Steel spare wheel - "Temporary Use Only" sticker?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GilbertOz, Mar 28, 2024.
  1. Mar 28, 2024 at 5:09 PM
    GilbertOz
    GilbertOz [OP] Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Looking at the 6-lug steel spare-tire wheel that came with my 2014 AC V6 4x4 MT TRD OR -- it looks like a normal, full-strength steel wheel to me, but I haven't seen enough of them to be sure.
    Why does it have a "For temporary use only" sticker on it? (Assuming that the tire I will put on it is a brand-new full-size normal tire.) Is the sticker needed because the truck comes with stock 16" alloy (aluminum) wheels (which I am running at this time) and the differing mass (heavier) of the steel wheel, particularly on the rear axle, would cause long-term issues due to different amts of torque required to accelerate/drive the heavier steel vs. ligher alloy wheel?
    I want to include this spare wheel + tire in my normal ~4-5K tire-rotation plan so it wears evenly w/ the regular tires.
    2024-03-28_13-24-48_1280px.jpg 2024-03-28_13-24-36_1280px.jpg 2024-03-28_13-25-02_1280px.jpg 2024-03-28_13-24-32_1280px.jpg
  2. Mar 28, 2024 at 5:44 PM
    TacoTuesday1
    FL
    Don’t know the purpose of a 5th rotate. Never done it.
    far as I’m aware oval hole presence means low speed limited.
    zero oval holes, and full circular holes is a regular steel wheel without that limitation, can be found for cheap, and can also be sourced from FJ steelies.
    I switched from oval hole spare to a circle holes spare, 17”.
  3. Mar 28, 2024 at 5:46 PM
    GilbertOz
    CA
    Gotcha. Staring me right in the face, that strangely-placed oval hole. Of course that would compromise strength and potentially balancing. Weird choice by Toyota.
    Edit: google search says the reason for the oval hole is to make it possible to check the air pressure in the spare without having to drop it from the vehicle. Makes a bit more sense.
  4. Mar 28, 2024 at 5:49 PM
    GilbertOz
    CA
    In my view the theoretical point of a 5-th wheel rotate is to keep even wear across all tires so that if the spare was ever needed it would be fully capable and ready to use for extended periods in any driving conditions (including high speed) without possible issues caused by A) different diameter (spare being larger than the other tires) or B) different traction (spare having a lot more grip because it's still brand-new, basically.)
    Let's say the brand new tire has 12/32" tread depth and a very worn tire has 3/32", that's a difference of 0.21" radius or 0.41" diameter on a 30" tire, or ~1.4%.
    Is a 1.4% difference in tire diameter & wheel speed enough to screw with ABS / VSC? Or any other issues related to unequal torque on the axle?
  5. Mar 28, 2024 at 8:11 PM
    vtdog
    vtdog Well-Known Member
    NH
    I recently replaced the spare on my '11 when I got new tires on all 4 wheels. The tire had never been on the road, but once a year I dropped and lubricated the lift unit. This year, I noted that the spare, which was an original tire, had numerous lateral cracks on the sidewall. I got a "cheap" tire for use as a spare (compared to the Michelin Defenders on the 4 wheels). When looking underneath I saw that the tire tech had put the spare on, but he had rotated the wheel 180 degrees (flipped it). I saw that the steel wheel had a "temp use" sticker which I never noticed before when I did the lubrication. It appears that the sticker was a "normal" placement, at least on my '11.
  6. Mar 28, 2024 at 8:14 PM
    MGMDesertTaco
    GilbertOz[OP] likes this.
  7. Mar 28, 2024 at 8:23 PM
    GilbertOz
    CA
    MGMDesertTaco[QUOTED] likes this.
  8. Mar 28, 2024 at 8:29 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Your math is off. 9/32" (12/32 - 3/32, per your example) is .281", which works out to .009% of a 30" diameter. Not worth the consideration.
  9. Mar 28, 2024 at 8:38 PM
    GilbertOz
    CA
    But is it? A single thickness is the radius. Diameter = radius x 2.
  10. Mar 28, 2024 at 8:40 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Oops, you're right... .018%. That's .018 of 1 percent, still not worth the bother.
  11. Mar 28, 2024 at 8:42 PM
    GilbertOz
    CA
    But is it .018%? Or is it .562 " / 30" = 0.0187 which is.. 1.8%. Nearly 1.9% if rounding.
    Based on what I've seen elsewhere on the internet (the subject of tire wear/diameter differences has been discussed plenty) I think 1.9% is probably tolerable for a certain distance at lower speeds, probably not ideal for long-term/ongoing use.
  12. Mar 28, 2024 at 9:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I thought the oval hole was there to stick a tire inflation tool in and top off air pressure..
    The valve stem is point up, you need a dual head inflator. Or at least that's the only way to air up with out dropping the tire down.
  13. Mar 28, 2024 at 11:18 PM
    TacoTuesday1
    FL
    never used that kind of inflator. It is one style of many styles out there. Not commonly used in shops, gas stations, or Costco self serve tire fill.
    Or air compressor.
    I may be wrong. But will say this. There is steelies out there people seem to run full time, such as aftermarket or FJ 17.
    I just run 4 tires and rotate them.
    Don’t know if the specific tire is a factor.
    just a heads up, if the oval is in fact just one for airing up
    I had no idea. Always placed my spare upside down with the rim down. Stem exposed. So I could air it. Figured it made sense that way. It’s not hitting anything and so far the hoist has worked without issue holding it that way. At the end of the day it’s a steelie with a hole and no cap, for the holder to grab regardless of side, and be cinched tight.
    eventual goal is swingout, Archive HH w high clearance cross tube that blocks spare
    It appears later Dirt King released their own version with angled bars that doesn’t block spare
    Not that cramming a 35 in there is easy anyway.
    had a working removal tool (the bars that put together) until one stripped and further got beat up at a tire shop
    they don’t look rounded to slide like Archive and who knows what other comparisons
    maybe I’m thinking of the weird uglier spare might’ve had that one originally
    that would make sense. For example, even a 5x114.3 can probably be star patterned to run on a 5x112 car. And/or cone seat lugs used on a ball seat or vice versa. But it is not ideal.
    Steelies are typically straight ball seat. While I think alloy Tacoma wheels are a combination of both ball seat and outer flat seat that is trickier to get straight then other designs.
  14. Mar 29, 2024 at 6:37 PM
    Waasheem
    Waasheem
    2007 xrunner
    Not something I would do or recommend but I’ve been passed by people with the tiny donut spare going at least 90mph. Then Ive also seen people standing next to a flat donut on the side of the freeway. I don’t want to say anything else in fear of jinxing myself.
  15. Mar 30, 2024 at 8:31 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    The aluminum spare on my 14' Limited is the exact same casting as the 18" wheels that came on the truck....except it doesn't have the dumb plastic cover stuck on it. It also doesn't have the TPMS transmitter. It came with the same sticker as shown on the steel rim. Toyota saved the price of a transmitter - for the price of a sticker.
    My guess is that the missing transmitter is the sole reasoning behind the warning. Otherwise the OEM spare has to be mechanically safe to install on a loaded truck.
