Steel Rims vs Aluminium on trucks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4runnerToTacoma, Apr 8, 2024.
  1. Apr 8, 2024 at 6:51 AM
    4runnerToTacoma
    4runnerToTacoma [OP] Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    Okay so, am I only one who finds Tacoma SR steel rims better? compared to aluminum sporty rims that comes with current SR5+?
    I feel like truck should have steel rims. Has anyone swapped out their alloy wheels for steel rims? and did it have any impact on towing/hauling?
    I dont care about MPG, I am talking about for towing/hauling. Thanks
  2. Apr 8, 2024 at 6:58 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Only relevant factors(for this topic) are load rating of the rims, weight, and cost.
    Less rolling mass, better braking performance. Aluminum wins.
    Wheels will match load rating of OEM door sticker(or better). So, the SR steelies provide no benefit over the SR5+
    If Aluminum wheels can handle the load of a semi...
  3. Apr 8, 2024 at 7:01 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    AL rims are bitch to keep clean. The theory is it takes less power to turn them. Yeah there AL rims on many big trucks I just wonder how much they gain for the expense.
  4. Apr 8, 2024 at 7:05 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Aluminum alloy wheels are usually stronger than steel counterparts. Work trucks have them because they're cheap, not because they're better at anything specific. If you do decide to switch, it shouldn't affect your load hauling or towing at all....that will come down to the tires. You can run either wheel type just fine.
    Personally, no way I'd trade any stock aluminum wheels for anything steel on my vehicles.
    Barsoom likes this.
  5. Apr 8, 2024 at 7:08 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I got both right now, but as soon as that other check comes in...............
    Malvolio and Jeffch like this.
  6. Apr 8, 2024 at 7:09 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Everyone saying there is no benefit to steel wheels is not exactly correct. If you do hardcore offroading, or just like hitting potholes at speed, steel wheels have the benefit of denting instead of cracking. Steel will still hold air and could likely be bent back to shape, whereas aluminum would be hosed.
    https://youtu.be/lWM3o2v46KI?si=07cRfGvZn_mF-96v
  7. Apr 8, 2024 at 7:10 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    The only real advantage I have ever experienced with steel wheels is they can be bent back into shape if you bend one out of shape. That said, give me aluminum wheels every day and twice on Sunday.
    Bertw192 likes this.
  8. Apr 8, 2024 at 7:11 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    there is the new trend, alloy wheels that look like steel
    3JOH22A and Malvolio like this.
  9. Apr 8, 2024 at 7:18 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    My personal opinion - neither adversely affects towing/hauling capacity.
    Steel wheels will rust.
    Aluminum wheels will corrode.
    Both require maintenance with respect to rust or corrosion.
    The alloy wheels on my '06 TRD OR exhibited serious corrosion (thanks to CT DOT's use of deicing chemicals). At about 10 years I had them blasted, baked & powder coated. Looked like brand new when they were done.
    I have a set of steelies for Winter use (not that we've had a REAL Winter in several years). They also underwent the same process. After about 5-6 years one can find pits & breaks in the powder coating.
    Powder coating the wheels is not perfect - there will be tiny locations where the coating fails and rust/corrosion starts to gain a foothold. So, the process will need to be repeated if you want them to look sparkly new year after year.
    I measure my vehicles life in decades, not years, so maintenance is mandatory.
  10. Apr 8, 2024 at 7:32 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’ll have you know when I potholed and made an oval out of my lame M35 alloy sport rim on the BQE, the old school freaks at Hilna in Brooklyn heated it up and brought it back to true. “It’ll do,” they said with a shrug. Looked like this one. Scary! What a stupid rim to run in NYC…
    Bertw192[QUOTED] likes this.
  11. Apr 8, 2024 at 7:36 AM
    Horseshoez
    Dale
    Maryland
    Here is a car I would never put aluminum wheels on, errr, if I was lucky enough to own it. :)
    Chasespeed likes this.
  12. Apr 8, 2024 at 11:04 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Back in the days that my friends and I would frequently visit salvage yards - accumulating hot rod parts - one of the places we often went campaigned a modified and had a for real mechanic. He and the owner of the place had a "wall of shame" with a big display of factory aluminum wheels - that had flunked being cleaned and coated with dye penetrant. Some didn't even have a scuff .......
  13. Apr 8, 2024 at 11:52 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    aluminum rims aren’t any harder to wash than steel rims, there’s no difference
    BoomerGVNG likes this.
  14. Apr 8, 2024 at 11:54 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Does not make any difference for towing or hauling. Alloy wheels are plenty strong. However, if you offroad, you can straighten a steel wheel and not an alloy wheel if you hit a rock.
    faawrenchbndr likes this.
  15. Apr 8, 2024 at 12:18 PM
    sublimaze
    sublimaze Well-Known Member
    Go carbon fiber and never worry about rust or corrosion, it’s easy to keep clean, and weighs less than either steel or aluminum.
    Bonus: You probably won’t see another Taco with the same wheels!
    :anonymous:
  16. Apr 9, 2024 at 6:10 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    AL rims are far more obvious when dirty.
  17. Apr 9, 2024 at 6:28 AM
    Jemm63
    Jemm63 Well-Known Member
    Jeff
    2015 Barcelona Red Tacoma SR5 - 2WD
    Hood deflector, Raptor SS side bars, Fold-A-Cover Hard Cover, Husky X-Act Contour Floor Liners, Touren rims, BFG Radial TA 245/60R15 tires
    My 2015 SR5 came with steel wheels with skinny tires so I wanted a nice set of alloys. I replaced the 15X6 steel rims with 15x7 alloy wheels and was surprised how heavy the steel wheels were. They are very thick and look strong. I put the largest 15" size tires I could with the almost same diameter (BFG Radial TA's P245/60/R15) that didn't rub on steering and it makes the truck look far better. The stock steel rims with the skinny tires weighed 49.5 lbs, and the aluminum with the BFG tires and alloy rims weighed 50 lbs. - slightly more. The alloy rims were a lot lighter in weight but the BFG tires were heavier. Hope this helps.
  18. Apr 9, 2024 at 6:46 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    You guys know that dented alloy rims can be repaired, right? They're also less likely to dent on the rim vs. the thinner edge of steelies. (Now they are more likely to shatter if they are cast, in a collision that would also mangle a steel wheel).
    Looks are subjective, but alloys always look better to me. Steel rims remind me of cheap cars with plastic or stamped chrome hub caps from 2000 (although the aftermarket ones donlook much nicer).
  19. Apr 9, 2024 at 6:49 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    17" wheels can accommodate a front brake upgrade (like the popular 5th gen 4Runner brake swap) which benefits towing/hauling. 17" steelies are way too heavy, so I chose aluminum. I picked matte black so it doesn't show dirt as easily, and easier to touch up when gouged on the trail.
  20. Apr 9, 2024 at 6:56 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    2022 TRD SPORT DCSB
    This has nothing to do with the material the wheel is made of - more to do with the color of the wheel.
