Steel-it coatings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darkblackSR5, Jan 2, 2020.
  1. Jan 2, 2020 at 11:48 AM
    darkblackSR5
    darkblackSR5 [OP] Member
    Hey buds!
    Wondering if anyone has done their bumper in Steel-it VS powdercoating?
    Waiting on my BAMF bumper to arrive, opted to get it in raw stainless vs the extra charge for powder. Thinking a few cans of Steel-It might do the trick. Anyone have any experience with the product?
  2. Jan 2, 2020 at 11:52 AM
    Flying_Taco
    Flying_Taco "In there"
    James
    Tacoma, WA
    2014 TRD OR
    I’ve heard good things about it so I purchased one can ($34) to coat some hardware. It was installed under the truck yesterday so time will tell. The prep instructions are pretty intense, including sanding or blasting. Like any coating, you’ll make your money prepping the surface the right way the first time.
    In the future I’d like to get a new rear bumper and will probably go for Steel It too.
  3. Jan 2, 2020 at 11:55 AM
    tasq
    tasq Active Member
    Dave
    Colorado
    '13 TRD Off-Road
    No experience with Steel-it, but check out POR-15
  4. Jan 2, 2020 at 11:55 AM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    I did my rear in Steel It. Came out pretty good. Recommend a good resprirator though....
  5. Jan 2, 2020 at 12:01 PM
    darkblackSR5
    Heck yeah! I appreciate the replies- Was starting to kick myself for not going ahead and getting the powder done. But sounds like this will work fine if I take my time and do it right!
    Flying_Taco likes this.
  6. Jan 2, 2020 at 12:06 PM
    DG92071
    DG92071 Well-Known Member
    I'm confused, if the bumper is stainless steel why would it need paint/powder coat to fight corrosion?
  7. Jan 2, 2020 at 12:20 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    His bumper should be made of Mild steel.
    I believe he meant to say the finish is bare steel VS Powdercoat.
    I have not used steel-it before. My understanding is that you can weld on the coating. This is good for weld projects that will have a chance to rust while its being fabricated.
    DG92071[QUOTED] likes this.
  8. Jan 2, 2020 at 12:28 PM
    darkblackSR5
    Ahh yes, sorry about that! I meant Raw steel not stainless. Thanks guys.
    DG92071 likes this.
  9. Apr 9, 2020 at 4:56 PM
    BOLT_THROWER
    BOLT_THROWER Member
    Menifee
    2014 Tacoma
    How did the coating come out? Any pictures?
  10. Apr 9, 2020 at 8:26 PM
    John90XJ
    John90XJ Well-Known Member
    2006 Tacoma Access TRD OR
    We used it on a tube chassis Ultra4 race car a few years ago. The race shop didn't have a proper spray setup so the new off the shelf Wagner Power Painter did the job. Prep is still the most important thing and will yield good results. While you can weld through it's better to plan on scuffing it and then re-applying when done. It's held up well for a couple of seasons and is far easier to maintain versus WD-40 and craploads of Scotch Brite.
  11. Apr 27, 2022 at 8:13 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    I just did my steering with it in black and it turned out great.
