Starting issue- AEM fuel pump retrofit 4.0 fix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wonderbread, Feb 23, 2020.
  1. Feb 23, 2020 at 4:52 PM
    wonderbread
    wonderbread [OP] Active Member
    Steven
    PNW
    08 Tacoma TRD 4.0 4x4 auto w Loc
    Bilstein 5100 adjustable w TRD Exhaust
    Hey all, brand new here. I’ve tried to search around to no avail for information on how to retrofit the
    AEM 50-1200 E-85 320 Lph @ 43psi in-tank fuel pump’ into my 2008 Taco? I’ve read nothing but good things about the mod and am wondering if anyone knows how to do it? My truck is showing all the symptoms of a faulty fuel pump or fuel pump resistor? It starts for a few seconds then dies like the fuel is instantly shut off. I remove the battery cable for 30 seconds to reset and then it starts and runs until it decides to die again, could be a day, week, or month? No idiot lights coming on either. The only other thing is that there’s a slight droaning of power @ about 2200 rpm’s when hard on the gas coming through and out of a turn. I’ve read on here that it was a fuel pressure issue and need all the advice I can get. Is the AEM route the way to go? And if so, how? TY All
  2. Feb 23, 2020 at 5:16 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    wonderbread[OP] likes this.
  3. Feb 23, 2020 at 5:21 PM
    Bishop84
    Bishop84 Well-Known Member
    Without a gauge hooked up its hard to say. But they do fail like this, and we see the 05-10 models starting to need pumps slowly.
    I would stay with what I know, and thats OEM/Denso. The AEM looks good, but I have no experience with them.
  4. Feb 23, 2020 at 5:45 PM
    wonderbread
    Steven
    PNW
    Thanks! I just went over that whole thread and it doesn’t seem that bad! Just some plastic cutting and a hose clamp. Did you run an in-line filter? I thought the sock is the filter in these trucks? And does that URD kit come with everything (minus the pump) to do the mod? Thank you for your time and knowledge!
  5. Feb 23, 2020 at 5:50 PM
    wonderbread
    Steven
    PNW
    Bishop84 Thank You! Yes it’s been a slow death for mine. It’s just gotten to the point where I’m done resetting it lol. If I go stock it will be a Denso. I’ve heard these AEM’s actually give a tiny bit more power with the increased fuel pressure??
  6. Feb 23, 2020 at 5:52 PM
    BassAckwards
    Yes i am running an external inline filter, but there is also a sock that goes on the pickup for the pump in the tank. The urd kit comes with everything you need to get it knocked out
    Also the urd kit uses a rubber hose for the high pressure pickup but the thread below has a good upgrade for that.
    https://www.tacomaworld.com/threads/improving-the-urd-fuel-pump-kit.308651/
  7. Feb 23, 2020 at 5:59 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Oem- lasted 12 yrs and let’s figure out how to retrofit something
  8. Feb 23, 2020 at 6:04 PM
    wonderbread
    Steven
    PNW
    Perfect! I see you have the 2TR-FE, its gonna all be the same for my 4.0? Are all the urd kits the same for the 2nd gen? Better yet, where do you recommend I get the install kit? TY
    BassAckwards[QUOTED] likes this.
  9. Feb 23, 2020 at 6:10 PM
    wonderbread
    Steven
    PNW
    That is a good point however it’s been doggin on pressure for 5 years now and if I’m gonna do the job might as well run the best... God Bless Texas
  10. Feb 23, 2020 at 6:22 PM
    BassAckwards
    Both the 2TR-FE and your 1GR-FE use the same fuel tank/pump, so yes the URD kits are the same for all 2nd gens
    URD sells the fuel pump kit that has a filter and everything you need to get rolling. Id get that from them and then buy the better fuel hose from summit racing
  11. Feb 23, 2020 at 6:34 PM
    wonderbread
    Steven
    PNW
    Thank You Robert! I appreciate all your good help man! I’ll be getting everything ordered up and in and then pull the bed and get to work. Does the URD kit come w a new tank gasket? I’ve heard they leak if you don’t change it out and use some gas resistant silicone? and That should be it for now. I know Time is free but priceless... Good Man TY
  12. Feb 23, 2020 at 7:05 PM
    BassAckwards
    No the urd kit doesnt come with a tank gasket. Itd be cheap insurance to replace that since accessing the tank is a bit of a pain. Id go with a toyota one if you are going to replace it
  13. Feb 23, 2020 at 7:13 PM
    Taco Roofer
    Taco Roofer Well-Known Member
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    The work beast and weekend warrior rig.
    I would go to the dealer and grab a new gasket, not sure if I would use any goop on it though unless it's recommended by Toyota.
    I have always had good luck with Walbro fuel pumps, but I have used a few AEM's boost management systems and they seem to have a good and reliable product!
    Good luck with the mod!
    12TRDTacoma and wonderbread[OP] like this.
  14. Feb 23, 2020 at 10:47 PM
    wonderbread
    Steven
    PNW
    Thanks Brother man! Maybe I won’t use the goop then...
    Taco Roofer[QUOTED] likes this.
