Starter totally locked up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Nov 27, 2023.
  1. Nov 27, 2023 at 11:12 AM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Ok, so I sunk the Tacoma yesterday. It was running, just drying it out. This morning I turned the key and all I hear is CLICK like if the battery was dead. Anyone have a starter totally lockup like that? It's getting voltage. I don't think it's a power issue
  2. Nov 27, 2023 at 11:36 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Not on a truck, but I did a 4 wheeler we had once.
    It was full of mud and dirt after sink it.
    The starter is a huge pain in the ass to get to on the 4.0 4WD trucks.
    I'd start with making sure all the connections are good and tight. (Did you have battery disconnected?)
    Then, I'd have a set of jumper cables, and another vehicle, to "help" send all the power I can to the starter.
    And hope that frees it up.
    Other wise, you're towing it home. Or pulling the starter off and replacing it.
    Once you get the starter off, you might get lucky taking the small little bolts off that hold the starter together and cleaning it out.
    But the thoughts off doing the starter 2x.......Ugh, I feel for you man.
  3. Nov 27, 2023 at 11:39 AM
    Bishop84
    Bishop84 Well-Known Member
    Yes it does happen, as long as youre sure its not the battery, I'd simply buy a replacement.
    If it was a newer model I'd say clean it out and see if you can get it working, but its run its course and the core value is more than the spare part value.
    jboudreaux1965[OP] and TnShooter like this.
  4. Nov 27, 2023 at 11:41 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Battery could read fine or close to, and you could still have a dead cell that doesn’t have the amperage needed to crank the truck over. Pop the battery out and take it to get tested. If the battery is good check all connections at the starter. If good try hitting the starter with a small hammer. The actuator could be stuck
    jboudreaux1965[OP] likes this.
  5. Nov 27, 2023 at 11:44 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    My baby girl "my Tacoma" made it through the night and even hit some more trails. We got it to my cousin's, started drying it out and went get some sleep. it's just in her carport, she doesn't have a shop or anything, so I'm not on the side of the road at least. Amps are fried, but the rest of the electrical seems pretty good. Battery still full charged, the truck was leaning towards the driver's side in the water. The water level was right below the inside fuse box and on the passenger side about as high as the top of the door speakers. So I think ECU is ok.
  6. Nov 27, 2023 at 11:49 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I have 2-3 starters at my shop, problem is I'm in Houston, shop is in Louisiana, lol! I'm at a relatives house who has no tools I have all my trail tools and gear with me, so not worried about core or cost per day, just trying to narrow down possibilities and keep the inconvenience to my cousin as minimal as possible.
    Battery is good, on the meter it was over 13v and I stick it on a charger for a few hours also.
    I'm thinking I might try previous posters idea, get someone with a heavy duty alternator to try to jump it and bang on it, see if it will free up. Then at least I'll know that is the issue.
    TnShooter likes this.
  7. Nov 27, 2023 at 11:50 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Didn't someone in your other thread with photos/video say your starter was going to lock up? Foreshadowing, for sure.
  8. Nov 27, 2023 at 11:56 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Yup!
    Replacing it was going to be part of the whole rest of the maintenance and repairs I'm gonna need to do, but never had a starter just completed fail that quick.
  9. Nov 27, 2023 at 1:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Can you turn the crankshaft with a wrench?
    And damn dude, you put your truck through a lot lol. Didn't you flood it a few years ago doing rescues during a hurricane?
    jberry813 likes this.
  10. Nov 27, 2023 at 4:32 PM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    Starters dying after water crossings is normal. Wish there was a better way around it... I buy Toyota remans, but even those are single-use with a proper dunk.
    I've never been left stranded though... even on morning no-starts with still-wet carpet, I can usually nudge it to crank with some quick flicks of the key in the ignition.
    Try timing it to music, throw in some pauses for swear words maybe... seems to help?
    Worst case, get a prybar on the starter and hit it with the hammer, like it owes you money, as wife cranks it. Seems to free things up.
    I do carry a spare starter on trips when I plan to get engine-deep in the drink though. Definitely a weak point when operating these trucks at depth!
    Edit: Two more thoughts:
    1. Shower it with some WD40 or whatever else you've got on hand... ideally to lubricate points of friction, but also just for general good luck, and don't hesitate to spray extra out of spite.
    2. If hammering on it, be careful not to short against the battery conductor! Remember, it owes you money... don't give it a chance to turn the tables on you!
  11. Nov 27, 2023 at 4:39 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    This. I’d be checking to make sure it’s not hydrolocked.
  12. Nov 27, 2023 at 7:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I thought he had it running and driving after the dunking...
  13. Nov 27, 2023 at 7:19 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Do you have the 6 speed? When my starter died I just pop started it in 2nd gear and moved along until I could get a replacement.
