Starter stays engaged weather Ignition is in Off Or On Position
Discussion in '1st Gen. Tacomas (1995-2004)' started by bogusjr23, Sep 14, 2013.
  1. Sep 14, 2013 at 12:08 AM
    bogusjr23
    bogusjr23 [OP] Member
    Riverside,Ca
    1996 Toyota Tacoma
    Please Help! I have a 1996 Toyota Tacoma (2.4L, 5 Speed Manual Transmission) I Went to Start my truck & the starter stayed engaged in both the on & off position. ALSO I Had to Put the gear in neutral Because the truck kept Scooting forward & I Had to disconnect the battery to disengage the Starter
  2. Sep 14, 2013 at 12:11 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Starter relay could be stuck closed. Pull the relay out, put in a known good relay and try again.
  3. Sep 14, 2013 at 1:42 AM
    bogusjr23
    Riverside,Ca
    1996 Toyota Tacoma
    Ok, Will do. Thanx
  4. Sep 14, 2013 at 7:33 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Could also be a bad (stuck) starter solenoid.
    But try the relay first, simple and cheap test.
  5. Sep 14, 2013 at 8:52 AM
    bogusjr23
    Riverside,Ca
    1996 Toyota Tacoma
    Thanx, it was a Bad Relay.
