Starter Motor Complete Failure - Armature Stuck in Transmission Housing (Problem Solved)
Discussion in '1st Gen. Tacomas (1995-2004)' started by g1_prefunner, Jul 2, 2023.
  1. Jul 2, 2023 at 12:07 PM
    g1_prefunner
    g1_prefunner [OP] Member
    Southern CA
    2001 Prerunner DCB Limited - 3.4L V6 / Auto (Silver)
    Bilstein 5100 / OME 2880 - ProComp 69s 15x8 - 31/10.5/R16
    Hi, new here and this is my first post. Gaining experience with my Taco so look forward to providing help instead of asking in the future.
    2001 PreRunner - 5VZFE - Auto Transmission
    My Toyota/Denso starter failed yesterday with a grinding sound and wouldn't even turn on ignition after. Ordered new Bosch unit, ready to install today.
    Video if you prefer:
    Removing my old starter, I noticed the Armature is stuck in - I assume - gearing that meets the starter at the entrance to the transmission case.
    Pictured:
    Haynes Manual Diagram: IMG_4459.jpg
    View Of Lodged Part: IMG_4455.jpg
    Up Close: IMG_4458.jpg
    First, Am I correct in saying that's the Armature, and maybe bearing stuck?
    It won't come out with a simple pull, and I wanted to ask the experts here (all of you - compared to me) if anyone has dealt with this, or if they know how I should proceed. What other parts should I inspect for damage or dislocation? Any tip is appreciated.
    Thank you in advance. Really need to get this back on the road for work.
  2. Jul 2, 2023 at 12:46 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I would suggest getting a big screwdriver or pry bar, put it in neutral and move the flywheel to the left a tad then smack it with a hammer. Should come out. Then check the teeth on the flywheel.
    Wulf and g1_prefunner[OP] like this.
  3. Jul 2, 2023 at 3:19 PM
    g1_prefunner
    Southern CA
    OK, thanks for the tip. I'll try that in a bit and update.
  4. Jul 2, 2023 at 6:33 PM
    g1_prefunner
    Southern CA
    Alright, reporting back. Learned about the shifter lock and got her in neutral. Unfortunately, the armature is so stuck - and my guess is mangled - between the flywheel and the tranny case, that I'm unable to get the flywheel to turn a degree in either direction.
    Some questions that come to mind:
    1) Is there a trick to the trade for turning the flywheel (other than a finger or a prybar through the starter's empty hole)?
    2) Will the flywheel engage if I take the truck off the jack and roll her? If not in neutral, then maybe another auto trans setting?
    3) I can't get much force behind the hammer either, and the whole situation here is making it apparent I should get a better angle for my hands, tools, and eyes. Is dropping the transmission something an amateur can do at home? I don't have a lot of experience but I was able to rebuild the entire front end, so I'm not completely incompetent - just need to learn many things on the fly.
    At a loss here, I finally had her running like a dream and the starter literally thrwe a wrench in the gears =\
  5. Jul 2, 2023 at 6:51 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Flywheel is bolted to the crankshaft. Put a socket on the main pulley crankshaft bolt and use a breaker bar to rotate it enough to take the stress off the starter shaft since it appears to be wedged against the bell housing.
  6. Jul 2, 2023 at 7:37 PM
    g1_prefunner
    Southern CA
    Will try this. I'm going to look up the crankshaft bolt, not eaxactly sure where it's located but I'm assuming somewhere along the height of where engine meets transmission.
  7. Jul 2, 2023 at 7:44 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Front of the engine, in the center of the damper pulley.
  8. Jul 2, 2023 at 7:44 PM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Front of engine, at bottom. Large pulley with drive belts going around it.
  9. Jul 2, 2023 at 8:07 PM
    g1_prefunner
    Southern CA
    Right on, I found it. Fan was a bit in the way so I removed the front skidplate and torqued from underneath. Unfortunately i could not get it to move. Is there anything that usually prevents it from spinning, or is it probably the jammed flywheel?
  10. Jul 2, 2023 at 8:07 PM
    g1_prefunner
    Southern CA
    Thanks, found it! Unable to make it budge unfortunately.
  11. Jul 2, 2023 at 8:20 PM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Gotta be the jammed flywheel. It should spin freely in either direction, only resistance would be the compression in the cylinders. Keep trying. Use a cheater bar if necessary and really lean into it. I believe you should be rotating counterclockwise. Hopefully the flywheel breaks loose before the bolt does.
    g1_prefunner[OP] likes this.
  12. Jul 2, 2023 at 8:39 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    If you can get a small pipe wrench, a pair of channel locks, or even some big vise grips on that broken starter drive, try twisting it. I think a good clockwise crank might just do it.
  13. Jul 2, 2023 at 11:20 PM
    g1_prefunner
    Southern CA
    Thanks for the guidance, much appreciated. Have to stop now, will catch a ride to work tomorrow and hopefully make some progress on the Fourth!
    surfishjoe likes this.
  14. Jul 3, 2023 at 11:41 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    At this point the transmission needs to come out.
    It sure sounds like a Flex plate failure caused the starter to self destruct.
    I have had starter drives fail but have never seen this much carnage.
    Maybe the transmission locked up.
  15. Jul 7, 2023 at 7:59 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Update?
  16. Jul 7, 2023 at 8:10 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    Remove the spark plugs and it should try really easy either direction
  17. Jul 7, 2023 at 9:53 AM
    Bivouac
    In this case that is not going to help. It can not hurt .
    We are waiting to hear what happened OP
  18. Jul 7, 2023 at 1:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It looks like the starter drive gear shaft somehow separated from the starter. Is that what I am seeing? Is it sheared off?
    The A340E will have a removable inspection plate that might provide another angle to access the area where that starter gear/flex plate interface is. It might also give some indication of the condition of the flex plate. It would be interesting to know if there is tooth damage or if the plate broke further in towards the crankshaft mounting point.
    It is concerning that the OP was unable to rotate the engine at all. The thought occurs to me that if the engine is locked up solid it could cause the carnage we see to the starter gear end.
    Bivouac[QUOTED] and Wulf like this.
  19. Jul 7, 2023 at 5:37 PM
    Bivouac
    If the engine locked the starter would have just quit unable to turn.
    It is all a guess till things come apart.
  20. Jul 8, 2023 at 7:03 AM
    g1_prefunner
    Southern CA
    Thanks for the input guys. I tried everything here. When I removed the spark plugs I was able to get a bit of movement from the flex plate, but it began to dent/bend the armature worse with no progress in my ability to pull it out. Didn't want to risk the flex plate's teeth or bellhousing integrity, for the reward of maybe shearing the armature in two and it falling further in.
    I've had it towed to a shop nearby, just one guy who works only on Toyotas. If I had the free time like I did just a few weeks ago, I'd try going through the trans myself. Unfortunately I'm putting in 16 hr days (2 hr commute to San Diego) and my schedule won't ease for a month. Swallowed my pride and looked around for a good shop. Had planned on doing all work myself, but such is life.
    Thanks again guys, I appreciate it greatly.
