SS3 Sport better than Pro?
Discussion in 'Lighting' started by Tacoma13_NC, Feb 11, 2021.
  1. Feb 11, 2021 at 9:13 AM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I'm interested in getting a set of DD SS3's for fogs, but I'm a little confused about output vs cutoff. The majority of what I read says Pros are better than Sports and Max's are best. I've also see a couple say they had Pros but we're downgrading in power output to Sports because they had a better cutoff for driveability. Can anyone elaborate on this? I'm willing to get the Pros if they're that much better, but if the Sports are better for driving purposes than I'd rather stick with them. Thanks for any help and clarification. I'm not paying $500 for Max's, that's just not worth it to me.
    dajosh likes this.
  2. Feb 11, 2021 at 9:27 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    PROs light output is better than the Sports but the cut off isn't as sharp because of it. More likely to get flashed by cars coming from the other direction
  3. Feb 11, 2021 at 9:28 AM
    Tacoma13_NC
    Ok this is what I wanted to know. Thanks
  4. Feb 11, 2021 at 9:30 AM
    Meatloaf
    North Florida
    I run the sports to be a considerate driver while still benefiting from superior light output
    dajosh likes this.
  5. Feb 11, 2021 at 9:31 AM
    Tacoma13_NC
    My mindset also. I can't stand when people do it to me so why would I want to do it to them. I think I'll go with the sports.
  6. Feb 11, 2021 at 9:35 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    I have the sports. If you aim properly, you won’t blind other drivers.
  7. Feb 11, 2021 at 9:38 AM
    dajosh
    dajosh Member
    Joseph
    2016 4Runner
    I also have the Sports. Paired with a set of proper LED retrofits is more than enough light without blinding others.
  8. Feb 11, 2021 at 9:43 AM
    Tacoma13_NC
    Agreed, although I have new OEM housings with upgraded harness, but same concept.
  9. Feb 11, 2021 at 9:44 AM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Nobody flashes me with my pro’s running
  10. Feb 11, 2021 at 9:53 AM
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
    I went with the pros. I live in LA and have drove around with them on and have never had any issues getting flashed. I have a 2-2.5" lift with the headlight upgrade as well. just need proper aiming. My thought on getting the pros was mainly, when would I most likely be running the lights. And I came to conclusion that it would be mostly while driving off road, at night, or low visibility. So no oncoming drivers to really worry about. I'd rather have more light output. From everything I've read though, you really can't go wrong with any of Diode's products.
    Tacoma13_NC[OP] likes this.
  11. Feb 11, 2021 at 9:57 AM
    Tacoma13_NC
    :thumbsup:
  12. Feb 11, 2021 at 11:22 AM
    miamijime
    miamijime Well-Known Member
    Jim
    St Louis MO
    2018 TRD Off Road Quicksand MT. 1980 HiLux 4WD long bed
    SwitchPro, 2” lift, TRD rock rim wheels, Japanese numbers + character on shift knob
    I have Sport which I run day and night because they look so cool. Never been flashed or hassled by the man. ( No front license plate.) Light bar on for pic only. 46EF500F-DD0C-40D4-9629-53A6E4822770.jpg
  13. Feb 11, 2021 at 11:27 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Diode Dynamics are trash!! :anonymous::crapstorm:
    Maybe @memario1214 can answer some questions!!
  14. Feb 11, 2021 at 12:13 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    SAY IT TO MY FACE!!!!! :laser::eek:
    @Tacoma13_NC the short answer to your question is that it comes down to the size of the LED emitter. The difference to you behind the wheel is that you will get the impression of more "light bleed" as the output on the pros doesn't draw quite as sharp of a line in the road in front of you, and the window of light is "larger". See photo below for direct comparisons.
    Either way... Aim them PROPERLY and John Q public will still not be blinded as his sightline will be below the cutoff of your lights. I don't really want to speculate as to why folks who had pros went down to sports, but if I had to guess it would either be A) Improper aiming, B) ALOT more light than stock down on the road so they figured that they HAD TO be pissing off the other guy... :notsure:
  15. Feb 11, 2021 at 12:16 PM
    Chunk
    2016 DCSB OR
    Baby Ruth
    NO! Maybe... when I make it to MT! Any SC trips planned soon? :rofl:
  16. Feb 11, 2021 at 12:17 PM
    memario1214
    Colton
    Missoula, MT
    You start walkin' my way...
    Chunk[QUOTED] likes this.
  17. Feb 11, 2021 at 12:18 PM
    Chunk
    2016 DCSB OR
    Baby Ruth
    On it! Thanks for answering the real question!
    memario1214[QUOTED] likes this.
  18. Feb 11, 2021 at 2:17 PM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    i didn't feel inferior with my sports until you posted this comparison
  19. Feb 11, 2021 at 8:18 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note that all 3 Sport/Pro/Max are all SAE complaint and street legal as fogs. The Pros do have more spill above the cut off (aka glare) than the Sport or Max, but within legal limits. If you are the type to leave them on all the time, the sports may be a better fit. One other point to consider, is the Sport will not get hot enough to de-ice. So if using them for snow conditions, the Pro or Max are a better fit to prevent snow/ice build up from obstructing output.
  20. Feb 16, 2021 at 6:37 AM
    cosmic65charlie
    cosmic65charlie Consumer of good times.
    Colorado
    2019 TRD OR AC
    Offroad stuff, Audio stuff, Cooler full of beer
    Really appreciate this information along with your other testing. This is why I went with the Pros, even though I thought the Sports would have been fine from an output perspective. No sense in having yellow fogs for the snow if they're going to freeze up and not work.
