SRS warning light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maverick904, Nov 9, 2009.
  1. Nov 9, 2009 at 10:47 AM
    Maverick904
    Maverick904 [OP] Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    this morning as i got in my truck to head to school i noticed the SRS warning light was son. the manual says take it to the dealer..i was just wondering what exactly this is.?
  2. Nov 9, 2009 at 11:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's for your air bag system. SRS = Supplementary Restraint System
  3. Nov 9, 2009 at 11:10 AM
    Maverick904
    Kameron
    Northeast Florida
    ya i just figured that out..has anybody else had this? i have a feeling takin it to the dealer is my only option. what are the odds it will be expensive? ahaha
  4. Nov 9, 2009 at 11:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    It could be a warranty thing. If not, anything SRS related is normally mucho dinero.
  5. Nov 9, 2009 at 2:51 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    My light came on a couple months ago and I scanned the code, 1801 which is an open circuit on the drivers side. I got it checked out and it was my clock spring that broke (Toyota calls it a Spiral Cable). This is a fairly common problem it costs about $200 for the part, I drove around about a month with it on. It means the airbag won't deploy if I meet in a major accident because their is no power to the airbag.
  6. Dec 2, 2009 at 12:48 PM
    bruce1271
    bruce1271 Well-Known Member
    Did you replace this yourself? Any write-up on how to do it? Mine has been on for about 30,000 miles. They (toyota)said there is an open in my spiral cable. Looks like I have the same issue.
  7. Dec 2, 2009 at 1:09 PM
    Asgard
    ^^No, haven't replaced mine as yet. From what I understand it should be fairly simple. You take the steering wheel off and remove the defective cable assembly, the trick is how you put the steering back on but someone told me the assembly has the instructions on a sticker stating how to position everything. The spiral cable assembly is like a tape measure consisting of two wires (airbag and horn) and when the steering turns the cable extends and vice-versa. You have to position everything so when you make a full lock you don't overextend the cable. I've read a thread on another forum where a guy soldered his broken cable back together but I wouldn't recommend that. I found two links that should be helpful :
    http://www.customtacos.com/tech/fil...6toyrm/06toypdf/06rmsrc/rm2006ta/04700510.pdf
    http://www.customtacos.com/tech/files/05FSM/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/0470066.pdf
  8. Dec 2, 2009 at 1:20 PM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    Obviously off topic for the tacoma -- but the same thing happened in my wife's honda civic. I got the code scanned, (forgot the number, its written down somehwere...), and per service guidelines it said that it was a pressure leak in the emissions system. Commonly this light comes on when a driver forgets to replace the gas cap after refueling, or there is a leak pre 02 sensor in the exhaust. I've had the code flashed on the car twice and it keeps coming back on. I haven't noticed a difference in performance or mileage or whatever, so I've just left it alone.
    Dont know if this is the same for our trucks, but get it scanned, it may no be as devastating..
  9. Dec 2, 2009 at 1:31 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
  10. Dec 2, 2009 at 2:35 PM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    I guess I can stop wondering now. Mine came on at 60k. I'm at 88k, maybe $200 is worth it though.
  11. Dec 2, 2009 at 2:39 PM
    Asgard
    I thought I was the only one driving around with my airbag light on.
  12. Dec 2, 2009 at 2:46 PM
    AzPrerunner05
    Tucson
    Lol, looks like most of us are doing it :eek:
  13. Dec 2, 2009 at 3:29 PM
    Tony D
    Tony D Well-Known Member
    Tony
    I just did the clockspring on my 99 Passat.. other than the fear of playing with the airbag it was a snap.. took about 1.5 hours to do. Got a used clockspring off www.car-part.com for $100 ($500 new from VW!!!) - then just had to get the Airbag computer reset so it would scan the system and all was fine.
    I would totally do it myself now on any vehicle.
  14. Dec 2, 2009 at 5:15 PM
    98tacoma27
    Ben
    Not Beech Creek
    That will trigger the CEL, not the SR5 warning light
  15. Jul 21, 2010 at 8:25 PM
    wolfeye
    wolfeye Well-Known Member
    Got in the truck this morning on my way to work, start it up, drive off, and the "SRS" warning light came on. Looked up the indicator light in the manual and it says "Take vehicle to Toyota dealer immediately." So after work I drive directly to the dealer. My truck is over 36,000 miles and my Toyota Extra Care will be used for the inspection. Dealer says there isn't anything they can do and I should bring it first thing tomorrow morning when Extra Care is open. If I go through Extra Care they charge a $50 deductible. What could be the cause of the light coming on?
  16. Jul 21, 2010 at 8:37 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Most likely clock spring.
  17. Jul 21, 2010 at 9:39 PM
    wolfeye
    Any idea how much this item will cost without the "extra care". Should have never purchased it. Such a rip off..:mad:
  18. Jul 21, 2010 at 9:51 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Dealer quoted me $90 for a new clock spring.
  19. Jul 21, 2010 at 10:50 PM
    JKD
    JKD Well-Known Member
    I was just flipping through my warranty info booklet on my '09, and noticed that the seat belts and airbag system are specifically covered up to 5 years and 50,000 miles. The spiral wire assembly is not listed in the "what is not covered" section, so it should be covered if you aren't over the warranty limits.
  20. Jul 22, 2010 at 3:59 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    :eek: I've been driving around with my airbag light on assuming that it wasn't covered on my 07, but if that is the case I'm in luck
    Cheers Brother!
    :cheers:
    One thing: If you had a bad seat sensor would that trigger the airbag light as well? If so why not just bypass it?
