SRS Warning Light - On Solid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by this_is_nascar, Aug 24, 2014.
  1. Aug 24, 2014 at 1:26 PM
    this_is_nascar
    this_is_nascar [OP] Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    A few hours ago, I was involved in an accident whereas I was rear ended. Ever since then, my SRS warning light remains on solid. I didn't substain too much rear end damage because I had my hitch and my hitch ball installed and that absorbed most of the force.
    My question is does that solid SRS warning light mean that my airbags might come on at any minute or does it mean the opposite, that they won't operate at all now? I don't want to be driving down the road and have the airbags deploy unexpectedly.
    With the rear impact due to the hit, what could have occurred to make my light stay on?
  2. Aug 24, 2014 at 1:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    SRS Light on means that the system has detected a failure somewhere and the system is disabled. No it will not go off unexpected or even in a wreck with the light on.
  3. Aug 24, 2014 at 1:39 PM
    MadMatt
    MadMatt Member
    PreRunner SR5
    Switchback signals, led stop lights.
    The way the system is designed, if the light is on, the system is down. The should deploy. Although stranger things have happened. As far as what caused the light to come could be a number of different things. Have it checked.
  4. Aug 24, 2014 at 3:12 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Thanks. I'll have to get it into the dealer. It just doesn't make sense to me why this would occur during a rear-end hit.
  5. Aug 24, 2014 at 5:20 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Did the Seat Belt Pre-Tensioners go off? It is possible for them engage even with the air bags not deploying. If they did, that will cause the SRS Fault Light until they are replaced and the system reset.
  6. Aug 25, 2014 at 4:12 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    How would I know if that happened?
  7. Aug 25, 2014 at 7:59 PM
    smd3
    smd3 Well-Known Member
    You won't be able to use the belt, it'll be locked. Check the passenger belts.
  8. Aug 26, 2014 at 7:35 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Both fronts belts are usable. We used them on the way home from the accident and several times since. I extended each of the rear belts. They extend and retract like they should.
  9. Aug 26, 2014 at 7:40 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Check the plugs to the seats and seat belts. Connectors are always a weak link. The nice thing about airbags is once you find the short, the light goes out on its own.
    You dont have something heavy sitting on the passenger seat do you.
  10. Aug 26, 2014 at 7:44 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Nope, nothing different than usual. Me in the driver's seat and my wife in the passenger's seat. No issues until getting ass-ended and since then, the SRS warning light will not go off. It stays lit on solid. No airbags deployed, nor would I expect them to from a rear-end collision.
  11. Aug 26, 2014 at 8:33 AM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    could be the spiral cable on the steering wheel and coincidentally it happened right around the same time.
    I couldn't figure it out and I knew there 's a recall on it..maybe the dealer will check it for free.
  12. Aug 26, 2014 at 12:59 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Thanks. I'm going to get it checked at the dealer in the next several days. I'll report back as to what they find.
  13. Aug 26, 2014 at 2:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It should be covered as part of the accident repairs under the insurance claim. You were rear ended correct? It should be repaired under their insurance.
  14. Aug 27, 2014 at 5:33 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Absolutely. I'm not worried about it getting paid. I'm more interested on what actually broke to cause the condition. Its going in on Thursday for this and the recall.
  15. Aug 27, 2014 at 6:12 AM
    Kala
    BigIsland
    05 PreRunner SR5
    the insurance company may talk you into saying the air bag light was already on which disabled the air bags…and some how they may twist it into you causing the accident so they can get out of paying you/fixing your truck.
  16. Aug 27, 2014 at 7:53 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    I got ass-ended, at a stop sign, by a guy who admitted he was distracted. I have no concerns, as his insurance company already accepted total responsibility.
  17. Aug 27, 2014 at 8:38 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    I had my SRS light come on and stay on, this was before the clock-spring recall was done. When I went in for the recall, they found my airbag sensor on the front bumper went dead. Might be something like that.
  18. Aug 27, 2014 at 2:38 PM
    koditten
    Kirk
    Central Michigan
    As soon as they boot up the Techstrem program, they will be able to tell you what sensor is not giving feedback. Hopefully it s not the ECU for the SRS system. Most likely the dealer won't let you take the truck home and hopefully they give you a loaner until the new ECU shows up.
    I can't wait to find out which sensor was bad.
  19. Aug 28, 2014 at 5:48 AM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    The truck arrived at the dealer @ 07:00 this morning. It's now 08:45, so I don't expect to hear anything for several hours. I'll keep everyone posted. At 1st, he didn't want to start the work until the insurance adjuster came. I told him that would waste most of the day. Do the work, I'll pay if I have to and then charge it back to the insurance company. They're going to diagnose/fix the SRS Warning Light Issue, then do the loose pre-tensioner recall.
  20. Aug 28, 2014 at 2:54 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Got my Tacoma back and the SRS Warning Light is now functioning as it should. I also got the seatbelt pre-tensioner recall done while it was there. Now, I don't claim to be the sharpest knife in the drawer, but to me it doesn't appear they did anything other than to reset the system.
    Here's the description from the work-order:
    "Customer states SRS light is on since accident. Was hit in the rear.
    Pulled codes found OCCUP DET SYSTEM malfunction. Started from removing dust and debris from driver's side air bag harness to make sure it was not the problem. Performed 0 point calibration and performed sensitivity check. Codes are cleared, not road tested and nothing pending."
    Any thoughts on this? Oh and by the way, this was $220 before tax.
