SR5 4wd , but Carfax says the vin is TRDpro??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freakyjones, Aug 22, 2017.
  1. Aug 22, 2017 at 8:24 PM
    freakyjones
    freakyjones [OP] Member
    i'm new to this forum , and it looks like there are a number of related threads, so sorry if this is a redundant thread . the vehicle in question is 2 states away at a dealership, so i cant examine it firsthand , i only have access to dealer photos, and maybe photos i get the guy on the lot to snap for me. all apparent signs point to SR5 4wd, that's how its billed, priced, labelled, and there is only a blank button where the rr diff lock button would be . BUT , the carfax report is telling me that the vehicle for that vin is a TRD PRO ??? is the carfax report wrong? is the factory VIN info wrong ? - how reliable is the carfax info regarding vin ? any cases of a vehicle being manufactured with the intent of TRD pro , but then the package never got installed and VIN info reflects incorrectly ? any chance i stumbled onto a TRD PRO that is mislabeled and the RR diff button was never labelled as such ??
  2. Aug 22, 2017 at 8:41 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    If no locker than its an SR5
  3. Aug 22, 2017 at 8:48 PM
    Pigpen
    Northwest Montana
    Car fax means nothing
  4. Aug 22, 2017 at 8:54 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    They could have entered the wrong vin for the correct truck in human error. Not likely it's some trd pro unicorn that left the factory w/out a rear locker. I'd call the dealership and confirm what you're looking at first.
    TRDSport10 likes this.
  5. Aug 22, 2017 at 8:55 PM
    Bishop84
    Bishop84 Well-Known Member
    Share vin, we can decode.
  6. Aug 22, 2017 at 9:02 PM
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    freakyjones[OP] likes this.
  7. Aug 22, 2017 at 9:04 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    Don't trust the VIN they publish in the listing, have them take pictures of the VIN on the dash, the door jamb, the windows, etc. They should all match, and I bet they are different that the VIN in the listing online. Something isn't right here... Post the link.
  8. Aug 22, 2017 at 10:42 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    It's not a Pro. Common mistake, the Carfax is wrong. It's the same reason there are so many non-Pro 2nd gens listed as Pros by dealers: their system grabs info out of a database to auto-populate the listing but the info is incorrect.
    Example: check out these listings. 13 listed as 2015 Pro but only 1 is genuine. https://www.ksl.com/auto/search/ind...o=2015&miles=25&page=0&cx_navSource=hp_search
  9. Aug 23, 2017 at 2:56 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Title VIN's are misread sometimes... U's and V's, for instance.
  10. Aug 23, 2017 at 7:21 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is normal for carfax, the truck is not a Pro. My truck is listed as a Pro by carfax but it is an Off Road.
    Welcome to the forum and nice job doing your homework. Post up some pics once you purchase!
    TRDSport10 and freakyjones[OP] like this.
  11. Aug 23, 2017 at 9:01 AM
    freakyjones
    wow , thank you guys for all the replies , extremely helpful !. i'm impressed with this site, glad i found it ! - like a few of you said, likely that the listing in carfax is incorrect. Again, thanx !!
    crashnburn80 and RyanL like this.
