SR fog light wire harness and switch recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yoda22, Dec 7, 2021.
  1. Dec 7, 2021 at 9:41 PM
    Yoda22
    Yoda22 [OP] Member
    2022 Tacoma SR 4x4 v6
    Hi,
    Im aware of other post on here regarding fog lights. My question is actually looking for fog lights recommendations of reliable brands to purchase for the wiring part. Can anyone recommend a good reliable Wire kit and switch so I can get my fog installed?
    my main concerns was after googling, people fog light wires can catch fire and switch melt. Hopefully I dont have to deal with it. Much thanks!
  2. Dec 8, 2021 at 12:44 AM
    caribe makaira
    Caribbean, Puerto Rico
  3. Dec 8, 2021 at 1:37 AM
    Yoda22
    Yoda22 [OP] Member
    I saw that post but couldnt find the link to buy a reliable wiring kit for it…
  4. Dec 8, 2021 at 3:25 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    I just did a cheap open box kit from extreme terrain on my SR recently. Came with wiring, fuse, switch, some wires were a little short so I had to add. I paid around $30.
  5. Dec 8, 2021 at 6:49 AM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    I used a harness from CaliRaised. They have some good videos for installation as well.
    Robsharp06coma and Yoda22[OP] like this.
  6. Dec 8, 2021 at 9:38 AM
    Yoda22
    Yoda22 [OP] Member
    Some people said dont use cheap wire since its not reliable.
  7. Dec 8, 2021 at 9:40 AM
    caribe makaira
    How about just purchasing the missing OEM harness?
    grad3r likes this.
  8. Dec 8, 2021 at 9:40 AM
    jeffmansion
    16UTILITY4x4MT2.7
    The wires fine. It was just a bit short. Bet ya I won't have a single issue with it.
    Yoda22[OP] likes this.
  9. Dec 8, 2021 at 11:00 AM
    Yoda22
    Yoda22 [OP] Member
    I looked into that too but they said oem involves turning other lights on and is not the best, i dont mind using oem if it works exactly the same as aftermarket. Do you think the 19-21 can fit my 22?
  10. Dec 8, 2021 at 3:23 PM
    caribe makaira
    Who is they?
    Look at the connector on your '22 and verify it's the same from the Nitori thread. (it should be)
  11. Dec 8, 2021 at 3:25 PM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    I liked the Rigid D series fog lights.
  12. Dec 9, 2021 at 2:20 AM
    Yoda22
    Yoda22 [OP] Member
  13. Dec 9, 2021 at 2:21 AM
    Yoda22
    Yoda22 [OP] Member
    Reddit and also I went to tacoma dealership today and they literally just told me to fk off. Saying if i buy used oem, i need to buy a bunch of other things to make it work. They quote me $2k to have it installed by them lol.
  14. Dec 9, 2021 at 2:32 AM
    caribe makaira
    Stealership will do all they can to make you pay more. I don't know if REDDIT even quotes this forum.
    The SR will be either ready for fogs or not. Like the info on the link I posted. Verify your SR for the missing relay, it may have the terminals to secure the missing relay. Same for the steering wheel light stalk connector, it'll be with or without the required wires. Also the missing bumper harness.
    The SR will have the connector open to the environment.upload_2021-12-9_6-34-51.jpg
    Procure the missing harness and install it. Same for the relay. For the missing switch is either an inexpensive switch or any one you choose. All the switch is doing is providing a signal to ground for the circuit.
    With any other type of install you can duplicate what the vehicle is missing, as long as you clone the setup.
  15. Dec 9, 2021 at 5:06 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Probably the reason they catch fire is people are using high current bulbs and using a cheap switch instead of using a relay with good terminals. Generally some people just try to string together a cheap switch to good lights with no fuse and it burns out the switch or the wires or both. Ohms law is straightforward.
  16. Dec 9, 2021 at 7:17 PM
    Fire Arrow
    Jim
    MD
  17. Dec 11, 2021 at 8:41 PM
    Yoda22
    Yoda22 [OP] Member
    Thank you!
  18. Dec 11, 2021 at 8:43 PM
    Yoda22
    Yoda22 [OP] Member
    i actually have that wire but was wondering what that does. So does this mean mine is prewired? The dealership told me it is not.
    Do you think this is all i need?
    https://www.ebay.com/itm/303947729100
    i kind of want to use the press button rather than install a new steerling set.
  19. Dec 12, 2021 at 8:50 AM
    caribe makaira
    That be all you'd need in one package. There are post here to follow the install.
