Squirrel Damage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoroamer, Dec 21, 2021.
  1. Dec 21, 2021 at 1:32 PM
    Tacoroamer
    Tacoroamer [OP] Active Member
    Atlanta
    06 Access Cab
    camper top
    I have had two repairs this month totaling over $2000 on my 06 Tacoma due to chewed hoses and fuel line. South Atlanta Toyota said the hose above the fuel tank (that was chewed) only comes with A NEW FUEL TANK. That was $1400. Charcoal canister had to be replaced because its chewed hose also only comes with a new canister $400+. They said rodents had chewed both hoses. The trouble was revealed when the Check Engine light came on and I was getting p0441 and p0455 emissions codes. My Ultragauge revealed this. There is a rodent repelling device that connects to the battery and uses strobe and ultrasonic sound when it detects motion under the hood and the truck is parked with engine off. I found it on Amazon so I guess I'll try it. You get two for $55. There are battery ones also but I don't want to have to keep changing AA batteries. There is also some so-called rodent repelling tape for wiring but I'll try the electrical device first. Has generally good reviews... 60% 5-star. Anyone got any other ideas? (other than building a garage!)
  2. Dec 21, 2021 at 1:42 PM
    NJOffRoad
    NJOffRoad Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    My only advice is to try and get parts like that from a junkyard in the future. Those hoses generally don't go bad or decay, so if you can find one off a truck with some damage in an irrelevant spot, it could save you the cost of buying an entire gas tank.
    Mully likes this.
  3. Dec 21, 2021 at 1:45 PM
    Lambo9418
    Lambo9418 Well-Known Member
    JP
    Black 2019 TRD Pro
    Maybe give the little buggers something else to chew on? Perhaps you can line your parking area with peanut butter-baited rat traps?
  4. Dec 21, 2021 at 1:49 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had the same thing happen. My tricks were. 1. Empty plastic vitamin container, drill a bunch of 1/4 holes, fill with moth balls and zip tie in engine bay. 2. Use Mens hair spray, spray all wires and dust with cayenne pepper, spray again. 3. Buy Gamo pellet gun, set up bait station, kill ‘em all.
  5. Dec 21, 2021 at 2:03 PM
    Coldrider
    Coldrider Well-Known Member
    Mark
    Blk Limited 2019
    None
    The squirrels up here carry off rat trap and all. CCI birdshot .22 won't damage much if you miss, but the little bastages don't like it.
  6. Dec 21, 2021 at 2:04 PM
    Jp5385
    Jp5385 Well-Known Member
    2014 TRD Sport V6 4x4
    I also had this problem on my 4Runner, our cars are parked outside in a car port. I bought the same repellents you bought a few months ago but I bought the battery powered ones. They last a little over two months and I use the rechargeable batteries. I use to spray peppermint oil mixed with water in the engine bay and around my truck. But you have to spray it 3 times a week for it to work so I stopped doing that. But so far so good. Hopefully it stays that way.
  7. Dec 21, 2021 at 2:05 PM
    Matt8vt
    Matt8vt Well-Known Member
    Illinois
    2021 MGM TACOMA SR5 SB 4X4
    Method 305 16x8 in black with duratracs 265/75/16 Running boards SS3 fog lights Truxedo tonneau Carhartt seat covers
    Oof I am sorry, this is my nightmare. With winter coming hopefully the little critters find homes elsewhere. Good luck
  8. Dec 21, 2021 at 2:27 PM
    Tacoroamer
    Atlanta
    06 Access Cab
    camper top
    Thanks for the comments! I've been feeding them on the patio but that stops today. I noticed a few days ago when we had a washing machine repair guy here, a bunch of squirrels were climbing up into the wheel wells of this truck. Must be attracted to the warmth of the engine. We just thought it was cute at the time but now we've put 2 and 2 together and it's not cute anymore. Anyone know of a circuit breaker switch that will fit in the panel knockouts for extra switches in a 2006 Taco? I'd like to have a breaker in the line with these repellent gadgets and be able to turn them on/off from inside the cab, just in case, to make sure it doesn't short out the battery or run it down.
  9. Dec 21, 2021 at 2:34 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Couldn't you just replace the lines?
  10. Dec 21, 2021 at 3:50 PM
    spitdog
    jfox8 and Raylo like this.
  11. Dec 21, 2021 at 4:54 PM
    riverrat958
    riverrat958 Well-Known Member
    keith
    upstate ny
    2015 base crew cab tacoma
    camera source backup, camera seat covers,intermittent wiper arm
    get a outside cat?? the reason animals are chewing on wires all the sudden is because they are plastic made from corn starch. that's what they are after.
    DG92071 likes this.
  12. Dec 21, 2021 at 5:08 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    I read on one website if you have a flower bed or yard nearby you could use a motion activated sprinkler to scare them off. That's the best I got. Thankfully my only encounter with a squirrel and my truck is a hedge apple in my engine bay.
    DG92071 likes this.
  13. Dec 21, 2021 at 11:26 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Don’t go to a dealer for repairs
    Find local mom n pop garage
  14. Dec 22, 2021 at 12:54 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    They also like to get up under the plastic engine cover and eat hoses and injector wires so watch there too - been there done that. I got the electronic repeller but if you are close you too can hear that annoying noise but.... so can't the critters and add mice to the mix ha ha. Many city dwellers get hit when camping.
  15. Dec 22, 2021 at 1:36 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Get some peanut butter and mix it with antifreeze
    cloudbnd, Oreo Cat and DG92071 like this.
  16. Dec 22, 2021 at 3:38 AM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    If you don't already have it you may want to consider adding comprehensive coverage to your auto insurance policy with either a low or $0 deductible.
    wi_taco and muddog321 like this.
  17. Dec 22, 2021 at 3:45 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    So you trained them to come to you food, and now you’re shocked they damaged your truck trying to find food? Hmmmmm
    wi_taco and eherlihy like this.
  18. Dec 22, 2021 at 4:06 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    There is a whole other thread on this but i cant find it
  19. Dec 22, 2021 at 12:10 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    tacofish[QUOTED] likes this.
  20. Dec 23, 2021 at 2:14 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I had my abs harness changed out due to a squirrel. Covered under comprehensive insurance. Minus my deductible. I installed a rid a rat. It’s a flashing led light. Hard wired it to the battery. It’s been almost a year now.
    DG92071 and JGO like this.
