Squeeze a bigger battery in?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natenite, Aug 22, 2020.
  1. Aug 22, 2020 at 5:18 AM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Having some talks in other threads about batteries and powering fridges and such. Got me wondering.... looks like the first gen fits a 24f or 35 group size battery. Sounds like 2nd and 3rd gen trucks come with the same but can fit in a 27f. I’m wondering a couple things...
    1: Can we fit a 27f or another “larger” battery in?
    2: Is there a real advantage to a larger batter?
    3: Am I risking messing anything up but increasing the battery size?
    Any help would be appreciated. Thanks!
    Hotrodroxie likes this.
  2. Aug 22, 2020 at 8:14 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    You can fit a group 31 in with a little finagling.
  3. Aug 22, 2020 at 10:18 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The quality and type of battery is important to. At times more then the size of battery. Take a look at the x2 battery from Batteries Plus. Also has a great 5 year free replacement warranty. Many people are seeing 5+ years of life out of them in diesel pickups.
    They're pricey, but 10% online curbside order and $20 mail in rebate online.
    Wulf and Wyoming09 like this.
  4. Aug 22, 2020 at 10:28 AM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    1.) Take measurements of the space you have, and then look at the dimensions of batteries you’d like to put in there. There is quite a bit of extra room for something larger, but measuring will be your friend so you don’t have to deal with returns and guessing.
    2.) In theory more capacity, more cranking amps, longer draw times. However, as was mentioned, the type of battery and quality of battery plays a big role. An anecdotal example would be a standard lead-acid battery vs an AGM battery - a larger lead-acid battery likely would not perform as well as an AGM battery. So pay attention to the stats on the batteries, no sense in “upgrading” if it’s not an actual upgrade.
    3.) The only thing that could get messed up by running a bigger battery would be due to it being a heavier battery and cracking or denting the inner fender apron upon which the battery rests. However, upgrading a single battery probably wouldn’t be enough to do anything like that, you tend to see things like that happen when doing dual batteries in that spot. The increased weight from a single upgraded battery should be totally fine.
  5. Aug 22, 2020 at 11:03 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Didn't our trucks have the option of a cold-weather kit that included a larger battery?
  6. Aug 22, 2020 at 11:31 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    If you going to add a battery that is wider then the stock battery. I recommend cutting a piece of 1/8 inch aluminum or 14g sheetmetal the size of the battery and place it under the battery for support. The stock battery hangs over the edge about 2 inches with nothing to support it, other then the plastic tray. A wider battery would hang even more out possibly deforming the bottom of the battery.
  7. Aug 22, 2020 at 11:36 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  8. Aug 22, 2020 at 11:37 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    There are two types of batteries a starting battery and a deep cycle some thing to think about if you are going boondocking with a fridge etc.
  9. Aug 22, 2020 at 11:43 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    The X2 battery from Batteries Plus covers both.
  10. Aug 22, 2020 at 11:54 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    As soon as my wallet allows it, I'm going with Northstar 24F for my dual battery set up.
  11. Aug 22, 2020 at 1:45 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    the X2 is made by Northstar. Don't know if there is a price difference.
    QMEDJoe[QUOTED] likes this.
  12. Aug 23, 2020 at 4:40 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Highly recommend an isolator, relay type is the cheapest and easiest no dead truck battery when it's time to go home.
  13. Aug 23, 2020 at 6:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    1 Just why do you need more battery??
    What type of new loads for the battery ??
    You can install any battery size you desire most likely not under the hood .
    Are you needing a dual battery system ??
    It all comes down to just Why you need more battery ??
    mechanicjon likes this.
  14. Jan 3, 2022 at 9:05 AM
    Hotrodroxie
    Hotrodroxie Active Member
    NEO
    08 Tacoma dbl 4x4, poor girl stock
    that’s what I thought to! On my 2008 dbl 4x4- I could have swore I paid for some bs upgrade that included a better battery & other key investment components (alternator maybe?).... but I can never find info about it.
    I do remember that all the different upgrades I was getting there was some issue with them not working in combination together...things canceled each other outt‍♀️...it caused an issue with my bucket seats I couldn’t used the $200 oem seat covers I wanted/bought; the dealer couldn’t figure out why they wouldn’t work with the seat design! I was so pissed!
  15. Jan 3, 2022 at 9:30 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Older thread I know, but...
    If you're looking to add overlander accessories, fridges and all that stuff, as others have said, 100% go with a 2nd battery with some type of an isolator system. If you're looking for "more storage" don't get a bigger battery.
    Let the main battery start the truck, and all your other junk should be powered by the 2nd battery. Or just get a Jackery.
  16. Jan 3, 2022 at 2:01 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Tow package has the group 27 battery all ready. By the way don't buy a starter relay if you are going to use for two it will burn up day one make sure it's an isolator one.
