squealing serpentine belt.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by avid, Jan 10, 2013.
  1. Jan 10, 2013 at 6:21 AM
    avid
    avid [OP] Member
    don
    florida
    07 4cyl access cab
    My main belt squeals a little when I first start the truck. it quiets down after a few minutes and is fine for the rest of the day, but the next morning it will make noise again till it warms up.
    I was told by several people that using dove soap or bar soap will quiet the squeal.
    Any experience with this.
    An examination of the belt looks fine and the tension seems good.
  2. Jan 10, 2013 at 6:25 AM
    Chayes119
    Chayes119 Long Member
    Georgia
    06 PreRunner SR5 BLK
    How old is the belt and how many miles on it?
  3. Jan 10, 2013 at 6:55 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Replace it?
  4. Jan 10, 2013 at 6:55 AM
    avid
    avid [OP] Member
    don
    florida
    07 4cyl access cab
    My tacoma is an '07 with 53k.
    I hesitate to put anything on the pulleys or belt, but I did clean the pulleys. One in particular was really dirty. It seemed to help, but I won't know for sure untill tomorrow morning when i start her cold.
    Seems like their could be alot of reasons for the squeak. I have a friend who is a mechanic and he is going to change to the belt for me...I'm hopeful that will do the trick.
  5. Jan 10, 2013 at 9:18 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    If the belt is glossy, or cracked, or shines, its dried out and needs to be replaced.
    Dishsoap is a rubber lubricant, and the purpose of the belt isn't to slide, its to grip. Do not put dishspoap on it, because anytime your engine gets wet and the soap can "suds" the belt will slip.
    There is a reason we use it on the impellers in water craft in the spring. It frees up the stuck rubber propeller.
  6. Jan 10, 2013 at 9:23 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Toyota was too cheap to put sealed pulleys on these trucks so they could have foreign matter within them causing the bearings to wear and cause the noise.
  7. Jan 10, 2013 at 9:32 AM
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    You can also get belt dressing. I would look the belt over to see if it glossy or has cracks in the ribs if so replace the belt. You can also clean the belt with a brass brissel brush while it's running if you are real careful. But this is a temp fix it's best to replace the belt.
  8. Jan 10, 2013 at 10:37 AM
    Rivet Joint
    Rivet Joint Well-Known Member
    Albuquerque, NM
    2010 SWB DC Sport
    5100s @ .85, OME 885s, Rear TSB, Helo Max 6's, General AT2 Tires, Black Badges, Demello Offroad Bumper, Grillcraft, Sub/Amp, Pioneer DVD HU, TRD Intake & Exhaust.
    this happened to me about 3 wks ago. i thought it was the s-belt but turns out the tensioner pully was wearing out. my truck is a 2010 and has 55K miles on it. i also drive about 5.2k miles in about 5 wks. Dealership swapped it out in about an 1.5 hrs. Cost about @250.
  9. Feb 14, 2013 at 11:24 AM
    Rivet Joint
    Albuquerque, NM
    2010 SWB DC Sport
    just the pulley. I went ahead and had them replace the belt too...just in case.
  10. Feb 14, 2013 at 12:30 PM
    Rivet Joint
    Albuquerque, NM
    2010 SWB DC Sport
    Sure...I'll see what I can do for you. Standby.
  11. Feb 14, 2013 at 3:40 PM
    XXXX
    sKiP
    05 Prius
    It's on the PM pic I sent you.
  12. Feb 24, 2014 at 5:40 PM
    LN13
    LN13 Well-Known Member
    Dave
    Cave Creek AZ
    2024 TRD OR Hybrid
    I have the same squeal at startup, which happened 2 starts after I replaced the belt with an OE belt. It still squeals after about 8 starts. Is it possible the tensioner went bad after I used/moved it? It doesn't seem totally logical that it would go bad within the same day, but maybe becasue I moved the tensioner it effected its integrity.
    Does anyone have any thoughts on this? It only squeals on startup.--thanks
