Squeaky suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by guywithahog, Mar 9, 2023.
  1. Mar 9, 2023 at 7:49 PM
    guywithahog
    guywithahog [OP] Well-Known Member
    Francisco
    LA
    21 MGM OR DCSB
    Has anyone had this suspension squeak and found any solutions to stop it? I’ve read around and I’ve found old posts that say that the bushings need some lubrication. There are also other posts that say they’ve tried that and it didn’t work.
    I’m due for my 10k service so I was going to bring it up to them. I only hear it at low speeds (>5) but I can also shake the truck and hear it then. I’ll include a video.
    Thanks in advance. Everything is stock except for cosmetic mods.
    I did go on a camping trip this past weekend about 350 miles round trip, but I was hauling normal gear for camping. I did strap two ice chests onto my Diamondback cover, but nothing out of the ordinary. If that info helps.
    Again, thanks in advance.
    https://youtu.be/lZbIsI1NBIE
  2. Mar 9, 2023 at 7:56 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    I did go on a camping trip this past weekend about 350 miles round trip, but I was hauling normal gear for camping. I did strap two ice chests onto my Diamondback cover, but nothing out of the ordinary. If that info helps. It’s a 2021 Tacoma OR DC SB with 10.5k miles
  3. Mar 9, 2023 at 7:58 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
  4. Mar 9, 2023 at 7:59 PM
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    Does it clunk/bang over speedbumps?
  5. Mar 9, 2023 at 8:01 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    I haven’t gone over any speed bumps since I just noticed it, but I’m sure I heard it when hitting some small pot holes in the street. I’ll also post a video of it squeaking while driving at low speeds.
  6. Mar 9, 2023 at 8:11 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
  7. Mar 9, 2023 at 8:12 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
  8. Mar 9, 2023 at 8:13 PM
    TacomaMike25
    I had an issue with the front end of my truck and it was from bad frame/rad support bushings. This could be bad bushings in the control arms
  9. Mar 9, 2023 at 8:18 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    Were you having similar squeaks?
  10. Mar 9, 2023 at 8:53 PM
    TacomaMike25
    Mine was kind if like that but only over speed bumps. I would have the dealer check the front rad support bushings. They tend to fail early on with these trucks
  11. Mar 9, 2023 at 9:51 PM
    Lhd
    Lhd Active Member
    The OC.
    2021 Tacoma TRDPro Lunar Rock
    I notice mine does it more when the weather is cold and sound like the rear. No fix yet. Comes and goes mine sounds nothing like that.
  12. Mar 9, 2023 at 10:43 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Oh no no. A 10k mile truck that is mostly stock? That should not happen. That is a nasty squeak. Hope you or the dealer find the cause.
    Ricardo13x likes this.
  13. Mar 9, 2023 at 10:58 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
  14. Mar 9, 2023 at 11:08 PM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    Try some WD40 dry lube at your UCA bushings. Also at the LCA bushings.
  15. Mar 9, 2023 at 11:24 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    Ricardo13x[QUOTED] likes this.
  16. Mar 9, 2023 at 11:25 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    Yeah I’m going to give that a try. I’m also going to take it for scheduled maintenance at Toyota, so I’ll ask them about it.
    Ballz[QUOTED] and Ricardo13x like this.
  17. Mar 9, 2023 at 11:45 PM
    Ricardo13x
    Upland, CA.
    Have them do it, Then you mess with it. I have read dealers coming up with bs once they see you tried something. Don’t give them reasons to come up with bs and have you bite the bullet. Cheers!
    Just1n and Superdave1.0 like this.
  18. Mar 9, 2023 at 11:46 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    Thanks! I’ll definitely let them look at it first.
    Ballz likes this.
  19. Mar 10, 2023 at 2:37 AM
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
    That is your front body mounts. Had mine replaced at 7000 miles. Took a couple trips before I was able to convince the dealer that what it was.
    Ballz likes this.
  20. Mar 10, 2023 at 5:46 AM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    I fought this battle too. Switched dealers, replaced both front body mount bushings. One was worn through to metal. Came back in another few thousand miles. Sitting at 60k miles now and it’s really annoying. My wife makes fun of the truck (she has a Jeep so she knows rattles and squeaks). Want to replace myself but read people struggle to get bolts back in if frame shifts. I’m too old for that nonsense, and Toyota refuses to replace again.
