Squeaky lower ball joint driving me crazy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garciav, Apr 10, 2018.
  1. Apr 10, 2018 at 10:42 AM
    garciav
    garciav [OP] Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Hello all
    I pinpointed a squeak to the OEM lower ball joint on the passenger side of my truck and its driving me crazy. Is there any remedial action i can take to get rid of the squeak? I thought I had read a thread on someone finding a way to pump grease or lubricant into the ball joint. tried searching but didn't find much other than the MOOG greasable lbj option as a replacement but i am not ready to replace LCA's just yet.
    Anybody got any ideas or suggestions on how i can lubricate the lbj to make the squeak go away ? the boot isn't torn either to its not spilling grease or anything
  2. Apr 10, 2018 at 10:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Curious how do you know it's the LBJ?
    There's a lot of other moving parts in that area.
    But to your question, I don't think you'll be lubing that particular part.
    garciav[OP] likes this.
  3. Apr 10, 2018 at 10:45 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I'm not sure how to get the squeaking to go away since they are sealed units...but I would definitely check them for play because it might be a sign that they are going bad (or maybe they're just squeaking). Worth checking them though, if they are going bad you'll definitely want to replace them...very dangerous to roll around on bad LBJs
  4. Apr 10, 2018 at 10:51 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    He's second gen, they redesigned the LBJs as to be not so catastrophic when they fail. Still a good idea to replace if its on its way out.
    eon_blue[QUOTED] likes this.
  5. Apr 10, 2018 at 10:54 AM
    garciav
    Houston, TX
    TRD SC,HPTuners
    i bought a cheap mechanic's stethoscope and put it against all the joints while i had a buddy jumping on the side of the truck to articulate the suspension. UCA's, uniball, sway bar links, LCA's, ect... squeak was loudest at the LBJ area
  6. Apr 10, 2018 at 10:54 AM
    eon_blue
    Azusa, CA
    ah yeah I totally knew that but didn't see this was a 2nd gen thread lol...any time I read about LBJ issues I automatically assume it's a 1st gen thread, unfortunately
  7. Apr 10, 2018 at 2:10 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  8. Apr 10, 2018 at 2:17 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Hey Chuy, how is that used? Details please.. Ty
  9. Apr 10, 2018 at 2:40 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    You can but those at Napa too. That's where i got mine. They're a needle with a zerk fitting. Stick it on the grease gun and pierce the boot...
    REDdawn6 likes this.
  10. Apr 10, 2018 at 2:47 PM
    TheRicksta
    TheRicksta Well-Known Member
    Ricksta
    San Diego
    2013 White Tacoma 4x4
    King 2.5 EXT with compression adj/Built Right UCA/Deaver Progressive 3 leaf pack/285 KO2s
    after piercing the boot with that needle, you might want to use some silicone to close the hole
  11. Apr 10, 2018 at 2:57 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I have one but have not used it. Saw some utube videos a while back. The hold should close up after removing the needle, but not a bad idea to use silicone, but will have to clean off the grease real good for it to stick.
  12. Apr 10, 2018 at 3:23 PM
    TheRicksta
    Ricksta
    San Diego
    My LBJ was losing grease so I used that same needle to put more grease. The hole did not seal by itself in my 2013 taco and I lost some grease out of the puncture.
  13. Apr 10, 2018 at 6:51 PM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Hole should seal itself fine unless you overgreased. I've been doing this for years on my jeep
  14. Apr 10, 2018 at 7:57 PM
    garciav
    Houston, TX
    TRD SC,HPTuners
    how do you know when you've added the right amount?
  15. Apr 10, 2018 at 8:37 PM
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
  16. Apr 10, 2018 at 9:30 PM
    badger
    badger Well-Known Member
    07 SR5
    I would use the needle. The hole can be sealed with shoe goo after cleaning the rubber. The automotive shoe goo is best.
  17. Apr 11, 2018 at 7:02 AM
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    You'll see the boot start to buldge a bit then it's time to back off. Sometimes I hit the boot in 2 different places (front and back) to get grease in all around
  18. Apr 11, 2018 at 6:35 PM
    garciav
    Houston, TX
    TRD SC,HPTuners
    where can I find this "automotive shoe goo" stuff ? I ordered the needle and I'm going to take a stab at it this weekend. the squeak is driving me up the F$%& wall...
  19. Apr 11, 2018 at 6:52 PM
    badger
    07 SR5
  20. Apr 11, 2018 at 7:31 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Im just going to start by saying REPLACE THE BALL JOINT!!! if its squeaking and making noise its done no grease metal to metal grinding itself away, the tolerances aren't there anymore it will come loose at some point, it has to be replaced.
    Oreo Cat likes this.
