Squeaking noise in reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by token2k6, Aug 3, 2009.
  1. Aug 3, 2009 at 5:32 PM
    token2k6
    token2k6 [OP] Member
    Houston, TX
    06 PreRunner SR5
    K&N Air Filter Steelcraft Taillight Guards
    Ok, so I've stated before that my truck suffers from the spring-leaf / silencer-pad problem (had it in 4 times, dealer just says they're waiting on new 'prototype pads') Anyways, so just as soon as I accept that squeaking noise as part of my daily routine and life...a horrible new sound pops up.
    The past week, everytime I put the truck in reverse, i starts to squeal in a rotational or revolutionary (sorry I don't know what word I'm looking for) sort of way. I backed all the way down my street, and the more gas I put on, the faster and faster the squeaking would get.
    I think its mainly coming from the rear, my main concern is I might be damaging something on my truck by hesistating to take it to the dealer to be looked at. I just washed it, the leaf spring squeak went away (which is usually the case after a wash) but not this sound.
    Any tips on what part of the truck this might be would be greatly appreciated!
  2. Jul 18, 2010 at 11:39 PM
    doudle d
    doudle d New Member
    Don
    texas
    2006 trd sport crew
    magna flw cat back exhast.aem cold air filter, bak flip tonnue cover
    U joints:mad:
    wilcam47 and Archertl33 like this.
  3. Jul 18, 2010 at 11:44 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Put some grease in your Carrier bearing. I packed it full of grease and stopped it immediately
  4. Jul 19, 2010 at 5:38 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    +1 on u-joints, carrier, lube the slip joint too.
  5. Jul 19, 2010 at 8:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Also....
    If you put on your brakes, does the squeeking stop?
    Cycle your ebrake a few times and perhaps open up the drums to take a look inside. This may or may not have something to do with the drum brakes in reverse & self adjusting,etc.
  6. Jul 19, 2010 at 8:05 AM
    Lentsnh
    Good point, It could also be the brake "reminder" for your drum brakes.
    The OP said it mostly in reverse, though. I guess we will have to wait what he says.
  7. Sep 24, 2012 at 9:53 PM
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    Sorry to dredge up a three year old thread, but the OP's description is exactly what my truck started doing a few weeks ago.
    Truck: 07 PreRunner Access Cab (V6, auto, Off-Road Pkg.), 100,000 mi.
    Making a bad "rotational" squeak from under the truck, only in reverse. Quits doing it every few days (possibly weather/temp-related).
    So, does anyone definitively know what it is? Does the fact that it only squeaks in reverse mean that only one joint is bad? Can I get away with just lubing? I haven't seen any zerks under there.
  8. Sep 24, 2012 at 10:11 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Greaseable U Joints? Dont think prerunners have them, mine didnt at least.
    Its defentally the U Joints tho. Mine started off in reverse then started going full time.
    If not greasable then you'll have to replace them, all of them because the others could fail eventually too. Good news, 3 U Joints are only ~$100 and couple hours labour.
  9. Sep 25, 2012 at 4:52 AM
    memphis guy
    Nashville
    OK, thanks for that.
    So, anyone have a recommendation for a brand that sells greasable U-joints?
    Thinking about going with some of those instead of the sealed Auto Zone units.
    Also, what's the deal on this driveshaft carrier bearing and "slip yoke?" Worth replacing those too while I'm at it?
  10. Sep 25, 2012 at 4:57 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
  11. Sep 26, 2012 at 12:35 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Moog suspension and drivetrain, or factory parts are the best options.
  12. Sep 26, 2012 at 12:38 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Rent a ball joint press from autozone. Use it to press out the u-joints, and save yourself money. Just make sure you mark the shaft so it's phased properly, and don't squish a needle bearing putting them back together.
  13. Apr 20, 2014 at 3:06 PM
    clintron3000
    clintron3000 Member
    clinton
    Missoula, MT
    1998 Toy Taco (2" OME, ARB bump)
    Custom Bumper, Topper, OME 2" leaf, 2" coil, front diff cut out.
    Sorry to once again revive this thread.
    Same issue as above... JUST started last week.
    I got the grease gun out and hit all the zerks.
    Still squeeking in reverse... but only at low speeds, if I really get on it in reverse the squeeking goes away.
    The only thing without a zerk is the carrier bearing. could this be the problem? Or is greasing just not necessarily guaranteed to get rid of the squeek?
    finally... can't I just drive it until it starts doing this going forward? Any risks in just ignoring it until it gets worse?
    mrhappyguy likes this.
  14. Jan 4, 2018 at 5:26 PM
    mrhappyguy
    mrhappyguy New Member
    04 Toyota Tacoma Prerunner 2x4
    K&N, Royal Purple, Toyotec coil over 3" lift.
    Same here, going to change the bearing carrier. I'll let ya know if it works out.
  15. Jun 6, 2018 at 10:21 AM
    m.reed.1
    m.reed.1 Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    And then... did it work? I’m having the same issues
  16. Sep 23, 2020 at 10:45 AM
    luis_cast4
    luis_cast4 New Member
    Luis
    05 Tacoma
    I've come from the future to let you know the squeaking noise is still a thing. My 05 Tacoma just started with this issue, it only squeals when its in reverse mode, if I switch it to Neutral while backing up the noise stops. I'm assuming the U-joints, I'll find out once I replace them.
  17. Apr 16, 2021 at 12:05 PM
    Toyotagang
    Toyotagang Well-Known Member
    Kainoa
    2005 black Toyota Tacoma 4cyl 4x4
    You find out what it was ?
  18. Sep 28, 2021 at 4:36 AM
    POedHandyman
    POedHandyman Member
    Anyone have any luck with the intermittent rhythmic reverse squeak? Started last week on my '10. Tried WD-40 on the u joints and carrier, but still happening.
  19. Sep 28, 2021 at 4:56 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Check this out. U-joints got a warranty extension (Not sure on dates/years). Had my Tacoma done before I got rid of it.
  20. Sep 28, 2021 at 5:39 AM
    POedHandyman
    POedHandyman Member
    Oh wow. This is fantastic. Going straight to a dealer after work today. Thank you so much!
