Squeaking coming from rear diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bambooshoots, Mar 12, 2011.
  1. Mar 12, 2011 at 3:56 PM
    bambooshoots
    bambooshoots [OP] Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    It appears that I have one of the many squeaking problems that Tacomas have. Here's more:
    It's definitely not coming from the engine area. I've replaced the belt and lower idler pulley and most importantly, got another person to listen to it and it's definitely coming from the rear.
    I don't think it's the suspension, as it doesn't happen when I get in or out of the truck and is speed dependent. It squeaks slow when I'm going slow occurs faster/more often the quicker I drive.
    Then it stops when I hit about 20-25mph.
    It also happens whether I'm going absolutely straight or turning left or right.
    It really does sound like it's the differential or possibly the rear part of the driveshaft. I'm not sure which it would be; maybe someone who's had this problem before can chime in.
    If it is the differential, what could it be? Low gear oil? I've changed the gear oil twice in the past, the most recent back in Aug. 2010, and don't see any signs of leakage.
    I don't know anything about the driveshaft. Maybe it just needs some lube? Or is something else shot...?
    Skimonster likes this.
  2. Mar 12, 2011 at 6:05 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    That was a big help.
    Anyways, to the OP, try jacking your truck up and spinning wheels by hand, see if you can hear exactly where the noise is coming from.
    It could be your wheel bearings, diff, driveshaft, or a few other things.
    Also, not sure if the prerunners have the grease nipples on the u-joints under the truck? Could try those as well.
    Good luck!
  3. Mar 12, 2011 at 6:13 PM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
    U-joints usually squeak right before the go bad.
  4. Mar 12, 2011 at 6:14 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Check your U-joints.
  5. Mar 12, 2011 at 6:25 PM
    MwC73
    MwC73 Well-Known Member
    Louisiana
    07 Tacoma 4x4
    5100's,OME 885's
    I had been noticing the same thing with my 07. Climbed under it and found the rear u joint is toast. I greased them regularly,but i guess everything wears out, actually was relieved that was all it was. I was definitely thinking it was the rear diff. I would check them first, they will make for a bad day if they come apart on you.
  6. Mar 12, 2011 at 6:26 PM
    S.B.
    Sean
    San Diego
    15 Taco
    How many miles on it?
  7. Mar 12, 2011 at 6:32 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I vote for the u-joints
  8. Mar 12, 2011 at 6:51 PM
    MwC73
    Louisiana
    07 Tacoma 4x4
    5100's,OME 885's
    Right at 90,000 miles. I am going to try and upload a photo i took Friday at the shop i work at . It was an f-250 with the transfer case held together by the chain inside and the rear driveshaft that had the bolt on yoke. The front u-joint was locked up, DESTROYED the transfercase. Probably one of the craziest things i have ever saw towed in. I work at a transmission shop down here in SE LA. U-joints can cause a lot of carnage--or at the least leave you stranded for awhile.
  9. Mar 12, 2011 at 6:52 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Sounds about right.
  10. Mar 12, 2011 at 10:09 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    6 years and I have zero squeaks.. I didn't know they were riddled with problems? :notsure:
  11. Mar 12, 2011 at 10:48 PM
    anethema
    J
    Dawson Creek,BC
    The U-joints are greasable. If you don't grease them, metal-on-metal will squeak. I wouldn't exactly call that a defect.
  12. Mar 12, 2011 at 10:51 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Only the 4x4s have grease able u-joints.
  13. Mar 12, 2011 at 11:56 PM
    anethema
    J
    Dawson Creek,BC
    Ah I thought the pre-runners having a lot of the off-road oriented stuff might have them as well but looks like no.
    Doesn't rule out the u-joints, but ya, I still say jack up the rear of the truck and try to diagnose it by ear.
  14. Mar 13, 2011 at 8:17 AM
    MwC73
    Louisiana
    07 Tacoma 4x4
    5100's,OME 885's
    No it's not a defect, I kept mine greased though, and they wore out around 90k miles. Nothing lasts forever, especially if you go through a lot of mud, water.... and have it lifted.
  15. Mar 14, 2011 at 12:05 PM
    bambooshoots
    Kevin
    College Station, TX
    Yeah, my truck has 89,000 miles, close enough to 90k.
    After reading through some more threads, and this one: http://www.tacomaworld.com/forum/2nd-gen-tacomas/41248-rear-end-squeak.html you guys are probably right about the U-joints. Unfortunately, Prerunner U-joints are not greaseable, which initially confused me when I crawled under the truck, so new ones have been ordered.
    Hopefully this will solve the problem, pretty embarrassing having a good looking truck squeal like it's a dump truck.
  16. Mar 14, 2011 at 12:07 PM
    bambooshoots
    Kevin
    College Station, TX
    I dunno, but there are quite a bit of of threads on squeaking. Trust me, I tried the SEARCH function before putting up a new thread.
