Squeak only when backing up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingston73, Sep 17, 2010.
  1. Sep 17, 2010 at 6:40 PM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I've got a wheel squeak that I haven't been able to locate. It only happens when I back up, I notice it in the mornings most. I jacked the truck and spun the wheels by hand and couldn't replicate the squeak, and I've driven around a parking lot a bit at slow speeds and it doesn't squeak when going forward. Any ideas welcome, I just don't want something to be worn down to nothing if the squeak is damaging something.
  2. Sep 17, 2010 at 7:11 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    moisture accumulated on the brake pads in the morning maybe?
  3. Sep 17, 2010 at 11:33 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Does this squeek sound like a piece of wire wrapped around something maybe ?
    & does it go away when you get a little road speed going ?
    Just in reverse huh ?
    Any more info would be of help maybe.
  4. Sep 18, 2010 at 5:28 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Only in reverse, closest I can describe it is the sound when brake pads wear but the pads are only a few months old. It sounds like it's coming from the rear. I only notice it when I'm backing out of my driveway.
  5. Sep 18, 2010 at 7:17 AM
    my6
    my6 Well-Known Member
    houston,texas
    04 prerunner 2wd non trd
    check your "U" joints.
  6. Sep 18, 2010 at 7:18 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    have your driveline checked out, particularly the cv joint or (ball and seat) on the rear driveline. i had the same problem about 4 months ago. The squeak would only come when i backed up and i ended up having to replace all u joints, carrier bearing and the ball and seat. but the ball and seat was the part that was making the noise, it was just worn out. how many miles are on your truck?
  7. Sep 18, 2010 at 7:34 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I have about 166,000 on it now. I greased the drive shaft nipples a month or so ago. So you had to replace the entire driveshaft joints? How much did that cost?
  8. Sep 18, 2010 at 7:55 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    labor and parts was about $500, the only thing that was actually bad was the "cv joint" on the rear driveshaft, but i had everything replaced just for peace of mind considering at the time my truck had around 178k. Try something, drive down the road you live on just in first gear, get it up to about 2,000 rpms and let of the throttle, when i did this in mine i would get the ugly squeaky noise
  9. Sep 18, 2010 at 3:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Thats kinda where I was going with the "wire wrapped around something" noise, I would check U joints, get underneath your securely parked truck & with both hands grasp firmly the end of the drive shaft where the U joint sits in the yoke coming off rear diff. Now check for "wiggle" in the joint, if good you should have virtually no movement , back & forth or side to side. If you do, the U joint is bad. Repeat this on all U joints , if they all check out OK then maybe carrier (center) bearing may be the culprit. All these are not a hard Do-it-yourself thing & you'll save a ton of money also..:cool:
  10. Sep 18, 2010 at 5:01 PM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    I've got the same squeak only when I back out of my driveway. I'll check my joints in the morning!!
  11. Sep 18, 2010 at 5:02 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dont go backwards.......:D
  12. Sep 18, 2010 at 5:31 PM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    My truck has been showing the same symptoms lately. I've got 162,000 miles on her, so we're around the same mileage. It's been going on for a while now (maybe 1,000 miles off and on), so I tried a few different things.
    First thing I did was to hose down the underside of the truck with WD 40. Anything that moves got a good dusche, and it went away for a little while.
    After it came back I tried the WD 40 trick again, but to no avail. So I changed out the diff oil, thinking maybe some water seaping into the yolk was the problem. I put a couple hundred miles on her before anything changed. All of a sudden it just quit.
    Tomorrow I'm going to be pulling the yolk apart to replace the front oil seal, which someone suggested to me might have gone bad, thusly making the noise. I'll let you know if that works.
  13. Sep 30, 2010 at 5:09 PM
    mckinneydt
    mckinneydt New Member
    Dustin
    Arlington, TX
    06 PreRunner SR5 TRD Sport
    I have the same issue of squeaking on my 2006 TRD Sport. It's been doing it for about a week and assumed that it was the rear brakes, but I just got through checking and there's still plenty of pad left. As I pulled into the driveway tonight I also noticed what sounded like a popping noise as I was breaking. I took it back out on the road and noticed that it was happening as I was accelerating and decelerating, but not at cruising speed. I checked the U-joints and everything seems really tight. I put it up on jack stands and put it in gear to see if I could replicate the problem. It is definitely coming from the shaft/diff area, but there aren't any visible signs of wear. The truck only has 63000 miles and has been rock solid until this past week. Any ideas other than U joints? The soft suspension mounts and movement when accelerating and stopping makes sense, but the connection seems tight.
  14. Sep 30, 2010 at 10:38 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Does it happen every time you backup, or just the first time you back up after sitting overnight? Try not pressing your brakes while backing up and see if its still there.
    If brakes dont make any difference with the noise, check the things like others have suggested, but if its just brake noise, make sure your shoes are fine, and if they are, you can either get some anti-squeal for them, or just live with it.
  15. Oct 9, 2016 at 11:38 AM
    mandofett
    mandofett Member
    2008 Tacoma double cab V6
    I am having this same issue. A squeak squeak sound when I back up. Just got replacing a bad u joint at trsnsmission. I thought that was the culprit but squeak is still there. I checked the other u joints and they are tight. No play at all. No grease lines either. The squeak started a week ago after I left a friends house. They live on a hill so my truck was parked at an odd angle and I used the ebrake. Could it be the rear brakes?
  16. Oct 9, 2016 at 11:38 AM
    mandofett
    mandofett Member
    Mileage is around 165000 I think.
  17. Oct 9, 2016 at 11:42 AM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    put more grease in, you may not have put enough in the first time AND they may have been bone dry anyways.
    open your drums and clean your hardware while it's connected. brake dust on certain parts can squeak. or just spray some silicon grease or graphite on your hardware and between the backing plate and the shoes. don't put anything on the brake lining!
  18. Oct 9, 2016 at 11:50 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    sounds like u-joints to me, regrease them until you see grease come out of "all" the caps, not just one or two.
    also chock front wheels, jack both rear wheels off ground and secure on jack stands for safety, put truck in neutral, turn back wheels backwards by hand and this will allow the u-joints to turn while you check for looseness or squeaks
