Squatting A 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JiggaTrix, Feb 17, 2019.
  1. Feb 17, 2019 at 11:08 PM
    JiggaTrix
    JiggaTrix [OP] Well-Known Member
    David
    North Carolina
    2009 Red Tacoma
    6in Pro Comp Lift 3in Body Lift 35x13.50s AMP Mud Attack’s 24x14 Xtreme Forces
    So I own a 2009 Tacoma. It’s currently sitting on 9” of lift. 6” suspension lift and a 3” body lift. My question is I want my truck to squat and I’m wondering how I get the rear end to sit lower.
    I tried taking out the lift block which we’re about 3” so the truck squatted a little but not much. The next thing I did was I left the blocks out and also took out my added leaf spring and put Chevy drop shackles in. After finishing that I took the truck out for a spin but the ride is extremely rough. It’s almost unbearable. So the next chance I get I’ll be putting the stock shackles back in. I would really appreciate any ideas on how to squat my truck but not make it ride like a wooden roller coaster going down the road.
    PS. It’s a “2009 Tacoma Prerunner”
  2. Feb 17, 2019 at 11:09 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Question, why do you want a bro lean?
  3. Feb 17, 2019 at 11:10 PM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Take out the body lift and 6 inch “suspension lift” then buy a real suspension lift. Problem solved.
    TXpro4X4, rmepilot, ace96 and 5 others like this.
  4. Feb 18, 2019 at 12:51 AM
    JiggaTrix
    David
    North Carolina
    2009 Red Tacoma
    whatstcp[QUOTED] likes this.
  5. Feb 18, 2019 at 12:52 AM
    JiggaTrix
    David
    North Carolina
    2009 Red Tacoma
    Lol where I’m from it’s called the “Carolina Squat” and because it’s a show truck.
    R490, frenchsquared and Bebop[QUOTED] like this.
  6. Feb 18, 2019 at 12:55 AM
    Bebop
    Nick
    Throw about 500 pounds of sandbags in the bed, that will make it squat
  7. Feb 18, 2019 at 12:59 AM
    JiggaTrix
    David
    North Carolina
    2009 Red Tacoma
  8. Feb 18, 2019 at 1:08 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Is this what you’re going for? You can get that by removing the added lifting components from the rear so all that’s back there is the original stock leaf pack.
    TXpro4X4 and inwood customs like this.
  9. Feb 18, 2019 at 1:14 AM
    JiggaTrix
    David
    North Carolina
    2009 Red Tacoma
    So your saying leave the lift blocks out, take out the added leaf, and keep the stock shackles, along with putting the stock shocks back in the rear.
    BassAckwards and whatstcp like this.
  10. Feb 18, 2019 at 1:22 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Yes.
  11. Feb 18, 2019 at 1:25 AM
    JiggaTrix
    David
    North Carolina
    2009 Red Tacoma
    The only thing with that is the truck is still going to ride stiff. Correct?
  12. Feb 18, 2019 at 1:29 AM
    PK808
    PK808 Well-Known Member
    Payton
    Hawaii
    2009 Tacoma MGM SR5 4x4 S/C (SOLD in 2020), 2020 T4R NB Venture 4x4
    What provides the lift up front? Strut spacer or extended coilover assembly? The extended assembly will provide a much better ride. That or I’ve seen some people use the extended Bilstein 5100 that comes with the RCD lift and pair it eibachs for additional lift. I believe that combo provides more than 6” which might help you get the lean if you then ditched a part of your rear lift.
  13. Feb 18, 2019 at 1:31 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Maybe? The stock rear isn't stiff but I don't know how much it will be affected by having the front of the truck all jacked up.
  14. Feb 18, 2019 at 1:34 AM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    I don't get this shit and I'm from South Carolina.
  15. Feb 18, 2019 at 1:35 AM
    JiggaTrix
    David
    North Carolina
    2009 Red Tacoma
    I have coil overs in the front. So before I took out the added leaf and also tried to add drop shackles the ride wasn’t stiff at all it rode very smooth. But after taking out the added leaf and trying Chevy drop shackles it rises like s**t. I know I can just take the lift out of the back.. but then. My tires will rub.. and that’s not what I want.
  16. Feb 18, 2019 at 1:37 AM
    JiggaTrix
    David
    North Carolina
    2009 Red Tacoma
    SC is trying to pass a law to ban squatted trucks . But I’ll be down there in March for the show.. and I hope they write me a ticket
  17. Feb 18, 2019 at 1:38 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Takes some good pics and post the of your set up so we can see visual what your working with
    whatstcp likes this.
  18. Feb 18, 2019 at 1:40 AM
    PK808
    Payton
    Hawaii
    You could try the RCD billy 5100 combo with an aftermarket coil to further lift your front. That will give more than the extended coil over you have that provides 6”. Then you wouldn’t have to touch the back. Not sure how much higher you want it in the front over the back though.
  19. Feb 18, 2019 at 1:42 AM
    easleycrawler
    Travis
    2014 RC Taco 4wd
    I hope they do pass it. Hell, there are a few Silverado's around that have done this shit and they have the tailgate half way down.
  20. Feb 18, 2019 at 2:01 AM
    Muddinfun
    Muddinfun Well-Known Member
    Your rear shocks are too long and are bottomed out.
