Spyder LED tail lights may be causing an issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mr Lazi Dazi, May 10, 2021.
  1. May 10, 2021 at 3:06 PM
    Mr Lazi Dazi
    Mr Lazi Dazi [OP] Lazy Daze
    2021 Tacoma TRD Sport
    MBRP 3” Muff, LED Smoke Tail Lights, 4” Spindle Lift soon
    Hi all, I just replaced my tail lights this weekend with a new LED version but now I am getting a code that says brake and accelerator are being pressed at the same time and the thing completely loses all power. There’s no way I am pressing both at the same time so the thought is that it has something to do with the tail lights which makes zero since but that’s all I did. This is a brand new truck 2021’ with less than 1000 miles so before I take it back to the dealer I wanted ask on this forum to see if it’s something simple that I can handle. Thanks in advance for your help!
  2. May 10, 2021 at 3:12 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    How often is this code occurring?
    Swap the taillights with OEM and see if the issue goes away.
    Definitely swap them out before going to the dealership, especially if you think they're suspect. I doubt the taillights are causing the issue but I suppose noise could be the culprit.
    caribe makaira likes this.
  3. May 10, 2021 at 3:18 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I would check the grounding of the taillight circuit.
  4. May 10, 2021 at 4:55 PM
    Mr Lazi Dazi
    Appreciate the response, I tried driving it with the original lights back in there and it worked fine so I know it’s the aftermarket lights. Funny thing is if I turn off drl or headlights it works fine but if I start it up with drl or the headlights and try to accelerate that’s when I get the warning light. I mean it completely loses power even when I push the pedal to the floor.
  5. May 10, 2021 at 4:57 PM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    I would return those lights and get something else. ASAP.
    gsubioguy, Chew, Aqualoon and 2 others like this.
  6. May 10, 2021 at 5:06 PM
    DogStar84
    DogStar84 Well-Known Member
    Northern California
    2021 Off-Road MGM
    AllPro Apex Rock Sliders SSO Slimline Front Bumper Baja Design lite bar 20" Baja Design Squadron SAE fog lites Mountain Hatch Tailgate Rek Gen mud flaps
    I replaced all with , i think, “dynamic diode”. Gave me an electrical problem so went back to oem on JUST the turn signals. All better. 21’ as well.
    I found a fix on a forum and manufacturers website sold a fix. But i didn't try it.
    I really only need the brighter back up lights.
    Switch around the leds to see which one is causing issue (brake, backup, turn, license). Then just oem the problem child
  7. May 10, 2021 at 5:14 PM
    Catfish21
    Stockton, Ca.
    Winjet tails were pretty good. I’ve had mine on for 4 years now. 0727CEBC-1C05-4E44-9153-D9BBB928879F.jpg
  8. May 10, 2021 at 5:14 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    It loses power due to the brake-throttle override feature all Toyota's have in response to the whole unintended acceleration thing. Somehow those lights are causing a false brake pedal pressed input and activating the override function.
    HisDad likes this.
  9. May 10, 2021 at 5:30 PM
    Mr Lazi Dazi
  10. May 10, 2021 at 6:05 PM
    HisDad
    Texas at last
    Whenever I see or hear about a weird electrical problem my first thought is that there is a loose ground somewhere. The fact that you swapped the OEM taillights back in reinforces that. An open ground somewhere will cause weird stuff as the circuit tries to complete it self by finding a ground.
    Back when I repaired ambulance electrical systems any time a crew reported something like the siren came on when they used the windshield wipers, I'd start looking for the open ground.
    gsubioguy, Darrell942 and DogStar84 like this.
  11. May 10, 2021 at 6:45 PM
    DogStar84
    Northern California
    2021 Off-Road MGM
    That makes sense. So try swapping back to oem just the brake lite but keep the rest led.
  12. May 11, 2021 at 12:08 PM
    DBCoop
    DBCoop Member
    Alabama
    2017 TRD PRO Cement
    I recently installed the spyder led tail lights on my 17 pro and haven't had any issues.
  13. May 11, 2021 at 2:56 PM
    mr.rick
    mr.rick Well-Known Member
    Rick
    2021 Voodoo Blue TRDOR
    I had a similar issue years ago on my 1999 4Runner, I had replaced the 3rd brake light with a spyder LED product and oddly enough I was getting a brake light warning on my dash (there was not enough tech to put the vehicle in limp mode but it was still triggering the brake system). The problem was that the LED did not have enough resistance for the system and the truck thought I had a bulb burned out, so it was lighting up the brake system warning. I had to wire a stronger resistor in and it completely fixed the issue. But on a brand new truck if the lights are messing with the truck and causing it to go into limp mode I would return them and get my money back because that is indicative of them probably not lasting very long anyway and then you're out the money and can't return them.
    gsubioguy likes this.
  14. May 11, 2021 at 3:01 PM
    Fpc187
    Fpc187 Well-Known Member
    I’ve been running spyder LEDs for about 2months now without any issues. Maybe you received a bad/faulty set..???
    DBCoop likes this.
  15. May 11, 2021 at 3:03 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Spyder is ja-hunk
  16. Jun 8, 2021 at 8:30 PM
    tjaved22
    tjaved22 Well-Known Member
    What are the most reliable aftermarket tail lights?
  17. Jun 8, 2021 at 8:46 PM
    Komurphy
    Komurphy Well-Known Member
    Kory
    2020 Magnetic Gray SR5
    MESO stage 1 taillight conversion hands down.
