Spray Painting Coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MolonLabeTaco, May 2, 2018.
  1. May 2, 2018 at 9:32 AM
    MolonLabeTaco
    MolonLabeTaco [OP] Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    If you have successfully spray painted your coil springs, what was the process & what spray paint did you use?
    I ordered some blue King's & want to paint them white. I will NOT pay to have the powder coated so let's keep this to people who have successfully painted theirs w/spray can paint.
    Thanks!
  2. May 2, 2018 at 2:02 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Guessing you're not doing this yourself or you wouldn't be asking. Canned spray paint is not designed to flex and will flake off pretty quickly. Either plasti-dip them or take them to a body shop where they can add a flex agent to the paint.
  3. May 2, 2018 at 2:54 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Yes I'm doing it myself, that's why I'm asking!
    I've read where others have had success using spray paint but the brand and process were discussed in length.
    Thanks.
  4. May 2, 2018 at 3:04 PM
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    If you just want to make them not blue (King) and will settle for either black or silver, Eibach sells 650 and 700 lb 14 inch coils.
  5. May 2, 2018 at 3:09 PM
    badger
    badger Well-Known Member
    07 SR5
    Krylon Fusion. Powdercoat is essentially plastic, so a plastic compatible paint is best. If you want THE best, get this: https://www.semproducts.com/product/vinyl-coattm
    SEM products are awesome, and luckily you are in Texas. Unless things have changed, they can't ship to California.
    MolonLabeTaco[OP] likes this.
  6. May 2, 2018 at 3:11 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I ordered a used set of Kings for $100 delivered to see if they fit my needs.
  7. May 2, 2018 at 3:13 PM
    cmbondo
    San Diego CA
    Good deal.
  8. May 2, 2018 at 3:36 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    The one you linked isn't for metal but they have another flexible paint product that is. Supposedly there's a distributor about 5 miles from my house so I'll go check it out. Thanks!
  9. May 2, 2018 at 4:07 PM
    badger
    07 SR5
    Unless you are stripping the powder coat off, I would use the stuff I linked. Powdercoat is plastic beads that are held on by electrostatic force and then melted into a solid sheet. Of course, yea, bare metal is another deal. I've been using SEM products since the 70's, if you can believe that. It will perform just as they claim it will.
  10. May 2, 2018 at 4:51 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    The PC on the coils has some flakes so I was going to sand them some. Your thoughts on that? Thanks.
  11. May 2, 2018 at 5:40 PM
    badger
    07 SR5
    If the stuff is flaking, then get it off and start from bare metal. Flaking means rust can live underneath. If is just chipped, then surface sand it, and touch up the chips if you can with primer. Then spray it
  12. May 3, 2018 at 12:25 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Use Cerakote,the best stuff you can get.
  13. May 3, 2018 at 12:36 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Good deal on the coils lol. I painted my sons coils on his first gen with high temp paint (exhaust manifold paint) . IIlet the cure aafew days and the I baked them at 200 for 20 min . Did the same with some eibach's that looked rough. Just did the same with some 600 king's blue to black . No chips or cracking .
