SPLIT CV REPAIR BOOT?
Discussion in '1st Gen. Tacomas (1995-2004)' started by POLISHTACO, Jun 15, 2021.
  1. Jun 15, 2021 at 4:21 PM
    POLISHTACO
    POLISHTACO [OP] Well-Known Member
    Frank
    Connecticut
    2002 Tacoma sr5,2.7,manual,4x4
    I have a small tear on my drivers side cv boot.Are any of those split repair boots any good? I see the Dorman split boot that is glued together and the other that is hinged on one side and bolted together on the other side. I drive less than 3,000 miles a year and don't do any off roading any more. Will one work for me or will I be wasting my time? Thanks for any input.
  2. Jun 15, 2021 at 4:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I wouldn't even bother fixing it. I drove 275,000 miles with a torn boot. It never failed.
  3. Jun 15, 2021 at 4:49 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Best is to rebuild them with actual boots. Anything else is just a bandaid fix. It takes a little bit of time, but it's not that hard. Plenty of videos out there. If you can turn a wrench or two, it's totally doable.
    Depending on WHY your boot is cracked, will depend on the type of boot yo should get. If you have a lift, it's likely that your boots are getting over extended and you should get some high angle boots. If it's just normal wear and tear, OEM style is more than sufficient.
    I would definitely advise against just ignoring it for 275,000 miles, especially if you take it off road. There's nothing worse than being "that guy" who breaks down on the trail because you ignored maintenance. If you just drive on the highway in 2wd 99% of the time, sure, who cares...
    In fact, if you go off-roading a fair amount, I'd buy a new pair of CVs, install those now, and rebuild your old ones at your leisure, and take them on the trail for spares.
    SR-71A and turbodb like this.
  4. Jun 15, 2021 at 5:00 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I wouldn't use a patch kit. A new OEM boot kit isn't that expensive and will generally last a really long time - even longer than some of the "high angle" boots that are supposed to be better.
    Here are all the parts and tools needed, as well as photos and a description of the whole process:
    How-to: Rebooting a Tacoma CV Axle
    ArizonaComa, Jase, KStateTaco and 2 others like this.
  5. Jun 16, 2021 at 5:40 AM
    POLISHTACO
    Frank
    Connecticut
    I have bilsteins all around the fronts are the next to the highest adjustment,so that would be less than a 2" lift. Do you think stock boots would be ok?
  6. Jun 16, 2021 at 5:41 AM
    POLISHTACO
    Frank
    Connecticut
    Thanks for all the information Dan !
    turbodb[QUOTED] likes this.
  7. Jun 16, 2021 at 6:15 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    At a 2" lift, the OEM boots will be fine. (Well, new ones with fresh rubber.)
    :thumbsup:
  8. Jun 16, 2021 at 6:21 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I used a split boot on my beater. It lasted a few years, longer than the transmission.
  9. Jun 16, 2021 at 8:05 AM
    jbrandt
    Justin
    You should be fine, yeah.
  10. Jun 16, 2021 at 10:53 AM
    POLISHTACO
    Frank
    Connecticut
    :thumbsup:
  11. Jun 16, 2021 at 11:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Surprised you didn't subject the OP to your usual blasphemy :luvya:
  12. Jun 16, 2021 at 12:23 PM
    jbrandt
    Justin
    I must be slipping in my old age.
    Kwikvette[QUOTED] likes this.
  13. Jun 16, 2021 at 1:23 PM
    jbrandt
    Justin
    @Kwikvette if I'm being honest, I was hoping you'd like that post, then I'd go back and edit it.
    :devil:
  14. Jun 25, 2021 at 5:21 PM
    POLISHTACO
    Frank
    Connecticut
    DSCN4583.jpg DSCN4578.jpg I decided to do the oem boot kit because my 02 Tacoma only has 100k on it. To buy me some time I put some gasket maker on it to seal up the small tear,about 1.5" long. No leaks so far after a week. I just have a lot of other things going on right now
    bramezy and ArizonaComa like this.
  15. Jul 5, 2023 at 2:18 PM
    Suckafartout
    Suckafartout Well-Known Member
    2008 Tacoma trd sc
    Supercharged
    Nuce fix!
