Split belt, battery light came on while on freeway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bosa, Apr 13, 2021.
  1. Apr 13, 2021 at 6:51 AM
    bosa
    bosa [OP] Well-Known Member
    06 4x4 Radiant Red Taco
    So while doing 50mph the battery light came on, right before I got home I lost power. ALL the dash lights came on and the radio went out. Recharged the battery and got it running again, took a closer look and the belt is split. Alternator seems to be putting out 13.5v when things are running. Battery seems to be holding the charge now. Idle is rough and drops right down while in gear.
    Truck is an 06 with 250,000miles.
    What do you think it is?
  2. Apr 13, 2021 at 6:56 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    A split belt? Did the belt take out anything? I had one fail on an old Ranger, took out $1000 worth of AC components... :mad:
  3. Apr 13, 2021 at 6:57 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    A serpentine belt well past its replacement life appears to be the cause.
    Suggest to replace the serpentine belt.
  4. Apr 13, 2021 at 7:15 AM
    bosa
    eek. Naw, it just as a slight split down a portion of the belt. Didn't fly off or anything.
  5. Apr 13, 2021 at 7:17 AM
    tirediron
    Replace the belt to start with.
  6. Apr 13, 2021 at 7:39 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I had the same issue happen to me on my old Audi S4. Was driving home from Palm Springs to San Diego... on the way home the battery light comes on. I keep driving, like an idiot. Eventually the car just dies completely. I have it towed to the nearest dealer. The belt failed which caused the tensioner and pulley to fail. Luckily it was all under warranty but nothing else was an issue. Replaced and good to go. Kept the same battery even.
    Sounds like you just need to replace the belt and check your pulleys.
  7. Apr 13, 2021 at 7:53 AM
    bosa
    Yeah I will test spin all the pulleys once I get the belt off
  8. Apr 14, 2021 at 1:57 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Replace that belt. For $40 its worth it...this was at 90k D3D4E786-9C2A-45E0-A798-973FAC0DA08E.jpg
    Key-Rei likes this.
  9. Apr 14, 2021 at 12:32 PM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    If the belt isn't holding, it won't charge the alternator and the whole thing will die. I had mine snap due to a bad pulley and had the same symptoms. Did it overheat? That belt also controls the water pump.
    Remove the belt, check all the pulleys, put a new belt on. It's surprisingly easy, you literally need 1 wrench and a drill bit or something (To hold the tensioner)
