Spinning noise when driving slow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackson317, May 7, 2021.
  1. May 7, 2021 at 11:16 AM
    jackson317
    jackson317 [OP] New Member
    Jackson
    2015 Tacoma v6
    Whenever I slow down or drive under 30mph I can hear a weird spinning or rotating noise coming from in front of me. It kinda sounds like I have a flat tire or something is rubbing against something else. It stops when I go faster and I can’t feel anything while I’m driving. It just makes the noise. It’s a second gen. Any suggestions?
  2. May 7, 2021 at 11:18 AM
    matthardy129
    matthardy129 Member
    2007 DCSB 4X4 TRD Sport Silver
    2019 Tacoma wheels
    Sounds like a bad wheel bearing
    igno1tus and wi_taco like this.
  3. May 7, 2021 at 11:49 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  4. May 7, 2021 at 12:33 PM
    jackson317
    Jackson
    2015 Tacoma v6
    It doesn’t shake like that when i jack it up
  5. May 7, 2021 at 12:37 PM
    wi_taco
    Adam
    SE Wisconsin
    Did you check both sides? Did you spin the front wheels when it was jacked up and did they make noise (like 3:15 mark in that video)? Still could be a bearing but might be something else too. Maybe check if the dust shields on the back side of your brake rotors isn't contacting the brake surface, and also check that your brake pads aren't dragging?
  6. May 7, 2021 at 12:42 PM
    jackson317
    Jackson
    2015 Tacoma v6
    I spun them both and they didn’t sound like the video. I’ll check the brakes.
  7. May 7, 2021 at 1:31 PM
    jackson317
    Jackson
    2015 Tacoma v6
    Went to check the brakes and realized one of the lug nuts was loose. Tightened all of them and there’s no noise now. Guess I got lucky it wasn’t anything major.
  8. May 7, 2021 at 1:32 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Is it a rotational squeaking noise that speeds up as you do until you can no longer hear it? Could be universal joints on the driveshaft if so
  9. May 7, 2021 at 1:32 PM
    BassAckwards
    Welcome aboard
  10. May 28, 2021 at 5:19 PM
    LMC
    LMC Well-Known Member
    2015 Black Tacoma TRD Sport
    Hey my truck has been making this weird almost rubbing grinding noise when turning and when slowing down. I took it to toyota thinking it was a wheel bearing but everything checked out to be normal . Any idea what this could be since they couldn't find anything wrong with it
  11. May 28, 2021 at 5:32 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    That sure sounds like a wheel bearing. Be easier to tell though if you could post a video of it.
    Could be the brake shield rubbing the rotor or something else stuck down there rubbing it
  12. May 28, 2021 at 5:56 PM
    LMC
    Yeah its super weird . I know it has to be something
    I'll try to figure out how to post the video i made. It was giving me an error when I tried before
  13. May 28, 2021 at 5:58 PM
    eon_blue
    Azusa, CA
    Can't post videos directly to the site like you can with photos, videos have to be uploaded to a video hosting site like YouTube or Vimeo then post the link on here
    Gen3TacomaOBX likes this.
  14. May 28, 2021 at 5:59 PM
    LMC
    Ohhh okay cool thanks ! I have a YouTube channel I'll post it there and then add the link
    Thanks !
    eon_blue[QUOTED] likes this.
  15. May 29, 2021 at 6:53 AM
    LMC
    Here's the link. It's hard to hear with wind but the sound Is still there
    https://youtu.be/P74QaT5cxO4
  16. May 29, 2021 at 7:04 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    It's difficult to tell there's noise other than the wind in your video. Perhaps since you're hearing the grinding noise in person you can distinguish between the noises in the video.
    Sure you're tires aren't rubbing anything?
  17. May 29, 2021 at 7:11 AM
    LMC
    I can try to get a better video today
    Yeah nothing is rubbing from what i can see. I've had this tire setup for 3 years and it's been fine till lately. I'll look into it more
    Thanks for the help appreciate it
  18. May 29, 2021 at 7:13 AM
    Gen3TacomaOBX
    S
    Cool. Perhaps a video where the camera is sheltered from the wind would do it.
    3 years for the tire setup but don't you have a new bumper install?
  19. May 29, 2021 at 7:18 AM
    LMC
    I've been running this tire set up for 3 years now and have had no issues, till now . I recently installed a cbi bumper but they sent me the wrong year for my truck if that's what your talking about
  20. May 29, 2021 at 7:21 AM
    Gen3TacomaOBX
    S
    Yes, just trying to rule out any new issue that may have been introduced. I'm asking whether the new bumper supports or wings can come in contact with the tire when driving under any circumstance.
