Spilled gear oil in bed. How to remove?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taylor, Feb 4, 2014.
  1. Feb 4, 2014 at 3:10 PM
    Taylor
    Taylor [OP] Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Hey guys! I was changing my diff oil out when my buddy called me needed a jump. I finished up and threw the drain jug in the bed. Didn't think about it.
    It turned over and spilled everywhere coating my entire bed with 1/2 an inch of oil. I spent like 20 minutes pressure washing it and it just won't come out.
    I can't stand the smell. You can smell it from like 10 feet away from my truck and it's a mess. I can't put anything back there now.
    What the hell will get rid of it? I can't use water because water just rolls off of the oil and it's like glued to my bedliner.
  2. Feb 4, 2014 at 3:13 PM
    Juan Solo
    Juan Solo Well-Known Member
    Johnny
    Houston
    2014 4x4
    Water is useless on any oil base. You might try a degreasing solvent or a crap-load of brake cleaner.
  3. Feb 4, 2014 at 3:15 PM
    Rickoutdoors
    Rickoutdoors Well-Known Member
    Richard
    Montreal,Qc,Canada
    heated mirrors, lighted cup holders, backup lights, backflip cover, box lights, raised diff breather, solenoid tailgate lock, flashlight holder,
    Try brake cleaner.
  4. Feb 4, 2014 at 3:22 PM
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    That'll take a lot of brake cleaner! Start with a strong degreaser - even simple green. Soak & scrub with a broom and rinse well. It'll probably take several tries to get it done. Try and use hot water if you can.
  5. Feb 4, 2014 at 3:24 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    X2 simple green that usually works best
  6. Feb 4, 2014 at 3:26 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    lol! Good luck man, Brake Clean is a safe bet and lots of it.
    I have to be honest though, I thought you meant your BED, as in where you sleep. I thought to myself "WTF was he doing with Gear Oil in bed...lotion man! Lotion!" :rofl:
  7. Feb 4, 2014 at 3:28 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Do not use brake clean, that'll eat off paint and bedliner. Just soak it with some purple power and hit it with hot water. First I'd get some powder absorbent stuff at a parts store to get most of it out.
    burntkat likes this.
  8. Feb 4, 2014 at 3:29 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    WHOA, slow down a minute....that bedliner sprayed or a drop-in ???
    Either way You might try speedi-dry ;1) take that smell away quickly 2) once it gets most of it dried up enough to sweep the actual last cleansing will be cheaper...3) DO NOT drive around 1/2 a$$ed with that speedi-dry cloud having fun..:rolleyes:..the longer it sits the more it will absorb...
    Just an Old Mans way of looking at things...:cool:
    GOOD LUCK and hopefully the "Friend" can help...;)
  9. Feb 4, 2014 at 4:39 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Exact samething I thought at first :rofl:
  10. Feb 4, 2014 at 4:52 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    What about some engine degreaser. I like the simple green idea also.
  11. Feb 4, 2014 at 4:57 PM
    Pagan
    Pagan Active Member
    Bill
    27°51' N, 082°17' W
    2013 PreRunner SR5, XSP-X DCSB V6
    Dawn dishwashing soap is a wonderful product.
  12. Feb 4, 2014 at 5:01 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I'll look into Simple green.
    Also, I also have some in my actual bed. I mean... it reduces friction, right? :notsure:
  13. Feb 4, 2014 at 5:02 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Drop in, haha.
  14. Feb 4, 2014 at 5:14 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    x2 Dawn kicks butt
  15. Feb 4, 2014 at 5:22 PM
    bamufflers
    bamufflers Active Member
    Keith
    Escondido
    03 SR5
    DirtyDeedsIndustries long travel, King coil overs with King bypass up front. 3X16 triple bypass kings out back to dampen the Deaver SUA pack. Long tube headers with full race exhaust system. Too much to list.
    The cleaning section in Home Depot has zep floor cleaner. This is a very high ph alkaline soap. Should cut right thru the gear oil and won't damage paint or bed liner.
  16. Feb 4, 2014 at 5:27 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    10 cans of brake clean mindlessly sprayed at offending area :anonymous:
  17. Feb 4, 2014 at 5:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Starting fluid from walmart is a great and cheap degreaser. 10 cans at $.99 each. It even takes grease spots out of the concrete on the driveway.
  18. Feb 4, 2014 at 5:38 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    kitty litter to soak it up then a good degreaser dawn works well
  19. Feb 4, 2014 at 5:42 PM
    98 Taco Max
    98 Taco Max Well-Known Member
    Max
    Calgary, AB
    v6 Tacoma 4x4
    cat litter is cheap and good for soaking up big oil puddles, i use it on the garage floor sometimes haha.. for the rest i'd get a big container of engine degreaser/simple green type stuff, something you can buy in bulk. aerosol cans of brake cleaner works good but will get realllly expensive for an entire truck bed!
    edit: ah whopper beat me to the kitty litter haha
  20. Feb 4, 2014 at 5:45 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Dish soap and then simple green. Both you can wash down the drain
