Speedometer stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smurf yeahh, Jan 16, 2013.
  1. Jan 16, 2013 at 10:57 AM
    smurf yeahh
    smurf yeahh [OP] New Member
    Josh
    Utah
    Base 4x4. double cab. off road
    2.5 lift. 33' tires flowmaster exhaust
    Hey guys,
    my speedometer stopped working the other day (temperatures have been 20 degrees and colder). everything else works on the cluster besides the speedometer stays at 0 the whole time I drive...
    there is no check engine lights on or anything? I was told that when it gets this cold the the Speed sensor on the tacomas can freeze and not work where its located.. is this true? or what do you think my problem is?
  2. Jan 16, 2013 at 12:12 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    Been in -30 or so with my Taco and the speedo has been fine on mine. Truck was orginally from Arizona so it didn't see much cold until I bought it.
    Could be the cold but I think there is another issue here :( I know that my old trucks had a speedometer cable on the back of the instrument cluster that came loose and caused it to stop working. I haven't taken out my taco's cluster to see how it is all hooked up yet.
    I hope someone can offer some more insight.
  3. Jan 16, 2013 at 12:48 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    there wont be a cable like older trucks. hard to tell. could be many things and im sure cold weather doesnt help none.
  4. Jan 16, 2013 at 12:51 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Check a fuse, i know the same thing happened to a jeep my buddy got to use as a off road beater and it was a blown fuse. at least start with checking fuses, than if you check ALL of them and it’s still nor working, may try finding out what els it could be.:
    :edit i know jeeps are not taco’s but it’s a really easy starting place, and thats all that really counts.
  5. Jan 16, 2013 at 12:59 PM
    98tacoma27
    Ben
    Not Beech Creek
    The speedo sensor should be sticking out on the driverside (IIRC) towards the tailshaft of the tranny.
  6. Jan 16, 2013 at 1:02 PM
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    I've had this happen to mine when it gets cold, too. The only thing I can guess is the electric motors moving the needles get into some type of bind. I've had it happen with both my speedometer and tachometer.
    Remove the dash and the protective cover from the gauge panel. It sounds like a job, but it's really not as bad as it sounds. It takes 10-15 minutes with a basic socket set and phillips head.
    Once you have the gauges exposed, cycle the needle around a little with your finger. Yes, physically move the needle around. You won't damage anything. I always unplug my gauge cluster for good measure. It's easy to do, there are two plugs behind the cluster. Unbolt the cluster for easier access.
    Once you've plugged everything back in and put the needles back to 0, go for a little drive an make sure everything works before you put your dash back on. I had to do it twice once. Once everything's working, put you dash back together.
    Hope this fixes it! It's always worked for me. Good luck!
    ijonahtacoma likes this.
  7. Jan 16, 2013 at 1:17 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    I wouldn't move the needles with your finger, you can throw it out of calibration. Make that your last resort.
  8. Jan 16, 2013 at 7:36 PM
    NMW 4x4
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    I've done it multiple times with no negative results - Ultragauge confirmed.
  9. Jan 17, 2013 at 1:50 PM
    smurf yeahh
    Josh
    Utah
    so today the speedometer worked again as i drove to work.. but then at lunch no longer was working.. but it sounds like i can hear like a little buzzing noise on the cluster when i turn on the truck. but then the speedo doesn't work.
    anyone ever had this problem? or know what it is?
  10. Jan 17, 2013 at 2:24 PM
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    On the bright side, it'll be a low mileage Tacoma if you sell it. ;)
  11. Jun 24, 2015 at 2:01 PM
    Beach bum
    Beach bum New Member
    2002prerunner
    Forget the speedo sensor, inside the sensor is a shaft3" long with a plastic gear on the end. The gear is the problem, they wear down and won't engage with matching gear in your tranny. Good luck finding a replacement.
    To check pop sensor out ( one bolt ) usually the shaft and gear come out with it, if not it right there, neddle nose and out it comes. Check the gear, you'll probably find it to be well worn.
  12. Mar 25, 2025 at 12:55 PM
    GGaytan
    GGaytan New Member
    Having issues with the speedometer sensor nylon gear (33482-59015 marked 6:17) wearing out on my 99 Tacoma 3.4L with auto tranny floor shift. Replaced the gear with a new one from Toyota and it lasted 4k miles and wore out as well. Talked to service manager at local Toyota dealership and he insists there is something wrong with the speedo door gear (gave me part number 33481-14020 but I think its 33481-35111)inside the tranny that is causing the nylon gear to wear out prematurely. Has anyone encountered this problem?
