Speedometer, radio, blinkers, wipers not working. Now won’t start.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Soupguy, Jun 19, 2023.
  1. Jun 19, 2023 at 12:14 PM
    Soupguy
    Soupguy [OP] Member
    2006 Toyota Tacoma 4cyl 2wd 5spd
    Hoping someone can help me figure this one out. Got in my Tacoma started up normally and drove fine. When I got on the highway I noticed that my speedometer wasn’t working along with the radio, blinkers, wipers, air, and cigarette lighter port. Tachometer, gas and oil gauges worked though. I parked and checked some interior fuses, nothing looked blown and then it would not start. No noise or movement in the engine bay whatsoever and no attempt to crank over. The battery is fine I cleaned the terminals, all the fuses seem fine and I replaced a few relevant ones. I checked the clutch safety switch and the reverse lamp switch, both seem fine. Any idea where I should look next? Thank you in advance!
    -soup
  2. Jun 19, 2023 at 12:21 PM
    Madd Matt
    Madd Matt Well-Known Member
    Between the Brandywines S.E. Penna.
    2015 Blue Tacoma TRD Sport 4.0 6 speed manual
    Welcome aboard, what is the voltage checked at the battery? Kinda sounds like a failed alternator, battery discharging as you drove it.
    Shedding accessories as the battery went completely dead.
  3. Jun 19, 2023 at 12:32 PM
    Soupguy
    Soupguy [OP] Member
    I’m not sure exactly what the voltage was but the tow truck driver said it had plenty and I had attempted a jump start which didn’t change anything. All the electronics that shut off went out at the same time. Also the ebrake and abs light came on along with some other dash lights.
  4. Jun 19, 2023 at 12:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like an ignition switch issue.
    All the things you mention are tied to the ignition switch.
    Dm93 likes this.
  5. Jun 19, 2023 at 12:35 PM
    TnShooter
    Deogee
    STOCK
    Dm93 likes this.
  6. Jun 19, 2023 at 12:36 PM
    TnShooter
    Deogee
    STOCK
    Do you have voltage meter?
    Or a test light?
    I think we can figure this out fairly easy.
    Dm93 likes this.
  7. Jun 19, 2023 at 12:43 PM
    Soupguy
    Soupguy [OP] Member
    I do have a multimeter, an ignition switch issue would make sense.
    TnShooter likes this.
  8. Jun 19, 2023 at 12:45 PM
    TnShooter
    Deogee
    STOCK
    See if the fuses in the diagram above have power with the ignition switch on.
    Then wiggle the key around in the ignition switch and see if you loose power.
    Also, will the truck still not start?
    Dm93 likes this.
  9. Jun 19, 2023 at 1:37 PM
    Soupguy
    Soupguy [OP] Member
    Okay how do I check if they have power, just check the fuses them selves? And no it will not start it doesn’t even make any attempt to crank or turn over
  10. Jun 19, 2023 at 3:21 PM
    TnShooter
    Deogee
    STOCK
    The fuse has a small spots on the top you can touch with the meter.
    Black lead to a good ground. Red lead to the metal dot on top of the fuse.
    See arrow
    This is NOT the correct fuse in the picture.
    It is just a representation of where to touch the fuse to see if it has power.ON.IMG_0284.jpg
    Dm93 likes this.
  11. Jun 19, 2023 at 3:25 PM
    Soupguy
    Soupguy [OP] Member
    Gotcha and the multi meter should just show resistance if the fuse has power?
  12. Jun 19, 2023 at 3:28 PM
    TnShooter
    Deogee
    STOCK
    No. Set the meter to DC voltage.
    It looks like the symbol on the far right of the picture below.
    asuchemist and Dm93 like this.
  13. Jun 19, 2023 at 3:48 PM
    Soupguy
    Soupguy [OP] Member
    Okay I did that and gave the key a wiggle no change in any of those fuses
    Though the IGN and gage fuses are reading 12.2, the tail fuse is reading 0.00 and the rest of the fuses are reading 69-72
  14. Jun 19, 2023 at 4:14 PM
    TnShooter
    Deogee
    STOCK
    What about the IGN1 and IGN1 No.2 fuses?
    Dm93 likes this.
  15. Jun 19, 2023 at 4:28 PM
    Soupguy
    Soupguy [OP] Member
    They’re reading the same as the others which I just checked again and they’re around 95
  16. Jun 19, 2023 at 4:30 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You may want to check the AM1 Fuse (50A) in the underhood fuse box, it feeds that branch of the ignition switch.
  17. Jun 19, 2023 at 4:31 PM
    TnShooter
    Deogee
    STOCK
    Is that one bolted in?
    If so it should have a window to see if it’s blown. But……
  18. Jun 19, 2023 at 4:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No it's a standard J-Case (Box) fuse.
  19. Jun 19, 2023 at 4:34 PM
    TnShooter
    Deogee
    STOCK
    Raining here, so I didn’t want to have to run out an pop the hood.
    Thanks.
  20. Jun 19, 2023 at 4:46 PM
    Soupguy
    Soupguy [OP] Member
    Shit this might be it! AM1 is definitely blown. I’m gonna go grab a new one and I’ll give y’all an update!
    Thanks!
    Dm93 and TnShooter like this.
