Speedometer Calibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Billnis, Jun 7, 2020.
  1. Jun 7, 2020 at 4:07 PM
    Billnis
    Billnis [OP] Well-Known Member
    Bill
    Menifee, CA
    2001 White PreRunner Extra Cab 3.4L V6 Oak Int.
    PERFORMANCE: TRD Gen1 Supercharger, Snow Performance Water/Methanol Injection, Toyota E-Locker, Falken Wildpeak Tires, 5100 Bilstein Shocks, Redarc Tow Pro Brake Controller, B&M Transmission Cooler. EXTERIOR: Raptor Spray-on Bedliner, Custom NRT Off Road decals, Chase Rack with Offroad Lights, Fog Lights, Bed Lights, Rear Bumper Lights, Rago Bed Stiffeners, T1A Metal Door Handles, 7-Pin Trailer Connector, Switchback front turn signals, LED tail lights, License Plate Lights Shutoff For Backup Camera. INTERIOR: Android Head Unit with OBD2, Dash Camera, Backup Camera, TPMS, and Hands Free Microphone, Rockville SS8P Subwoofer, Remote Door Locks with Automatic Window Close, RFID Kill Switch, Custom Switch Panel, Hands Free Phone Mount, All LED lights LED, Ignition Light Ring, A pillar two gauge pod with VC-50 Meth Injection Controller and NRT Branded Oil Pressure gauge, Torque Pro App for Gauges (Wideband Air/Fuel, Water Temp, Trans Temp, MAF, Volts, Timing, Engine Load, Intake Temp, Throttle Position, Fuel Status - shows open or closed loop, Instant MPG.)
    I found this old thread about this topic, but no answers.
    https://www.tacomaworld.com/threads/speedo-calibration.79381/page-2#post-23529435
    I didn't check to see how old it was so I posted a reply and got my hand slapped.
    My speedometer is off by as much as 10mph, I might have a solution to this problem. As I posted on the old thread (I deleted my post from there):
    Many years ago I had a '98 Dodge Dakota, it had a 3" lift and oversize tires on it. I bought a v3 Yellow Box from https://www.yellr.com/index.htm and it worked really well. I still have it the box, not the Dakota. I sent the company an email to see if it will work on my Tacoma. If it does I will let you all know how it works out after I install it.
    It can adjust the speedometer down to a .25% speed offset. Mine Tacoma is a 2001, from what I understand the first couple of years used a cable before changig to a speed sensor.
    Does someone know if the speedo sensor is a hall-effect type?
  2. Jun 7, 2020 at 4:32 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Haha, yeah, the threads are all dated.
    But your answer was there.
    If you want to ask a question of the original poster you can tag him by adding@
    @Billnis Or touch his username and see the last time they logged out.
  3. Jun 8, 2020 at 6:59 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
  4. Jun 8, 2020 at 7:41 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'm not sure what your goal is, but I got my speedometer almost perfect after swapping to a speedometer gear with the correct number of teeth. It was a 10 minute job of swapping it out of the transfer case.
    Black DOG Lila likes this.
  5. Sep 26, 2020 at 4:03 PM
    Beater_Bimmer
    Beater_Bimmer Well-Known Member
    San Francisco, CA
    2002 Tacoma 4x4 DCSB
    I just had my 02 auto 4x4 re-geared to 4.88 with my existing larger tires (255/85-16/33's) and my speedo is ~ 10mph at highway speeds. I'm going to do the 33-tooth speedometer gear swap first to see if that gets me to where I need to me. I'll be confirming with a GPS speedometer. See here for a good write up: https://adventuretaco.com/replacing-the-speedo-gear/
    Note: if you order a gear, pay attention to p/n's as they differ between manual and auto transmissions. Once it arrives and I test it out, I'll report back my results. I'm hoping to try this as it seems much more simple than the Dakota option.
    I ordered the following:
    turbodb likes this.
  6. Oct 13, 2020 at 9:37 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    How did that go?
    I run 285/75/16 with 4.88 gears. I put in a 34 gear and I'm still about 6%off. 255/85s are slightly taller (33.1 v32.8 I think) and doing a 33 tooth gear you may still be about 8%ish off.
    I'm thinking about doing the 255s when I get new tires.
    Let us know.
