Speedometer calibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sean73T, Aug 22, 2017.
  1. Aug 22, 2017 at 10:20 PM
    Sean73T
    Sean73T [OP] Well-Known Member
    Sean
    SoCal
    17 Pro
    Anyone use the hypertech on a 3rd gen? Running 285/70/17 Toyo MT's on the Pro. I know how off I am, roughly 6-7MPH, but I want to get the speedometer working correctly. Search feature and Google only show second gen threads.
    Thanks!
  2. Aug 23, 2017 at 8:13 AM
    dreadedsoldier
    dreadedsoldier Well-Known Member
    Utah
    2016 Quicksand TRDOR
    I have the calibrator from hypertech. Works as advertised. Buy it, read instructions, and install. Just make sure you disconnect the battery before you unplug the instrument cluster or you get a crap ton of faults. It may just be a placebo effect, but I think it shifts better. In theory the speed sensor is now calibrated right and so the shift points are back to where they should be stock. I recommend it as it bugged the ever-living shit out of me that I was off.
    GPsevinSixx, Age315 and Sean73T[OP] like this.
  3. Aug 23, 2017 at 8:18 AM
    Sean73T
    Sean
    SoCal
    17 Pro
    Thank you, that was the answer I was looking for. It's definitely annoying and if anyone drives my truck but me, I don't want them to get into trouble.
  4. Aug 23, 2017 at 8:24 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    I'm going to say that it has to be placebo effect. The combination meter is the "end of the line" and simply displays the speed you are going as a translation of speed pulses. The hypertech intercepts that signal going to the combination meter and alters the display only. It does nothing to modify the signal the ECU is receiving from wheel speed sensors.
    Only way to "trick" the ECU is to regear to the proper ratio.
  5. Aug 23, 2017 at 8:25 AM
    bradshawnh
    Boston, MA
    It's going to be a percentage and not a constant speed difference. It's about 6 or 7% faster than indicated speed. The speed differential is less at lower speeds (ie 30 on the dash does not mean 36, likely is closer to 33).
    Just to be aware, FYI.
  6. Aug 23, 2017 at 8:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    You might find this thread interesting, particularly post 7. https://www.tacomaworld.com/threads/p0500-code-vehicle-speed-sensor.434829/
    I realize this is a 2nd gen thread I'm referencing, but do we know for sure the 'flow' changed for this with the 3rd gen. ?
  7. Aug 23, 2017 at 9:03 AM
    bradshawnh
    Boston, MA
    I guess we don't. But we will never know because of the black magic going on inside of the ECU and combination meter.
    Logic points to this flow though, especially with the new technology employed by the 3rd gen...why would the speed sensors feed information to the combination meter AND THEN to the ECU? That would mean you had to interpret the vehicle speed from the 4 wheels at the combination meter and not in the ECU...which means the wheel speed sensors all connect to the cluster in some way. This makes even less sense. The only way that makes sense is if the ECU can translate vehicle speed, and convey that speed to the combination meter.
    Always open to believing that it acts differently, but I see no convincing evidence other than 2nd gen with older technology to say otherwise.
  8. Aug 25, 2017 at 6:20 PM
    Sean73T
    Sean
    SoCal
    17 Pro
    Hypertech did the job and installation was a breeze.
  9. Oct 4, 2017 at 5:33 AM
    itsraymondang
    itsraymondang Spam King
    Houston, TX
    2017 White TRD Sport DCSB
    Does it get removed or stay plugged in?
  10. Oct 4, 2017 at 8:02 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Stays plugged in. It mounts behind the cluster.
    dreadedsoldier likes this.
  11. Oct 4, 2017 at 8:04 AM
    itsraymondang
    Houston, TX
    Oh darn.
    Do they make any that gets programmed and can store in closet?
  12. Oct 4, 2017 at 8:07 AM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    If the factory Etune Navigation system comes with a tire/speedometer calibrator, why not use it?
    APPS / SETUP / NAVIGATION / DETAILED NAVI SETTINGS
  13. Oct 4, 2017 at 8:11 AM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    That is only for navigation use, hence why it is in the navigation setting. It does nothing to change the speed displayed in the cluster.
  14. Dec 22, 2017 at 10:17 PM
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    So, I'm going to revive this thread to ask @Sean73T if the hypertech unit fixed fuel economy and the odometer readings as well?
    I would assume it does, but I'm currently exploring options to recalibrate my speedometer.
  15. Dec 22, 2017 at 10:36 PM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    I can confirm that yes it does correct the speedometer and the odometer. Went to 35'' tires 2 weeks into ownership and the calculations are correct. As others stated this is an in-line addition that calculates the % difference of your stock tire diameter to your newly installed diameter. The hypertech unit does not adjust shift points.
