Speedo Calibration
Discussion in '4 Cylinder' started by C17Guy, Mar 6, 2010.
  1. Mar 6, 2010 at 7:10 PM
    C17Guy
    C17Guy [OP] Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    Hey guys,
    Some of you already know that I've been looking into figuring out a way to fix my speedo from being off from a range of 5mph-10mph. Quite annoying having to check the gps to make sure I'm not speeding too much!
    Well, I went to the local dealer for my 20,000 mile service (damn, a year and 1 month old and i hit 20 grand!!!!), and brought up the question and was quickly answered by a firm "NO."
    Well, I'm going to check another dealership and see what they say, but if there answer is the same, what should I start looking into and how much is it going to cost me!!!! Ha ha, I'd like to maybe save as much as possible due to the audio project and maybe (fingers crossed) the supercharger for out little bad boys! Thanks all!:)
  2. Mar 6, 2010 at 7:17 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I try not to wear speedo's anymore. The wedgies are an absolute killer!
    Zakc, DGXR, Khrolar and 1 other person like this.
  3. Mar 6, 2010 at 7:19 PM
    C17Guy
    Dennis
    alright :confused:.... actually i can't lie.... i did laugh a little bit!:D
  4. Mar 6, 2010 at 7:51 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I believe your best bet would be the GPS or getting a Scanguage that will display your digital speed same as your GPS. Thats all that I have been able to come up with since installing my lift.
  5. Mar 6, 2010 at 8:00 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Just get bigger tires, 265-75-16 ought to put your speedo right in line with the GPS
  6. Mar 7, 2010 at 6:58 AM
    C17Guy
    Dennis
    It's always been 2-3 mph slower than the gps stock, but when I got the 245/75/16 on there, thats when the difference was the largest. Why would going bigger increase the stock speedo?
    Thanks for the brainstorming guys!
    Benny123 likes this.
  7. Mar 7, 2010 at 8:04 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Larger diameter tires will necessarily make the speedometer read 'lower' (than actual speed). The more you increase your tire diameter the more your speedometer will be reading 'low' (relative to actual speed).
    The dealership was telling you the truth about not being able to recalibrate.
    If you want your speedo to read accurately you need to look into an aftermarket speedometer recalibration unit - to be wired inline to modify the incoming speed sensor signal.
  8. Mar 7, 2010 at 8:23 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The computer in the truck is set (very poorly) for whatever the stock size tire is. Putting a larger or smaller tire on the truck doesn't change how fast the truck thinks it's going but does change how fast it actually goes. With a larger tire, you will be traveling faster than what the speedometer says you are.
    With our trucks already being off by 2-3 MPH, a lot of people go with a larger tire size which eliminates this error. However, from what I've been able to tell the odometer is right now with the stock tire size so going with the larger tire throws it off.
    Installing a 265/75/16 tire on a Prerunner with a stock tire size of 245/75/16 takes up for a 2.3 MPH difference. On the base 2wd trucks with a tire size of 215/70/15, a 235/70/15 tire would be 2.5 MPH faster and a 225/75/15 would be 3.2 MPH faster.
    Use this link ( ) to compare various tire sizes.
  9. Mar 7, 2010 at 8:40 AM
    C17Guy
    Dennis
    Thanks! Looks like I double screwed myself with the 16" wheels and the tires. I've been looking into the Hypertech Speedo Calibrator, but that looks like it might be a pain in the ass taking apart the gauge panel.
  10. Mar 7, 2010 at 12:47 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    On my 4 cyl 5 speed 5 lugger, 60 indicated is 56 or 57 on my GPS, it jumps back and forth holding a steady 60 on cruise control. So to do a true 70 it need to be reading 75 or so. My odometer error is 1.5%. To me, that is a pretty big discrepancy.
  11. Mar 7, 2010 at 5:04 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I bought & installed one of THESE to correct the speedo on my old '96 Mustang Cobra almost 10 years ago when I changed the rear-end gear from the stock 3.27 to a 4.10. I don't know if anyone has used one in a Tacoma on not, but it should be possible. All you need to do is find the wire between the speed sensor and the computer. This device just splices in and adjusts the signal by whatever ratio you select. Very easy to set up (and change later if you decide to run a different size tire, rear gear, etc.).
  12. May 18, 2010 at 2:06 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I went from 245s to 285s and the dealer got mine within 2mph at 70
  13. Jul 19, 2013 at 9:07 AM
    jwiereng
    jwiereng Member
    What is the aspect ratio? Increasing width alone will not change speedo accuracy.
  14. Jul 19, 2013 at 6:39 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Replaced the stock Dunflops P245/75/16's with BFG All Terrain LT265/75/16's and my speedometer is dead on with my GPS? Stock tires were 2 mph off on the slow side. Of course now the odometer is not correct. At 10,000 miles the odometer is reading actually 9600 miles.
  15. Jul 30, 2013 at 7:46 PM
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    My Tacoma is fast 5-7mph what size tire would I need to fix that big of a error?
  16. Jul 30, 2013 at 7:51 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Hypertech makes a plug in programmer for our speedo's now, just got one and the install way super easy. Hypertech part # 730107 for 2005 to 2011 taco.
  17. Jul 31, 2013 at 8:53 AM
    Trachito
    Trachito Well-Known Member
    New Orleans
    at what speed is it that far off? 30 mph, 60 mph?
  18. Jul 31, 2013 at 8:56 AM
    camojared
    Jared
    SE Ohio
    3-5 off in town driving 7 off at 60- When the gps says 60 the truck says 67. I thought it was the gps at first so I borrowed two others they all say 60 and the truck says 67.
  19. Jul 31, 2013 at 9:20 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Good advice buyo. :)
    I wanted to run wider 16's on my 5 lug that is calibrated for stock 215/70/15 tires and wheels. So I installed 235/60/16's, because the diameter is only 1% different from stock...
    Adjusting the tire aspect ratio is an easy way to compensate for different size rims. :thumbsup:
  20. Aug 1, 2013 at 7:03 AM
    Trachito
    New Orleans
    i went from 32's to 33's on my TRD tacoma and it slowed my speedometer down by about 7%. yours is fast by about 11.5%. I don't know what size tire you have on there now but you definitely need to go a size or 2 bigger.
    use this calculator to help you figure out what size you'd have to go up to
