Speed sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Jan 8, 2021.
  1. Jan 8, 2021 at 7:18 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    How many do I have on my truck? It intermittently working.
    2006 Tacoma 2.7 4 cylinder single cab auromatic.
  2. Jan 8, 2021 at 8:03 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Engine speed (rpm) or vehicle speed (mph)?
  3. Jan 8, 2021 at 8:21 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe there are 4 on the Auto trucks. 1 for each wheel.
    The sensors send a signal to the Skid Control ECU.
    The SC/ECU send the signal to the Combination Meter.
    Do you have a Check Engine Or ABS Light on?
    A scan tool capable of looking at live Sensor Data would help a lot.
    Jimmyh and gearcruncher like this.
  4. Jan 15, 2021 at 11:55 AM
    pinktaco808
    Cel said speed sensor working intermitinely
  5. Jan 15, 2021 at 11:55 AM
    pinktaco808
    Speed sensor?
  6. Jan 15, 2021 at 1:09 PM
    TnShooter
    Deogee
    STOCK
    Do happen to remember the code # ?
  7. Jan 15, 2021 at 1:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Get the code.
    On a 2006 I would be looking at a worn wheel bearing causing contamination on the Magnetic Tone Ring and Sensor.
    6 gearT444E likes this.
  8. Jan 15, 2021 at 3:11 PM
    pinktaco808
    I'll go look again it.pop up again after I cleared it after 2 weeks
  9. Jan 15, 2021 at 3:11 PM
    pinktaco808
    Link for that? Pics
  10. Jan 15, 2021 at 5:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    As others stated you really need the code number to continue but being you have an engine light and no ABS light it's likely referring to the vehicle speed sensor or one of the other speed sensors on the transmission, you may block the wheels and crawl under the truck and give all the wiring on the transmission a good look over for breaks, chafing, or corrosion.
  11. Jan 15, 2021 at 5:43 PM
    pinktaco808
    Yes code
    PO500
    VEHICLE SPEED SENSOR
  12. Jan 15, 2021 at 5:45 PM
    pinktaco808
    Vehicle speed sensor?
    Easy fix how I trace it?
  13. Jan 15, 2021 at 6:13 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Does your speedometer work? Here's some troubleshooting information for that code.
    Jimmyh and TnShooter like this.
  14. Jan 15, 2021 at 6:26 PM
    TnShooter
    Deogee
    STOCK
    Hopefully it’s not the Gauge Cluster.
    There’s been a few guys with this issue.
    Most guys seem to say that if the scan tool shows No MPH or bounces around, it’s likely the Cluster.
    I believe it goes like this for the Auto trucks.
    Speed Sensor -> Skid Control ECU -> Cluster -> ECM -> Speedometer.
    You’re not throwing any ABS or Wheel sensor codes. Bit that doesn’t mean they are not worth checking.
    The cluster can be expensive and not the easiest to install.
    Here is a good read on how one guy diagnosed his.
    I couldn’t do this my self, I don’t have the proper equipment.
    Maybe some one with a bot kore knowledge can help you out?
    https://www.tacomaworld.com/threads/p0500-code-vehicle-speed-sensor.556206/
    Jimmyh, pinktaco808[OP] and Dm93 like this.
  15. Jan 15, 2021 at 6:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Close but according to the troubleshooter it goes: Speed Sensor > Skid Control ECU (ABS) > Combination Meter (Instrument Cluster) > Speedometer >Engine Control Module
    So if your speedometer is working properly it's likely something between the Combination Meter and the Engine Control Module, if it's not then it's likely either something between the Combination Meter and the Skid Control ECU, or a Speed Sensor or related wiring.
    Jimmyh and pinktaco808[OP] like this.
  16. Jan 15, 2021 at 6:47 PM
    TnShooter
    Deogee
    STOCK
    Humm.....I get confused at - ECM determines speed.
    It sounds like the pulse signal is relayed through the cluster to the ECM.
    Not sure how the speedometer knows the speed before it gets to the ECM?
    Unless there is a separate ECM that converts the signal for the speedometer?
    I hope that I never have to deal with this issue, it can be a hassle to deal with.
    Automatic Transaxle Models:
    Vehicles, which are equipped with ABS (Anti-lock Brake System), detect the vehicle speed using the skid control ECU and wheel speed sensor. The wheel speed sensor monitors the wheel rotation speed and sends a signal to the skid control ECU. The skid control ECU converts the wheel speed signal into a 4- pulse signal and transmits it to the ECM via the combination meter. The ECM determines the vehicle speed based on the frequency of the pulse signal.
    BTW, I’m not disagreeing with you.
    I just trying to figure out how it works exactly?
    Plus, help OP too!
    pinktaco808[OP] likes this.
  17. Jan 15, 2021 at 7:02 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The speedometer is in the cluster and controlled by it therefore it reads whatever the cluster sees from the ABS module, the cluster then sends a signal the the ECM based on vehicle speed. Most vehicles with this type of setup use only one of the wheel speed sensors for vehicle speed input but they don't always tell you which one as in this case I can't find any info on which wheel speed sensor is used for vehicle speed.
  18. Jan 15, 2021 at 7:13 PM
    TnShooter
    Deogee
    STOCK
    It seems like @Bishop84 said once?
    It worth noting that some guys have had issues with the speed sensor harness and wiring for the rear wheels. Whether this would cause this code, I don’t know?
  19. Jan 15, 2021 at 7:26 PM
    TnShooter
    Deogee
    STOCK
  20. Jan 15, 2021 at 7:32 PM
    Muddinfun
    Muddinfun Well-Known Member
    It seems like I read here somewhere that the transmission sensor supplies the speedo signal on the 4 cyl trucks. A few members have had the plastic gear wear out.
