Speed pulse signal connection???
Discussion in 'Audio & Video' started by brkin_th_habt, Jun 11, 2008.
  1. Jun 11, 2008 at 8:10 PM
    brkin_th_habt
    brkin_th_habt [OP] Gunny
    '08 Tacoma PreRunner SR5
    Eclipse AVN-6620 w/iPod/HDRadio/Rear Camera
    Installed an Eclipse AVN6620 (Double Din DVD/NAV) in my 08 Tacoma. My question is about 2 wires I have no idea where to connect to my tacoma.
    They are for:
    Vehicle Speed Pulse Signal
    and
    Reverse Signal
    Any help with where to hook these 2 wires into the tacoma factory wiring would be greatly appreciated.
    Thank you.
  2. Jun 11, 2008 at 8:20 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    Reverse Signal - Wire 12 (green) Looks like this gets connected to the high side of the circuit when trans is in reverse. Note: in manual says to use circuit tester to verify that signal is at 6 volts or higher when trans is in reverse!
    Not sure on the Vehicle Speed Pulse Signal quite yet.
  3. Jun 14, 2008 at 10:54 AM
    brkin_th_habt
    Someone with the program "Direct Wire 2.0" provided these answers to me.
    Item Wire Color Wire Location
    Reverse Signal Red/White Driver Kick, Gray 12 pin plug, Pin 1
    Speed Pulse Signal Purple/White Fuse box, Black 13 pin plug, Pin 5
    Both these connections worked great for use with my GPS and Rear Camera. If anyone runs into the same problem and needs help finding the connections above just let me know.
  4. Jun 14, 2008 at 7:26 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    these sound right to me. i got all my info from avic411.com. they deal w/ pioneer specific stuff, but they also have a section about VSS wires and such. oh, and the VSS wire can also be connected behind the glovebox, but i cant remember exactly which wire it is
