Speed bleeders for brakes
Discussion in 'Technical Chat' started by SpacemanSpiff, Jun 29, 2012.
  1. Jun 29, 2012 at 5:15 AM
    SpacemanSpiff
    SpacemanSpiff [OP] Well-Known Member
    James
    08 TRD Off-road
    Have any of you ever had any experience using these (ex. Russell Speed Bleeders)? If so, does it truly make it a one person brake-bleed job? Also, when you replace the existing bleed screw with the speed bleeder, how much brake fluid is lost and will the system need bleeding? In other words, are these things worth it or just a gimmick? I am not a racer, just an everyday driver. I am looking for a way to be able to do this myself. Thanks in advance!
  2. Jun 29, 2012 at 5:33 AM
    BamaToy1997
    Bill
    Navarre, FL
    The technology is sound. Just switch, bleed, and go. I have yet to see them in actual use though. Just have to make sure you don't accidentally leave one in! lol
  3. Jun 29, 2012 at 5:40 AM
    SpacemanSpiff
    James
    08 TRD Off-road
    Thanks, so they aren't designed to stay in? One poster mentioned replacing his stock bleed screws w/ these over on the 2nd Gen DIY brake pad thread...that thread is a little old and I posted the same on it but never heard anything - and pm'd him but no reply...
    Oh, your giff has to be the best ever...
  4. Jun 29, 2012 at 5:53 AM
    rushr
    rushr Well-Known Member
    04 DC TRD 4X4
    OME 883 Coils, Dakar Leaf Packs/D6XL AAL, Nitrocharger Sport Shocks, ARB Bumper, Warn M8000 w/Synthetic Line, BAMF Sliders, Odyssey Battery, ProComp 7069 15x8, BFG KM2 33x10.5x15, Frame End Cap Mod, Hayden Transmission Cooler
    They work great I use them on my race bikes. Hardly any fluid is lost installing them but yes bleed them after installation. They are meant to be left in place just keep caps on them so they don't get dirt/corrosion inside them.
  5. Jun 29, 2012 at 10:48 AM
    SpacemanSpiff
    James
    08 TRD Off-road
    Thanks! I may have to try them when I change the pads coming up soon...
  6. Jun 29, 2012 at 12:16 PM
    BamaToy1997
    Bill
    Navarre, FL
    Hmmm, from the description it appeared to be something you only installed during the bleeding proceedure. I will have to look again in more detail.
  7. Jul 10, 2012 at 7:03 PM
    JKD
    JKD Well-Known Member
    I used them for years on my previous car. It turned brake bleeding from a massive pain in the ass to an easy chore to do during routine maintenance.
    They go in and stay in. As a previous poster said, just keep caps on them to avoid contamination. Shouldn't matter, they're sealed, but why risk it.
  8. Jul 10, 2012 at 7:05 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Used them on a 73 Firebird. Liked 'em!
  9. Jul 10, 2012 at 7:13 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I haven't had them on any of my vehicles but I've helped a friend bleed his breaks, super easy. As those above me you just take at the old bleeder and screw in the new one, it's basically a replacement bleeder with a check valve. It is left in.
  10. Jul 10, 2012 at 7:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's basically a bleeder screw with a ball-valve and spring built in.
    Spring and ball seat against the bottom when you let your foot off so it doesn't draw air in, brake fluid (and air) pressure unseats the ball and allows it out.
    So... no need to remove, but you do need to remember to snug them down when you're done, same as the stock bleeder.
    Got them on my bike and I like them.
  11. Nov 4, 2014 at 7:35 AM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    anyone have a link to the ones for the tacoma? I have searched and searched and don't know the model to get.
    I know this is an old thread.
  12. Nov 5, 2014 at 9:25 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
  13. Nov 5, 2014 at 10:29 AM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
  14. Dec 14, 2014 at 10:43 AM
    dvd0020
    dvd0020 Well-Known Member
    Dave
    Colorado Springs
    08 Off Road Double Cab
    TRD supercharger, 4.88 Nitro gears, Doug Thorley long tube headers, aFe stage II intake, Pro Comp 6" DB lift (Icon Coilovers, Alcan 6" Springs, Bilstein RCD rears), NST lightweight pulleys, Morimoto mini projector retrofit for Spyder headlights, Cobra CB, 4' Fire stick, Pioneer AVIC-U310BT head unit, 2 10" alpine S, CBI Moab 2.0 front bumper, Smittybilt XRC8 winch, NFAB tire carrier, custom Colorado pinstripes
    The Russell website does not list them for a 2nd gen 4wd. Anybody know which model will work?
  15. Dec 15, 2014 at 2:13 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Check the speed bleeders site or send them an email.
  16. Jan 15, 2015 at 1:39 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I'm going to get some of these for my truck. I want to replace my brake fluid and these will help.
    I called speedbleeder.com to confirm...
    For Second Gen 4x4 the application is
    (2) SB7100 (Front Disk brakes) M7 x 1.0 x 35.15
    (2) SB1010 (Rear drum brakes) M10 x 1.0 x 34.44
    http://speedbleeder.com/automobile_applications.htm
    They are available in stainless and come with dust cap.
  17. Jan 15, 2015 at 1:48 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    I bought some speedbleeders and put them on my 05 but could never get my brakes fully bled at home. Ended up having to take my truck to a shop twice for bleeding. Royal PITA. I will confirm the Speedbleeder P/N's later when I get home.
    I think my problem was that I turned the key to "acc" or "run" to unlock the steering so I can turn the front wheels for better access to the brakes and in the interim, it activated the ABS which sucked in air.
  18. Jan 15, 2015 at 2:11 PM
    Crom
    Nick
    San Diego, CA
    Millions
    That sucks to hear, especially that it happened twice! I'm not sure I understand though. EDIT.... Found this post here which may be relevant.
  19. Jan 15, 2015 at 2:33 PM
    68vert
    AZ
    DCSB 4X
    I guess I need to be a little more clear. I had to take it back to the shop to rebleed because I felt after the first time, there was still air in the system and pedal was still a little soft.
    I put on the speedbleeders when i rebuilt my calipers and added SS brake lines. As soon as the system is open, air gets in. My theory is that once I turn the key, the ABS cycled the valves trapping that air in the ABS block up front. From some research I found, once that happens, you need to have a shop bleed with a diagnostic tool hooked up to cycle the valves in the ABS block.
    I plan on putting longer SS Lines on my new truck in the near future. So yes I will do it all without turning the key to see if it makes a difference.
  20. Jan 15, 2015 at 6:40 PM
    68vert
    AZ
    DCSB 4X
    These are the same P/N's I put in my 05 as well
