Spectre air filter?
Discussion in 'Performance and Tuning' started by Bobby311, Sep 26, 2009.
  1. Sep 26, 2009 at 7:33 PM
    Bobby311
    Bobby311 [OP] Member
    Bobby
    Spring, TX.
    99 Prerunner SR5
    5100's front, 5125's rear, flowmaster 40
    I think this is were this ? goes but has anybody used the drop in filter from Spectre? I just purchased one yesterday and searched the forum and nothing.
  2. Sep 26, 2009 at 8:05 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    That's because I don't think anyone has used one. Isn't too late for opinions now since you've already bought it?
  3. Sep 26, 2009 at 8:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They are not much different than all the other K&N type (Gause) filters.
  4. Sep 26, 2009 at 8:52 PM
    Bobby311
    Bobby
    Spring, TX.
    99 Prerunner SR5
    Then I guess I will let ya'll know if there is ant MPG differece
  5. Sep 26, 2009 at 8:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well....Keep in mind, a filter isnt the big restriction in the intake. When driving normally, the major contributer to engine pumping losses is the throttle it self. At part throttle, the engine is pulling against the small opening of the throtle valve. even running no filter wont improve mpg. If you buy it to have an air filter you can clean, then I can understand that. :) But for better mpg.....nope.
