SPC TYPE B UCA Bushing replacement - Polybushing
Discussion in 'Suspension' started by Tacoguayaco, Jun 3, 2023.
  1. Jun 3, 2023 at 6:20 PM
    Tacoguayaco
    Tacoguayaco [OP] Well-Known Member
    Xavier
    2020 white tacoma trd offroad
    Icon suspension 3inch lift ,2 " AAL , 285 75 16 DICK CEPEK tires ,DV8 roof rack etc etc
    SPC UCA for Tacoma
    https://www.spcalignment.com/component/spc/?task=part_description&pid=25470
    Typical part numbers you'll come across:
    25001- SPC Ball joint
    25400 - Toyota specific signifier
    25470 - Tacoma specific signifier
    25472A/3A - Type A UCA arm (Driver/ Passenger)
    25472B/3B - Type B UCA arm (Driver/ Passenger)
    25476 - Poly-bushing replacement kit
    25477 - Replacement Ball joint Boots
    25030 - X-AXIS BUSHING REPLACEMENT KIT
    Hello whom reads this,
    myself and a few others needed to replace bushings for our SPC uppers (as well as ball joints) and this is a bit of a findings guide/ tutorial for replacement.
    There are two main types of UCA's by SPC for Tacomas; 25472/3 in Type A and type B.
    Type A are the older versions of the SPC where it is the tube-type/welded variant.
    Type B is the newer, stamped steel type, as seen here;
    SPC has 2 main types of bushings; their "lower tiered" Polybushings / SpecRide, and their "fancy" X-Axis bushing. According to SPC, the Polybushings will not fit the Type B but will fit just fine on the Type A, however I can confirm that is not the case.
    The SPC Polybushings/ SpecRide bushings does (will) fit the Type B version of the SPC UCAs.
    Worn out X-Axis:
    UCA Bushing removal tool: Simple Balljoint press (cups inside the kit were used to press out the old bushings without following SPC's "removal guide" (where you drill out old bushing and then use a sawz-all to remove the steel shim/ pipe.)
    Balljoint press tool, using the cups to push out the old bushings.
    We attempted to use a hydraulic press, it does not work as well as the balljoint press.
    anvil and press, use tapered side of Bushing towards the "inside" of the "U" of the UCA.
    add lubrication to let the Polybushing slip in
    give it a good wack.
    besides that. it's a drop-in fit. there is no wobble and no issues after 2 weeks of driving.
    Photos and installation by myself
    "guide" Written by @Shveet
  2. Jun 3, 2023 at 8:47 PM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    Interesting... I'm at 140K miles on Type A. I changed both bushings @ 30K miles, I had one side which was shot for some reason. I'm in the process of rebuilding my front suspension this weekend and checked my SpecRides, they still have a bit of life left in em after 110K miles. It seems like the SpecRides might be the way to go and that it's good news that they fit Type B.
    I don't wheel, but I don't have a mall crawler either, I must of logged at least 25K on logging roads for work, usually at a fairly quick pace :burnrubber:. I'm quite pleased with the SpecRides.
    Shveet likes this.
  3. Jun 3, 2023 at 9:52 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I toasted my SPC X-Axis after 50,000km which kinda sucks but i have abused them on some wheeling trips so also shouldnt be too surprised.
    I was mostly annoyed that SPC states the specrides dont fit the Type B bushings and they are pushing their (more expensive) x-axis for both type B (as normal maintenance) and type A (via their "conversion" kit.
    Going to get myself a balljoint press kit and install the specRides myself.
    Optionally for those that want to be crafty enough;
    Polybushing and shim dimensions (± a few millimeters as i dont have the most accurate of calipers)
    IMG_20230604_003212998.jpg IMG_20230604_003257774.jpg IMG_20230604_003741871_HDR.jpg IMG_20230604_003340595_HDR.jpg IMG_20230604_003356148_HDR.jpg IMG_20230604_003437578_HDR.jpg IMG_20230604_003611386_HDR.jpg IMG_20230604_003639299_HDR.jpg
    SUMOTNK, jawmes and Kolter45 like this.
  4. Jun 4, 2023 at 12:02 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    It would be nice if someone would make rubber or poly bushings for these other than SPC. I really don't want to give SPC any more money given their long history of putting unproven parts out on the market.
    PasswordIsTaco123 and pa blaster like this.
  5. Jun 4, 2023 at 12:14 AM
    pinem56
    NE
    2018 TRDOR DCSB AT
    I also noticed that the last photo shows a gap between the bushing barbed end and the uca. If you look at the old style UCAs, there is no gap. Not sure if the gap matters.
  6. Jun 4, 2023 at 6:07 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I put my measurements up incase someone wants to see if ARB leaf bushings or some other company's bushings will fit.
    the SPCs i got were repackaged as Mevotechs. Ordered Mevotech bushings off of rock auto, and 2 different sizes. Kinda knew it wasnt going to fit, jut sucks that SPC didnt stick with OEM sizing for UCAs like other aftermarket ones did, where it just uses oem parts but has the adjustments set solid.
  7. Jun 4, 2023 at 6:18 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    When i was looking at @Tacoguayaco s truck, i noticed the same thing. i dont think it matters as it is pinned in place due to the assembly of the UCA onto the shock tower.
    So you have bolt, bushing washer, bushing + steel sleeve, shock tower, and mirrored that for the other have of the arm.
    The bolt compresses the washer into the steel sleeve and the steel sleeve is pinned against the shock tower, and then to the other side in the same manner.
    The polybushing itself only bears weight/ rotation, but even then its pinned against the washer and the UCA so it cant actually move.
    The only downside is that dirt could get onto the wear surface of the bushing and eventually make its way between the UCA and bushing wear surface causing it to fail faster.
  8. Jun 4, 2023 at 7:00 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    @Tacoguayaco might have installed the bushings incorrectly.
    Looking at my bushings adjacent to the UCA arm and sleeve. Having the fat/ thick portion of the polybushing on the outside and up against the sleeve of the UCA arm, it offsets the shim a bit. Towards the outside
    If we have the taperd side outside of the UCA sleeve
    Its 3mm narrower (so 6mm in total)
    @Tacoguayaco did you have issues with installing the UCA? Was it a loose fit (should be technically) ?
    time for more research!
    Edit: if you press the bushings from the outside (thick flange out, tapered in) , you can compensate using the washers from the kit and use the OEM bushing washers on the outside
  9. Jun 4, 2023 at 2:41 PM
    Redsquirrel
    Redsquirrel Well-Known Member
    wonder if polytuff makes bushings for the 3rd gen yet.
  10. Jun 10, 2023 at 2:47 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    So ended up removing the X-axis bushings to swap in the Poly ones from SPC. and i'm posting my own findings.
    Tried using a 1-3/4" hole saw to remove the middle bit, I toasted a drill this way since the rubber almost liquifies at some point and gums up. so using a drill to punch a hole between the interior ball joint and the steel outer sleeve (through the rubber).
    and fed through a coping saw blade and just hacked away in a full circle.
    then hack sawd out the sleeve, using a punch to push the steel sleeve inwards releasing it from the UCA.
    Cleaned and filed smooth
    i hate these SPC ball joint bushings more than i hate not having the correct tool.
    This is the gap i was talking about between the Poly bushing and edges.
    when i greased and pressed in the bushings, figured to slap in a 3D printed ring to take up the spot to prevent it from shifting around.
    Ended up following @Tacoguayaco 's (after getting convinced otherwise by @3JOH22A ) way of install with the thicker flange on the outside. however i think i should have followed my original idea of having the thick flange on the inside.
    the gap below is the UCA pressed against the one side of the shock tower and the remaining gap on the other side. almost a good 10mm of spacing.
    Even with 2 washers (SPC's supplied washers on the insides of the UCAs and the OEM washers on the outside there is about a 3-4mm gap that remains, would need to add in another supplied washer to make up that difference.
    HOWEVER this is only when you hand tighten it. Once you start reaching torque spec (85ftlbs), that gap closes and is no longer there (see 2nd image below)
    So basically the sandwich is:
    • Bolt head+ flange
    • oem curved washer
    • spc polybushing/ steel sleeve
    • spc supplied washer
    • shock tower sleeve
    • vise versa the above
    i think it would also benefit having it flipped around (washers) as the OEM washer is the weird bent/ tapered one
    since the tapered side of the poly bushing is smaller than the wide flange, there isn't any reason to not have the OEM flange against it as it has enough surface area to make contact with it.
    • teal = OEM bolt
    • red = SPC poly bushing
    • gray = oem washer
    • dark blue = spc flat washer
    • pink = SPC uca
    • green = Shock tower tube
    • purple = 3D printed spacer ring
    • brown = text
    But yeah, thanks for listening to my TED talk
  11. Jun 10, 2023 at 7:09 PM
    pinem56
    NE
    2018 TRDOR DCSB AT
    Awsome post Shveet. I should think McMaster Carr sells a washer that would fill up the gap, so that there is no need to put the arms in compression. The amount of stress put into the arms is probably insignificant to affect the arms, but it might put more friction between the bushing and the flat washer.
    Shveet likes this.
  12. Jul 12, 2023 at 4:25 AM
    18TRDOR
    18TRDOR Well-Known Member
    Kyle
    New Philadelphia, OH
    2018 TRD OR DCSB 6MT
    So you mean to tell me. I can put the "old school" standard bushings in my current arms that came with X-Axis bushings?!
    Shveet likes this.
  13. Jul 12, 2023 at 9:19 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Sure can! I just did. Was able to press out 2 but the other 2 had to cut the sleeve to get them out.
    pressing the new ones in is way easier
    MarX and Shveet like this.
  14. Jul 29, 2023 at 8:30 AM
    Trailmixguy
    Trailmixguy New Member
    Michael
    22 Tacoma sport premium with the goodies
    OEM TRD 2/1 lift kit. Stealth camo fender flare wrap, 33 inch Falken wild peak AT3, 16 inch trail replicas (8in wide vs. 7in stockies). Functional hood scoop, Fransue rack KNN black series intake MBRP turn down exhaust pedal commander TRD skid plate, cali raised lower grill light bar, old man steering knob
    How come everyone isn’t replacing with the x-axis ones?
  15. Jul 29, 2023 at 8:31 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    General consensus is that they have a high failure rate compared to spec ride.
    Shveet and AllTacosFloat like this.
  16. Jul 29, 2023 at 9:01 AM
    AllTacosFloat
    Boston ish
    And they are usually out of stock and over priced.
    And they suck to replace compared to spec ride
    MarX likes this.
  17. Jul 29, 2023 at 1:56 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Also absolutely a pain in the ass to remove the old and install new ones...
    With the poly stuff, its an easy press both ways but the x-axis needs a full blown press to get into place
    MarX likes this.
  18. Nov 30, 2023 at 9:22 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    SUMOTNK likes this.
  19. Nov 30, 2023 at 9:42 AM
    SUMOTNK
    Eddie
    Interesting but good option in what way? Looks like an x-axis replacement? Price point is good but Moog?
  20. Nov 30, 2023 at 9:57 AM
    toku58
    Mall Crawler!
    fairly similar to the OEM bushings that last for well over 100K. My SPC X-axis has failed with less than 10K miles. I just got a new set from SPC under warranty.
    Poly bushings will require greasing.
    SUMOTNK[QUOTED] likes this.
