Spark Plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by TurbulentLamp, Mar 7, 2019.
  1. Mar 7, 2019 at 12:22 PM
    TurbulentLamp
    TurbulentLamp [OP] Well-Known Member
    1999 Toyota Tacoma 2.4L 2WD
    Hello! I have a question for those who own a Tacoma with a 2.4L engine. I am planning on changing the spark plugs on my 99 Tacoma, and I wanted to know which spark plugs people have used on their 2.4L that they recommend. Any help is appreciated! Thank you!
  2. Mar 7, 2019 at 12:29 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I would just stick with the OEM copper plugs unless you have a modified engine (super/turbocharger for instance). I believe the OEM ones are the standard dual electrode Denso or NGK brand plugs.
  3. Mar 7, 2019 at 12:32 PM
    GMan8402
    GMan8402 Well-Known Member
    98 SR5 4x4 / 14 Prerunner TRD OR 4x2
    I used Bosch platinums in my 2.7 years ago and it's still going fine.
  4. Mar 7, 2019 at 1:53 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    These are the plugs recommended for your 2.4
    NGK BKR5EYA
    Any parts store should carry those
  5. Mar 7, 2019 at 2:09 PM
    TurbulentLamp
    Thank you guys! I figured that the ones I would have to use would be the copper spark plugs, but I just wanted to make sure that those were the ones people have used or whether they upgraded and went with the double platinum or the iridium spark plugs. But, I'm pretty sure the copper spark plugs should be fine since my Tacoma is completely stock.
    Speedytech7 likes this.
  6. Mar 7, 2019 at 2:28 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    well, the only difference with coppper, platinum and iridium is their longevity. They don't give more HP or anything
    Copper is the cheapest but they also have the shortest lifespan. They must be replaced at about 30k miles intervals
    Platinum have a longer lifespan, needing to be replaced at about 100k miles
    Iridium are the most expensive of the bunch, but they can last for 120k+ miles
    but to answer your question, I used NGK iridium on my 2.7
    oh and it is recommended you stick with Denso or NGK sparkplugs
    TurbulentLamp[OP] likes this.
  7. Mar 7, 2019 at 10:46 PM
    TurbulentLamp
    Thank you onakat! I didn't know that I thought you only had to put the spark plugs it recommended (in this case copper spark plugs) or else the truck would run funny. I think I'll go with the NGK double platinum in the meantime and see how well that works for me. Thank you for your advice.
