Spark plugs, whose changed em? what kind?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 209taco, Oct 27, 2014.
  1. Oct 27, 2014 at 8:50 PM
    209taco
    209taco [OP] Member
    Sid
    Central valley California
    2004 tacoma trd 5 spd 3.4L
    grey wire, leer camper, tundra brakes
    I just wanted to say hello, and let you all know i just did my spark plugs. I removed the factory denso's and replaced with ngk iridium ix plugs. I have read that people had issues with these plugs, I must say that I am happy with them so far.
    What kind of plugs have you all been using?
  2. Oct 27, 2014 at 9:08 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '03 cbr600rr, '09 R1, '03 cbr954rr
    I'm not sure if it matters, and I would like to know if it does, but on my 01 prerunner it states in the manual to only use the dual electrode plugs. I see that those are one. But when I got the truck I replaced with the duals and I didn't really notice a difference. I also heard that someone used the quads and it helped improve the performance. But yeah, kinda curious as to why they suggest only the duals...
  3. Oct 27, 2014 at 9:10 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    It suggest duals because of something with the sparking I believe, Ive run single and duals, truck seemed happier with duals but no drastic change but why not just put what it recommends in
  4. Oct 27, 2014 at 9:27 PM
    209taco
    209taco [OP] Member
    Sid
    thanks for chiming in folks. I appreciate the feedback so quickly!
  5. Oct 28, 2014 at 7:51 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    No matter which flavor you choose,,stick with the NGK's. They hold up the best.
    Bosch was a very short life. OEM was a bit better.
  6. Oct 28, 2014 at 8:22 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I heard dual spark plugs don't work as advertised because once the fuel/air is ignited there's no way to make a second ignition point.
    but I can't confirm nor will deny. all I know is I should probably change mine as well.
  7. Oct 28, 2014 at 8:29 AM
    romeo
    romeo Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    I changed my plugs to the E3 and have liked them so far, after installing them I could definitely notice a change in the exhaust sound and definitely noticed a change in the way she runs.
  8. Oct 28, 2014 at 8:34 AM
    scocar
    scocar hypotenoper
  9. Oct 28, 2014 at 8:54 AM
    stvnshnn
    stvnshnn Active Member
    Fairbanks, AK
    '01 Tacoma TRD Sport
    Why would you change something as integral to the full function of the engine to anything other than what the engineers who designed the engine say to put in it? In other words, go to the dealer, get the spark plugs in the red Toyota boxes and change them the when they should be changed. I want to get 400,000 miles or more out of my truck. A group of people smarter than I am designed the engine and then told me what to put in it to keep it running well. Good luck!
  10. Oct 28, 2014 at 9:03 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Go with the manual reccommendation. When I changed mine, I found a factory surprise. I had 3 Densos on one side and 3 NGK's on the other! It ran ok, but that chapped my hide a bit. I replaced them with 6 NGK's and it runs great now.
  11. Oct 28, 2014 at 9:06 AM
    scocar
    scocar hypotenoper
    They all come from the factory that way.
  12. Oct 28, 2014 at 9:14 AM
    Shelf Life
    Rob
    Central Oregon
    Really? What was the thinking behind that?
  13. Oct 28, 2014 at 10:38 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    I've run the factory Denso plugs in all my Toyotas for the last 35 years, zero problems.
  14. Oct 28, 2014 at 11:29 AM
    scocar
    scocar hypotenoper
    Nobody really knows (that I know of), but likely to maintain two major vendor supply chains.
  15. Oct 28, 2014 at 11:31 AM
    Koov
    Koov Well-Known Member
    Seattle
    2019 DCLB TRDOR
    Ha! Yep, I too use the ones from the dealer. NO issues so far!
  16. Oct 28, 2014 at 11:37 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    While there is no proof of any of the many theories, scocar nailed it. The only theory that holds any water is "Supplier Relationship Management" and the fact that Toyota owns a big chunk of both NGK and Denso. I have talked with NGK, Denso and Gadget with no 100% conclusive answer.
    The "3 of each" thing predates Tacomas in some engines and still goes on in the 4.0L, at least my 08 4R.
  17. Oct 28, 2014 at 5:02 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1.
    Those looking for additional spark plug info should check out The Truth About Spark Plugs....
  18. Oct 28, 2014 at 5:08 PM
    scocar
    scocar hypotenoper
  19. Oct 28, 2014 at 5:11 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I just changed mine and went Denso's all round per Chris 4X4 write up.
    No issues, easy
  20. Oct 29, 2014 at 1:26 AM
    Kalvin00
    Kalvin00 Member
    Nor Cal
    01 DCab 4x4
    I used standard NGKs, single electrode. Runs fine.
    The reason they recommend dual electrode plugs is because it is a wasted spark system, so each plug fires twice per revolution of the engine. Single electrodes will wear faster but I change every 30-40K anyways so who cares.
    Oh, and no anti seize necessary on NGK plugs. ;)
