Spark Plugs Recommendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TedTheTaco, Jan 2, 2021.
  1. Jan 2, 2021 at 7:37 PM
    TedTheTaco
    TedTheTaco [OP] Member
    2016 TRD Off-Road
    3” lift, Fuel Assaults 17x9 with 33s, Kicker Subwoofers, LEDs, Bakflip Cover
    Good evening, and Happy New Years.
    My 3rd gen Tacoma with the 3.5 has 107k miles (I know it’s a lot, I commute) and it’s time for new spark plugs. Anyone with a 3rd gen that has a recommendation for a brand of spark plugs that are reliable? Thanks
  2. Jan 2, 2021 at 7:50 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    DENSO is brand called out in manual.
    Some say that dealer price is not too bad.
    CaptainBart45 and gearcruncher like this.
  3. Jan 2, 2021 at 8:09 PM
    JG358
    JG358 Well-Known Member
    Jake
    Colorado
    16 Tacoma TRD OR DCSB
    I put denso in mine.
  4. Jan 2, 2021 at 9:31 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    127K on my Gen 2 and have yet to replace them.
  5. Jan 2, 2021 at 9:45 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    OEM always for ignition components. 107k is a pretty good testimonial I would say. You want more reliable than that?
    Junkhead and Skydvrr like this.
  6. Jan 2, 2021 at 9:53 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    DENSO FK20HBR8 (3491) as called out in the manual. $11 apiece at Rock Auto: https://www.rockauto.com/en/moreinfo.php?pk=5706984&jsn=3
    #4TOY4ME and shakerhood like this.
  7. Jan 2, 2021 at 10:14 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I went to the dealer. Fake plugs seem abundant. For the amount of times you change em, it's not too hard of a pill to swallow.
    Junkhead, G8R_Taco and shakerhood like this.
  8. Jan 3, 2021 at 6:58 AM
    mfalbojr
    mfalbojr Well-Known Member
    Kansas City, MO
    2024 TRD Sport Silver
    This is a do it yourself job. Shops charge wa to much. Takes about an hour. Watch a youtube vidio if you need help.
    slinkz419, CaptainBart45 and kgilly like this.
  9. Jan 3, 2021 at 7:26 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ^^^ This
    also a "how to do" on the 3rd Gen thread with list of items and pics - very well done. Showed my son-in-law how to do his and took about 2hrs total. really very simple, especially if you have any knowledge or experience turning even a simple wrench. Got his plugs at the local Toyota Dealer's on-line parts web page. OEM and saved about 30%.
  10. Jan 3, 2021 at 9:49 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    when removing the old ones do they just break loose immediately or are they a struggle to get out? i have one experience removing plugs from an aluminum head and felt like they were stripping and very hard to remove, was on a girl friends car and told myself never again
    Taco16LB likes this.
  11. Jan 3, 2021 at 11:22 AM
    Taco16LB
    Taco16LB Well-Known Member
    Been there . I went to remove plugs from a bought new 1987 Chevy Sprint (became GEO Metro) in 1996 with 85K miles . 1 plug screeched loudly and was very hard to turn when backing it out about 3/4 turn . I stopped there and retightened it and left it alone until we traded it in on a new 96 Pontiac . I have been told by a shop I trusted, that if the plugs were not removed before 50K on an engine with alum heads , they would not touch the plugs . This is were I chose my side of the anti seize debate with spark plugs . I use it , but sparingly .
    VirusCage and kahanabob[QUOTED] like this.
  12. Jan 3, 2021 at 12:33 PM
    GoldenBrew
    Golden, Colorado
    no problems just be sure you have the plug socket seated firmly on the plug = I used a 6 or 9 inch extender with the socket on it, and then by hand seat the socket over the plug by pushing down slightly and turning left or right until you feel it seat - that way you can feel that it is seated on the plug correctly - then use ratchet on the extension to remove - and do same for install - place the plug in socket and lower into position with extender - then with fingers turn back and forth without applying any down force - that way you can feel the plug thread grab - then continue by hand (not ratchet) until you can't tighten by hand any further - then put on the torque wrench and torque to proper amount (??14ftlbs). Power tools are a good way to ensure it will be f'D up - use your hand for feel and touch. A cross threaded plug is what you want to avoid at all cost and very unlikely to happen if you use the hand - touch - feel method. But I'm old school so what do I know? o_O and yes as mentioned us a very small amount of anti seize on the thread (like a 1/8" dab in one spot) and use di-electric grease on the top where the coil pack goes over the plug - more is good in this case.
  13. Jan 4, 2021 at 10:40 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    and just replaced my front pads at 65 k and one of the easiest jobs...both sides around an hour taking my time...
  14. Jan 5, 2021 at 6:06 PM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    OMG you are the other one! The other SPRINT owner. Had an 88 5dr hatch manual and an 87 parts car! Both were red, and plugs seemed welded in on the 87.
    Taco16LB[QUOTED] likes this.
  15. Jan 5, 2021 at 7:49 PM
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Is the one side really that much harder with relocating vacuum lines and such?
  16. Jan 5, 2021 at 7:54 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    OEM.
    Skydvrr likes this.
  17. Jan 5, 2021 at 7:55 PM
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    $700+ for a job that takes about an hour max is a pretty hard pill to swallow lol. Plus it was actually kind of fun.
    Definitely just get the recommended DENSO iridium plugs. Rockauto messed my order up once but they made it right and sent replacements quick (and they were genuine plugs). Just don’t try to hulk connecters out and you’ll be good OP.
  18. Jan 5, 2021 at 7:59 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I've run NGK for 40 years without issue. A spark plug is just an electrode running thru an insulator. Any more to it is just marketing.
  19. Jan 5, 2021 at 8:00 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Re-read the OP then my answer :thumbsup:
  20. Jan 5, 2021 at 8:07 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Thats why I only run copper plugs :jerkoff:
