Spark Plugs: 2010 TRD Offroad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaneHD, May 20, 2011.
  1. May 20, 2011 at 7:39 PM
    ShaneHD
    ShaneHD [OP] Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    Since I purchased my truck, I have put in a K&N air filter. Everything else hasn't been changed. I am around 26k miles and paid for a 75k mile maintenance plan. Guess I should have read up on this as it only does oil changes and rotations. Is this right?
    Regardless, it will be time to change my plugs soon. In my 2010 Tacoma TRD Offroad with the 4.0l V6, what spark plugs do I need/do you guys recommend? Anything tricky about changing these on this truck? Anything more I should know in changing them out?
    Since I failed to read into the 75k maintenance plan properly, what other maintenance should I be performing on my own?
  2. May 20, 2011 at 7:46 PM
    ShaneHD
    Fort Worth TX
  3. May 20, 2011 at 7:49 PM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Lawrence KS
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    Be sure to remember to ask for the headlight fluid corrosion resistant plugs. The Off Road Model requires them.
  4. May 20, 2011 at 7:52 PM
    ShaneHD
    Fort Worth TX
    So would I currently have 3 NGK and 3 Denso in my truck if I haven't changed them out yet (stock)? Will going all Denso plugs improve my gas mileage?
    Also, is the maintenance plan I mentioned (I think it is the Platinum) really only oil changes and rotations? No transmission fluid changes, brake fluid change, etc? I guess I was suckered, but I bought that plan and the 100k mile warranty package as well.
  5. May 20, 2011 at 8:09 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    DICKHEAD.
  6. May 20, 2011 at 8:11 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Our transmissions are sealed units using synthetic lubricant... they need NOTHING until 100,000 miles when you change it.
  7. May 20, 2011 at 9:08 PM
    ShaneHD
    Fort Worth TX
    Is there anything more I should be doing on anything else?
  8. May 20, 2011 at 9:12 PM
    ShaneHD
    Fort Worth TX
  9. May 20, 2011 at 9:17 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    What I have heard and it makes sense, they use two brands to protect themselves against labor problems. If they use only NGK and they go on strike, they are screwed. By buying from two major suppliers they are protected.
  10. May 21, 2011 at 8:45 AM
    David K
    Isn't there an owner's manual in the glove box? All the scheduled maitneance procedures recommended are in there.
    I got my 2010 new, and the Toyota dealer does everything on my truck, except for the tires and rotation (as of 5,000 miles ago when I got the Hankook Dynapro ATm's).
    I usually get the oil changed closer to 3,000 miles instead of waiting to 5,000. If you have 4WD, get both differentials checked and change their oil as recommended.... specially if you crossed deep water and haven't done the rear differential breather mod (see my link for that).
    Every 15,000 miles is a minor service above the 5,000 mile oil changes and every 30,000 miles is a major service. Do all these and you won't be shelling out money for broken down running gear. I am on Taco #3, and #1 and #2 both had over 100,000 trouble free miles in less than 5 years!
  11. May 21, 2011 at 9:07 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Just changed my dif fluids and manual tranny fluids to synthetic at the 30k mile mark. Get that old factory dino oil out and go synthetic, i found it worked wonders
  12. May 21, 2011 at 9:21 AM
    L.V.T.
    L.V.T. jackalope killer
    Las Vegas
    '10 TRD D-Cab
    Tint, Shaved Mud Flaps ;), Train Horns, 2.5" Fat Bob's front lift, Rear TSB spring lift, DuraTrac's
    Lol - classic
  13. May 21, 2011 at 3:12 PM
    ShaneHD
    Fort Worth TX
    We must be 22 here?
  14. May 21, 2011 at 5:41 PM
    Gregg
    Gregg Well-Known Member
    Gregg
    New Jersey
    2010 Access Cab TRD Sport 4x4 Magnetic Grey
    I think the transmission fluid was updated to be changed every 60,000 miles. I received an updated maintenance booklet. Also grease your drive shafts once in a while.
  15. May 22, 2011 at 6:39 PM
    chacotaco
    Travis
    Lawrence KS
    Better give him a free bump than to try and shut his shit down than saying something like "search feature"
    Your 22 comments statement escapes me. I am reliable and get off on cheap ammo.
    Find the "Toyota Maintenance Glovebox PDF that is in the stickies. Users from here, CustomTacos, and the Tacoma section of ToyotaNation put it together. Its a boiled down guide to you service intervals. Its a quite helpful.
