Spark Plug Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by coleslaw26, Apr 26, 2024.
  1. Apr 28, 2024 at 9:15 AM
    coleslaw26
    coleslaw26 [OP] Active Member
    Wyoming
    2021 Tacoma SR
  2. Apr 28, 2024 at 9:52 AM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    If you’re in no big hurry, either toyotapartdeal.com or local dealership would be your best bet. That way your getting the right plugs and mine came already gapped to what they needed to be.
  3. Apr 28, 2024 at 11:05 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    In 40 year of wrenching on cars (both my own and friends) i would say the biggest reason for a bad job is rushing it. I have seen wheel studs snapped off due to shops using impacts rather than torque wrench's to tighten. One member here had his oil changed and the tech forgot to install a new filter (the cartridge style of course). I have had dealers due a brake service and totally miss the fact that two piston boots where torn and the pistons seized. I only discovered this later and suspect the dealer may had actually caused this during their brake service
    I would say by and large the members here do the bulk of all their own work. Its their car and their investment.
    Service advisors treat everyone like idiots and knowing more than they do I treat them the same. Had a parents car in for front and rear brake work. Asked if they could due the tire rotation and said that would cost extra. I not so politely reminded then that ALL the tires were already off the car and NO it wont cost extra to put them back on in a different order.
    Then ultimate in stupidity and something I still laugh at today was taking my Tacoma in for its first service.
    The service advisor told me to my face that they had to take out my weather tech front floor mats in order to work on it because they were unsafe. I couldn't keep a straight face at that but there was no sense in disputing it so i just let it slide although i was laughing all the way home. Next time i went to the dealer I asked if they were once again going to take issue with my floor mats. The new service advisor said of course not, we sell then now.
    I have my limits based on not having a garage etc but beyond the warranty period my Tacoma has never been back to the dealer and most likely never will be. Its fully serviced by me and is better off for it.
    And while helping a lady friend with a grinding issue on her Hyundai that had just been to Midas for over $1000 in brake workI discovered this..
    There was NO outer pad on one of the rear disk brakes. The grinding noise was the caliper itself grinding on the rotor. The piston was only millimeters from popping out of the caliper at which point this could have caused a serious or even deadly accident. How the F does any competent mechanic forget a brake pad. No one here would.
  4. Apr 28, 2024 at 12:47 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    snapped off while they were using an impact?
    some of it is just crummy studs. my brz, i've never used an impact since i bought it new in 2014. i use a 4-cross wrench for every wheel change/rotation, and always hand-thread lugs on to start them to ensure i don't cross-thread them. a few years ago i had 5 different studs break off changing between winter and summer tires.
    in all reality, the impact really has very little to do with wheel studs, i blame the forces they're subjected to more than tools for installation/removal.
    but the funniest moments for me is when someone will impact a part fully onto the vehicle, and then put a torque wrench on it, which clicks immediately. for those that don't get it-- if i impact a bolt onto a vehicle to the max of the impact at 300ft/lbs, but then i come back to it with a torque wrench set to 75ft/lbs, it's going to click immediately, because it's torqued to 300ft/lbs.
    you're supposed to hand-tighten to roughly 30-40ft/lbs, and then bring it up to 75ft/lbs with the torque wrench.
    Stevie17 likes this.
  5. Apr 28, 2024 at 1:19 PM
    babylon5
    David
    Yes, snapped it off. Looks like they didn't
    Yes, snapped of. Looks like they didn't finger install first. Got cross threaded and twisted the stud till it broke.
    At 660 ft/lbs I can imagine what my IR impact would do if used to install. In reverse its a fixed 660. Luckily in forward its adjustable but I never use it to install anything anyway. Except for removing the reverse threaded nuts on lawn mower blades
    The next generation of the one i have is insane at 1,100 ft/lbs
    https://www.amazon.ca/Ingersoll-Rand-2135QXPA-Ingersoll-Rand-Impactool/dp/B00PPGE8DE?th=1
    I do use it to remove the wheel nuts. I jack up the corner I am working on and then undue all the nuts. Once I am done i then finger install and use torque wrench.
  6. Jul 28, 2024 at 6:03 AM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Thank you, all. Can anyone confirm part numbers for the plugs and also what size spark plug sockets? I have seen different information. Is it not 14mm?
  7. Jul 28, 2024 at 6:33 AM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Socket size is 5/8 or 16mm (standard spark plug socket). Part number is in the owners manual.
  8. Jul 28, 2024 at 6:49 AM
    bcmbcmbcm
    Brett
    Thanks. Is 5/8 the better fit than 16mm? Looks like 5/8 is 15.875 mm.
  9. Jul 28, 2024 at 8:09 AM
    babylon5
    David
    They may exist but have never seen a 16mm spark plug socket , I just use the standard 5/8 . And i assume you are using an actual spark plug socket and not thinking of using a 16 mm plain old socket..
    I bought and use this one. The magnet is quite strong and holds the plugs much better than the sockets that have a rubber insert that tries to hold the plugs. And it swivels as well.
    https://www.gearwrench.com/all-tool...-point-58-magnetic-swivel-spark-plug-socket-6
    On a friends older Corrola that one used a totally different socket. Think it was like a 12mm. Brought over my standard 5/8 and 9/16 which had served me for 40 years only to find this one was different.
    eurowner likes this.
  10. Jul 28, 2024 at 11:11 AM
    bcmbcmbcm
    Brett
    Thanks. Yes, definitely using a plug socket and not a regular metric deep socket. Curious if the plugs are really 16mm or 5/8.
    I have a trusty 5/8 spark plug socket that was from a ratchet set my granfather gave me years ago when I was 7. No engravings, stampings etc. lol just a sticker that says what size it is. I have probably completed at least a dozen plug changes in the last 40 years with this trusty socket.
    I am currently up leveling my tooling and thought about what may be better. Magnetic, swivel, etc. I had one nightmare of a plug change on my mom's 1990 Taurus with a transverse V6 when a plug broke off when I was removing it. Hard to get out-it was next to the firewall.
    Anyway I was looking at different sockets and sets, from spendy to not so much.
    Spendy
    https://shop.snapon.com/product/supplemental/3-8"-Drive-6-Point-SAE-5/8"-Flank-Drive-Magnetic-Universal-Spark-Plug-Socket/S9706KFUAMAG
    Not so much
    https://www.amazon.com/gp/product/B07MH5ZDMD?ie=UTF8&th=1
    and from HF If you look at the HF/Quinn set one of the sockets is a 16mm socket.
    Looks like a bunch of 16mm sockets on Amazon too:
    https://www.amazon.com/ABIGAIL-Magnetic-12-Point-Compatible-Motorcycle/dp/B0BYZD5G9M?crid=2GEF0B616GZYZ&dib=eyJ2IjoiMSJ9.FUM8ASMK6GogkUFowKJhkpKjzpQ3PpSdlbtXuE0jI1iDst7vM4_J9d4ATOWelppiGxbXGFzaW-100tD9crpccv9JznemzYjOV0wjcKcUgkmZFzCSXpNkHCuqddQ7WnZzL1isCINxyDH_QK5bHIArO5gw1qhxv-ADGYCg79K53u6PKqTCW8TEfwbkC_aBLmfexq_RgtzmL5jRiKs346AUJT3-O-L3-a-Ek1ZHNgFi93stWRt1ZZwl2yJ0PrL4aU25-IpkgyX2qiO-VLcoGP5wHPOo-qAimLfy_lFIDC3ds60.33KNkDvURIR3lHzZSz6dpAig62Ngda6pvMFiGqMhHas&dib_tag=se&keywords=16mm+spark+plug+socket&qid=1722189986&sprefix=16mm+spa%2Caps%2C109&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
    Just looking to use the best-fitting tool for the application here.
    Also found some Japanese Koken. More spendy than HF but if 16mm is correct these may be best. I like the one piece T-handle for hand-starting plugs in the heads.
  11. Jul 28, 2024 at 11:48 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Midas Mechanic rushing it, not paying attention, mind someplace else. I would fire mechanic on the spot. Midas probraly charge around $120/hr labor, major BS markup on parts, some BS they will not install customer supplied parts. Your friend took it back to Midas, got rotor and loaded caliper replaced free?
  12. Jul 28, 2024 at 12:17 PM
    cfarley
    cfarley Well-Known Member
    Michigan
    2023 TRD Off-Road
    Center console organizer
    Smart to go OEM if you're not sure how an alternative part is going to affect your engine. I wrestled with this as well and sided 3491
    Also did not need the universal joint as you can insert your socket extensions straight in on all of them. just push some wires out of the way.
  13. Jul 28, 2024 at 12:40 PM
    babylon5
    David
    If you have a 5/8 inch you have used and trust you are already setup. Every spark plug socket I have seen is 6 point and you are not dealing with something that is torqued to 100+ ft/lbs. i know in my 2nd gen a regular 5/8 fits just fine. But there are cases where a thin wall socket is needed but even then a 5/8 will do the trick. I mic'd out one of the denso plugs and its 0.625 , exactly 5/8
    Hardscrabble likes this.
  14. Jul 28, 2024 at 1:00 PM
    babylon5
    David
    The universal joint is a nice to have but not a requirement. But i highly recommend one with the extension as part of the socket. i have had cases where the grip between the socket and the extension was a little week and the socket would become detached and the plug would actually slide up a little in the socket such that the tip prevented the extension from going all the way back into the socket. i used a magnet probe to remove it. Before i bought the gearwrench magnetic version I actually epoxied an extension on to my old 5/8 to keep that from happening again. Those were the old style socket with the rubber insert to grip the plug.
    Technique and cfarley[QUOTED] like this.
  15. Aug 6, 2024 at 10:17 PM
    #35
    A_Baum92881
    A_Baum92881 Well-Known Member
    2019 Taco DCSB
    King 2.5 OME heavy pack Camburg UCA's Magnuson Super Charger Super Pacific X1 (with built out bed) The list continues to grow as my bank account continues to suffer!
    Welp...I know what I'm returning tomorrow!
    OP - Thank you for posting this thread!
    #35
    soundman98[QUOTED] likes this.
  16. Aug 7, 2024 at 5:53 PM
    #36
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I've bought mine multiple times from Amazon and I'm past 244k mile on my 2017 and I'm the og owner . I always buy from reliable seller . I could see if the seller on amazon was some rando fake company and was selling bogus parts . Gotta do your homework to pass the test I say. Research sellers and read opinions. I also have a app that checks Amazon for fake reviews. Fakespot app.
    A_Baum92881[QUOTED] likes this.
  17. Aug 7, 2024 at 8:24 PM
    #37
    A_Baum92881
    2019 Taco DCSB
    Good looking out and thank you for the tip on the fakespot app! I’ll be giving that a whirl on my next purchase!
  18. Aug 7, 2024 at 8:45 PM
    #38
    JCH
    JCH Well-Known Member
    Justin
    Colorado
    2021 TRD Off-road
    The thing about Amazon is that sometimes sellers use commingled inventory: https://www.prepitpackitshipit.com/post/amazon-commingled-inventory
    Essentially when that is used all the sellers for an item just ship that item to Amazon and it is thrown into a bin. When you order it doesn’t matter if you order from the most reputable seller or the sketchiest, the product would be pulled from the same bin.
    AFAIK the only for sure way to avoid this would be to message the seller and see if they use commingled inventory. Myself, if it has the slightest chance of being fake I avoid Amazon altogether.
  19. Aug 7, 2024 at 8:50 PM
    #39
    A_Baum92881
    2019 Taco DCSB
    Well I guess it makes sense to that if on paper it’s the same…If they’re on the up and up. But nowadays shady is all over the place!!
    JCH[QUOTED] likes this.
