Spark Plug Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by coleslaw26, Apr 26, 2024.
  1. Apr 26, 2024 at 8:34 AM
    coleslaw26
    coleslaw26 [OP] Active Member
    Wyoming
    2021 Tacoma SR
    All,
    I'm about to go ahead and replace the spark plugs on my 21 Tacoma SR (66k miles). Planning to following Team Oil Drop's spark plug video (linked below). All seems straightforward enough and I've got all the tools and more.
    Before I go ahead, any other recommendations or tips from those of you who've replaced your spark plugs?
    Thanks
    Spark plug replacement video: https://www.youtube.com/watch?v=tc9FYrD7vUw&t=58s&ab_channel=TeamOilDrop
    Stevie17 likes this.
  2. Apr 26, 2024 at 9:06 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    i havent done it , but make sure its the correct part, be patient, and dont over torque or under torque
  3. Apr 26, 2024 at 9:10 AM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Passenger side, piece of cake . Drivers side not so easy just take your time and you may have to move a bracket to get to a few . Other than that nothing else.
    NoOne likes this.
  4. Apr 26, 2024 at 9:10 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    for the brackets on the driver's side of the engine, remove the bolts at the top and for the lower, harder to reach bolts, use extensions and a swivel socket to loosen the lower bolts by accessing them through the wheel well, then you can swing the bracket out of the way and not have to use the force to miracle the lower bolts back into place
  5. Apr 26, 2024 at 9:45 AM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2019 TRD-OR AC
    Honestly people over exaggerate how difficult the driver's side is.
    You just loosen/remove the bracket bolts, then pull the foam shield out.
    Swap plugs just the same as passenger side after that.
    As long as you have a swivel and extension it's not hard by any means.
  6. Apr 26, 2024 at 12:23 PM
    coleslaw26
    Wyoming
    2021 Tacoma SR
    Awesome, thanks y'all!
  7. Apr 26, 2024 at 12:31 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    ^Sheer genius.
    Why not throw in "and stay hydrated"
    Himjo, 02Duck, oldtimertoyota and 5 others like this.
  8. Apr 26, 2024 at 12:32 PM
    Blak Shinobi
    taco
    n/a
    @jmneill :boom:
    stay hydrated and dont forget to put on sun block:anonymous: woke up on the wrong side of the bed lol :rofl:
  9. Apr 26, 2024 at 1:07 PM
    Blak Shinobi
    taco
    n/a
    yep you must drink water even if your not thirsty soldier , now drop and give me 50 pushups @WilliamJames
  10. Apr 26, 2024 at 1:54 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I changed my plugs when the engine was stone cold. Sat over night and changed them the next morning. Came out and went back in very easy.
  11. Apr 26, 2024 at 1:59 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    As previous post above: I recommend doing the job with the engine cold. (example: sitting overnight) Go easy on the anti-sieze if you use it. Just a hint on the threads and distribute it with a small cut-off toothbrush: no little globs. The threads on the Denso plugs are nickel plated and I don't use it. Either NGK or Denso (or both) do not recommend anti-seize on the threads. Do them one at a time.
    Have fun!
    Stevie17 and TA2016 like this.
  12. Apr 26, 2024 at 2:03 PM
    TA2016
    Oregon
    Also look into anti-seize or no anti-siege. Denso recommends no anti-siege, but many on TW like to use a little dab.
    Stevie17 and Williston like this.
  13. Apr 26, 2024 at 5:45 PM
    Stevie17
    Stevie
    Crossville, Alabama
    This socket helped me out a lot .
  14. Apr 26, 2024 at 6:59 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Make sure you have a good spark plug socket. The one I used (from Husky) left the rubber grommet behind on one of the plugs, and it was a pain to get it out plus get the grommet re-seated just right in the socket. Besides that the job wasn't too bad overall. I think I needed two universal joints and a few extensions for one of the ones on the driver's side. You'll have access to the PCV valve while you're working on the driver's side, but at 66k miles it's almost certainly fine, and you're more likely to break it putting it back than to find a problem. Mine looked fine at 129k miles.
    There is one clip securing a wire that I used pliers from underneath to release. Sorry, don't have a picture right now. But if you look around for a similar clip you can find one and figure out how it comes out.
  15. Apr 27, 2024 at 3:16 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Drive the truck to operating temps, shut it down, lay out your tools, and OEM sparkplugs. I do the hard side first. Know your dry torque for the plugs, no grease! It took me under 1.5 hours.
  16. Apr 28, 2024 at 4:47 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    AMEN! I have one and it really made the plug change go a lot smoother last weekend. Last plug on the driver's side was definitely loose.
    Stevie17[QUOTED] likes this.
  17. Apr 28, 2024 at 4:55 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    I have the gear wrench version and second that recommendation. And I am in the anti seize camp (i use high temp nickle version not copper). After the smallest dab with a qtip i then i wipe/twist it in a single sheet of paper towel leaving an ultra thin coat with non near electrode (there is more left on the paper towel than the plug). And i am using the Denso plugs not the "tri valent plated" NGK ones. I also use an actual inch/pound torque wrench and slightly reduce the setting (20%) since anti-seize can act as as lubricant.On my 2015 the change interval is a modest 30K but i would be almost certain to use it on the ones with the 100K intervals. Not sure if still recommended for those but a remove check reinstall at 50K used to be called for.
    Note. Copper is much more reactive in contact with aluminum than nickle (and why i use nickle and maybe why NGK plates with it.) But without an electrolyte like salt water involved even this is almost nill
    Has it helped thats hard to say. Plugs have never loosened and have always come out without issue but maybe they would anyway...
    Certainly hasn't hurt.
    There are about an equal # of articles/ video on the "no" category as there are on how to remove seized plugs from aluminum heads.
    IMHO the recommendation against anti-seize is due to those who just slather it on like cake icing and don't lower torque setting (20%) to compensate.
    P.S. Dont let the dealer do this. For my 2015 V6 they quoted 3 hrs at $108 plus plugs ($400 after taxes) . Based on video's and lots of helpful info here I did the job first time in 1.5 hrs. Book time is a (insert expletive here) rip off :crapstorm:
    And i want to use it all up all my anti-seize before i pass on so i don't have to bother including it in my will :rofl:
  18. Apr 28, 2024 at 7:08 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    More importantly, don't order plugs off Amazon or eBay. There are a lot of documented counterfeits that appear to be real, which can cause significant engine problems very fast.
  19. Apr 28, 2024 at 7:14 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    More you do it the faster you get
  20. Apr 28, 2024 at 7:25 AM
    woollypullover
    woollypullover Well-Known Member
    2019 Tacoma Sport
    If you have all the parts and materials give yourself 2-3hrs( it doesn’t take that long). This video is good, he makes everything sound way more daunting than reality.
