Spark Plug change on 2.7L 4cyl 2006 Tacoma?
Discussion in '4 Cylinder' started by dan99, Dec 7, 2010.
  1. Dec 7, 2010 at 8:10 PM
    dan99
    dan99 [OP] Member
    Maui
    06 4cyl Tacoma Access Cab SR5
    I've seen the DIY for the 6cyl. Anyone have one for the 4 cyl?
  2. Dec 7, 2010 at 8:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not yet. Im working with 08Pretaco on one
  3. Dec 7, 2010 at 8:32 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    It's pretty darn easy. Take the air intake assembly off the top of the engine. Unplug the coil pack then take out the screw holding it in. Take out old spark plug, put in the new one. Repeat for the other three. The usual precautions apply like checking/setting the gap and not over torquing the plugs.
  4. Dec 8, 2010 at 4:09 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    whats the recommended plug? i hit 100k on my 06 2.7, looking at swapping the plugs here soon.
  5. Dec 6, 2011 at 9:24 AM
    opalacio
    opalacio New Member
    Oscar
    South Florida
    06 Tacoma 4 cylinder
    Was there ever a 4 cylinder guide posted?
  6. Dec 6, 2011 at 11:26 AM
    afd23a
    The Dynamo of Dixie
    It's a Sticky in the 4 cyl tacomas section
  7. Dec 7, 2011 at 5:51 AM
    opalacio
    opalacio New Member
    Oscar
    South Florida
    Those were quick replies. Thank you very much it is very helpful.
  8. Jul 18, 2024 at 6:55 PM
    roninmd
    roninmd Member
    Ronin
    2005 Tacoma 2.7L Standard Cab
