Spark Plug Change Interval
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rraiderr, Oct 28, 2023.
  1. Oct 28, 2023 at 12:35 PM
    Rraiderr
    Rraiderr [OP] Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    For spark plug change on my 2017 3.5 is it strictly based on mileage or does it also go by the number of years old for lower mileage trucks?
    Like for oil it goes by mileage or year.
    The manual only shows mileage.
    Thanks.
  2. Oct 28, 2023 at 12:36 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Just mileage I believe which is 60k miles on the 2grfks
    shakerhood, Rraiderr[OP] and Chew like this.
  3. Oct 28, 2023 at 12:40 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    My guess would be usage for spark plugs. Oil and rubber degrade over time regardless of running the vehicle. Discount Tire when inspecting my spare tire said at 10 years old they would refuse to mount it for legal reasons.
    Rraiderr[QUOTED][OP] likes this.
  4. Oct 28, 2023 at 12:41 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Just mileage, oil degrades over time even if the engine isn't running, spark plugs only wear when driving.
    Rraiderr[OP] and shakerhood like this.
  5. Oct 28, 2023 at 1:20 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    They say 60k, but unless it isn't running like it used to I wouldn't change them. Iridium plugs are usually good for minimum 100k
    Anapg77, jmneill and Rraiderr[OP] like this.
  6. Oct 28, 2023 at 1:25 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    :confused:
  7. Oct 28, 2023 at 1:49 PM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    I would consider going by year even though the manual goes by mileage. Aluminum heads and steel spark plug threads. No harm in changing early but a lot of harm in changing late.
    02Duck, TA2016 and Rraiderr[OP] like this.
  8. Oct 28, 2023 at 8:27 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I don't like to mess around with old tires. I usually end up replacing mine sooner than most due to being in a high desert that also gets snow. The dry climate and UV light during the summer can be hard on the rubber.
    Rraiderr[OP] likes this.
  9. Oct 28, 2023 at 9:00 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is a good video if you plan on changing the plugs yourself.
    https://www.youtube.com/watch?v=737qAw6Z0n0
  10. Oct 28, 2023 at 9:23 PM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    One recommendation i have seen both yes/no on is to pull them half way (based on mileage). give them a really light coat of anti seize and replace them.
    Steel threads in an aluminum head can get to know each other really well in 60,000 miles. I have actually seen a case where the the spark plug came out with the aluminum thread from the head still attached. The person had to have heli coils added to the heads as a result.
    I know there are people on both sides of the fence in regard to anti seize and the new plating that comes on new plugs now adays. Myself I give them a very light coat (apply some and then use a paper towel wipe it off further)
    And i do use a actual inch/lb torque wrench and adjust the setting 20% lower to account for the anti seize.
    I think a lot of the no recommendations are based on people using it and NOT adjusting the torque to account for the lubrication effect of anti seize.
    My 2015 has a 30,000 mile change recommendation. On the 3rd set now and all is well.
    Still galls me that the dealer book time on a plug change for the 4.0 is 3 hrs :annoyed:
    Even my first change where it wasn't familiar only took me 1.5... Cost like $42 for plugs vs close to $400 for change at dealer
    Rraiderr[OP] and ThreeBeers like this.
  11. Oct 29, 2023 at 2:03 PM
    Gatafly
    Shawn
    What don't you get? Iridium plugs are extra long life. In my 4runner they were 100k miles and even with that many miles they looked good and performed great. Changed my Taco at 60K and I won't do it that soon again. Minus slight discoloration they looked nearly new.
  12. Oct 29, 2023 at 3:22 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I would change at 50k
    I always prefer to do maintenance EARLY, never late
  13. Oct 30, 2023 at 11:49 PM
    danielgonzzz
    danielgonzzz Well-Known Member
    Daniel
    2019 Tacoma TRD Sport 4x4
    Stawk as FUCK!
    Sure glad I did my plugs earlier at 43K miles. 3 of the 6 (all passenger side) were LOOSE while another was barely hand tight on the driver side. Cannot believe I was not having ignition/detonation issues with how loose they were, insane.
    Rraiderr[OP] and Freeheelbillie like this.
  14. Oct 31, 2023 at 12:37 AM
    MGMDesertTaco
    How ironic. I did mine at 18k. All passenger side were extremely loose not even finger tight and I believe 1 or 2 on drivers side were loose, but not as bad.
    Truck runs so much better now. :rolleyes:
  15. Oct 31, 2023 at 12:48 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What about this combo?
    Toyota uses aluminum head for many decades with spark plug replacement schedule at 120k miles.
    Even on I4 D4S engine is recommended at 120k mile
  16. Oct 31, 2023 at 2:53 AM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Note to self, check spark plugs this weekend!
  17. Oct 31, 2023 at 5:00 AM
    ThreeBeers
    Ron
    2020TRDOR
    Only what I have been told my mechanics and reading over the years. But steal and aluminum have different expansion rates. Multiple cycles of heating and cooling added that steal and aluminum bond over time. Aluminum is much softer that steel and it is Supposably easier to strip the threads when you take out the plugs.
    I just go by the what can it hurt to change them out sooner than later theory.
  18. Oct 31, 2023 at 5:15 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    There are not "2 sides" to the spark plug anti seize debate. Manufacturers of spark plugs say don't use it, and explain why. If you have a crazy theory about why you use it, that's great, however that theory wrong.
    https://ngksparkplugs.com/en/resources/5-things-you-should-know-about-spark-plugs
  19. Oct 31, 2023 at 5:20 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Would the Dealership be the best place to get new plugs?
    MGMDesertTaco likes this.
  20. Oct 31, 2023 at 5:23 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Agreed. Just as many here question why anyone would think they are smarter than a Toyota engineer with respect to oil changes they then choose to ignore their plug change interval. I too believe there’s no reason to use anti seize BUT if you are going to ignore the change interval and leave them in there for twice the period you likely will need the anti seize.
    Change at 60k and don’t use anti seize and you are following the experts advice. How is that a bad thing?
