Spark plug and fuel filter tune up for a 5VZ-FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Apr 19, 2018.
  1. Apr 19, 2018 at 9:03 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    Recently I was complaining that having a camper shell on my 2WD 6cyl halfcab Taco has slowed it's acceleration and bogged it down. My friend who also has a 1st gen halfcab Tacoma recommended that I get NGK Iridian spark plugs and a new Toyota fuel filter, and that then I will notice a slight improvement in MPG and performance. What would you recommend?
    Lucifer1 likes this.
  2. Apr 19, 2018 at 10:34 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    a proper tune up on your engine will help get back some of those lost hp, you might get a little better throttle response, but really a good tune up will give your engine that “like new” feel again.
  3. Apr 19, 2018 at 11:28 PM
    Cutter_
    What is in a proper and good tune up?
  4. Apr 19, 2018 at 11:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Fresh fluids all over, all new filters, spark plugs, spark plug wires
  5. Apr 19, 2018 at 11:47 PM
    Tacoma Dave
    Tacoma Dave Long time lurker
    David
    Oakley, CA
    04 xtra cab trd
    2004 trd off road 4X4, 265 75 r16 bfg at, bilstein 5100 all around front at 1in, rear firestone ride rite air bags
    Also clean throttle body as it can accumulate gunk. Clean maf sensor while your at it as well as the iac valve. Maybe seafoam if you still dont see or feel any improvement.
  6. Apr 19, 2018 at 11:50 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    I don’t know if iridium plugs will actully help you at all, just regular dual ground NGK’s would probably be best
    TACO TX, Dalandser and Sperrunner like this.
  7. Apr 19, 2018 at 11:54 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Im not sure either, when i swaped my plugs and wire i just got the ngk kit off ebay, im sure the plugs were the same as my old ones.
  8. Apr 19, 2018 at 11:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Also op how many miles are on your truck?
  9. Apr 19, 2018 at 11:57 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    My tune up consisted of:
    -New plugs (make sure to get dual ground, it says it on the engine if anyone tells you otherwise)
    -New wires
    -Fuel Filter
    -Air filter
    -Clean MAF
    -Clean throttle body
    -Clean IAC
    Will take you an hour or two to do everything, just depends how many beer breaks you need :cheers:
    I also ran a few of those Lucas Oil fuel injector cleaners the few fill ups leading up to the tune up. They were buy one get one so I figured why not
    Lucifer1, Dalandser and Sperrunner like this.
  10. Apr 20, 2018 at 12:01 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I usally run a couple tanks of shell premium after so many tanks of the lower end shell, because it has some of that stuff in it to that helps break up the gunk
  11. Apr 20, 2018 at 1:33 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    From a master tech - he said spark plugs have changed a lot since back when these were rolling out of the factory with dual ground spark plugs so it may not be as important with the plugs available these days, but like you said there's also nothing gained by going with something that wasn't spec'd out for the engine. Unless you're changing the specs of the engine with a turbo or sc'ing :devil: :D :burnrubber:
    Captain Magma[QUOTED] likes this.
  12. Apr 20, 2018 at 10:03 AM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Boosted engines is where iridium comes into play, with the colder spark?
    Dalandser[QUOTED] likes this.
  13. Apr 20, 2018 at 10:29 AM
    Cutter_
    100,000
  14. Apr 20, 2018 at 10:30 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Have you done your water pump and timing belt? I think its supposed to be even 90k
  15. Apr 20, 2018 at 10:31 AM
    Cutter_
    I bought the truck at 80,000 and put about 25,000 miles on it in a year. Haven’t done anything but oil. Air filter is surprisingly spotless after taking my truck on a 500mi road trip to bishop CA, but I’ll change it. My friend is pressuring me to change my shocks, he did a full king set up on his taco the thing is a 4wd tank. I put an 800lb Harley Davidson in my bed a few months ago and he said it blew my shocks - my shocks are very very stiff when riding I don’t like it, so he recommended bilsteins
  16. Apr 20, 2018 at 10:32 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    So other words it’s probably time do change your water pump and timing belt
    Captain Magma likes this.
  17. Apr 20, 2018 at 11:43 AM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    You'd be surprised how much a complete timing belt job, while pricey, can revamp an engine as well
  18. Apr 20, 2018 at 11:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    TBH I don't know about the iridium part - I'm assuming it wouldn't hurt in terms of longevity, but yeah colder / different spec'd ones than the 5vz's rolled out of the factory with was what I was trying to get at for sure :)
  19. Apr 20, 2018 at 11:47 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    They don't necessarily have to be iridium, they just have to be 'cooler' plugs...IK20 or IK22 is what a supercharged 5VZE calls for IIRC. The 'normal' heat range plugs that our engines use are IK16. There's no reason to go with a cooler plug if you aren't boosted, and it could actually put you at a disadvantage if you do from what I've read.
  20. Apr 20, 2018 at 11:49 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Op check ebay, ive seen a fuel sellers who put kits together with oem toyota parts for like 300 that comes with all you need to do your timing belt and water pump.
