Spare tire upside down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Otterstuff, May 9, 2022.
  1. May 9, 2022 at 1:40 PM
    Otterstuff
    Otterstuff [OP] Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    Does anyone know why the spare tire is mounted with the valve stem up? Is that to protect it from rocks breaking it off? They seem to gather more dirt and rust easier with valve stem side up. Has anyone tried to mount with valve stem down? Any issues? Thanks.
  2. May 9, 2022 at 1:42 PM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Otterstuff[OP] likes this.
  3. May 9, 2022 at 1:43 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    I assume it's so that the chain doesn't have to be extended so far. I put mine back on with the stem facing down just because I've had to change two flats and my spare wasn't as aired up as I like, so I make sure to fill it too.
  4. May 9, 2022 at 1:51 PM
    Otterstuff
  5. May 9, 2022 at 1:58 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I keep mine valve stem up. Protects the face of my spare from getting beat up. Granted I have a full size spare with matching wheel so I don't want it dinged up and IF I had a steel rim spare I wouldn't care. I also have onboard air so if my spare is underinflated it's not a problem to air it up.
  6. May 9, 2022 at 2:49 PM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    I put mine on face down, so I can check that it is full of air before trips etc. I have done this since at least 1977 and never had damage to the spare. YMMV
  7. May 9, 2022 at 2:58 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    My $0.02. With the valve stem up, it’s easier to winch it up because all the mass is all on top. With the valve stem down, the tire keeps wobbling and doesn’t self center when you winch it up, you have to hold it still with your hand.
  8. May 9, 2022 at 3:07 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Like others have said, flipping it over allows you to check the pressure easily. I turned mine over and have had it up and down a few times and haven’t had and trouble with it coming loose, centering or wobbling.
    I’d recommend soaking down the entire mechanism with Fluid Film (or whatever rust proofing you prefer) while it’s down. Also, try to put the valve at the very back so you can get to it without having to crawl under the truck to reach it....
  9. May 9, 2022 at 3:09 PM
    CaptAmerica
    Cap
    Oh, so we are bringing common sense physics into this?
    That might explain why my spare groaned when I cranked it back into place.
    Time to flip it. Again.
  10. May 9, 2022 at 3:09 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    It’s the nod to the Australian Hilux.
    Speedbird and CaptAmerica like this.
  11. May 9, 2022 at 3:16 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I thought it was mounted face up because of the mount used to secure it has a flat surface that butts up nicely against the flat surface on the back of the wheel without damaging it.
    Might not be an issue for most, but I prefer to not gouge the finish on my aftermarket spare wheel (even if it is cheap). Can get a valve stem extension if needed to make this easier.
  12. May 9, 2022 at 3:18 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    A better solution is to move the spare tire to the bed (if you don't need the space to carry cargo). Under the truck is a pretty bad place, for several reasons.
  13. May 9, 2022 at 3:19 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I always flip it upside down so I don’t have to pull the tire down to inflate it.
  14. May 9, 2022 at 3:20 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    If the stem is up, then you have to exercise the lift mechanism in order to check it. Then there is less of a chance of it being seized when you really need your spare. Just my thoughts.
  15. May 9, 2022 at 4:19 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
  16. May 9, 2022 at 5:54 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I tried doing that, but my spares always went missing. Tacomas near me must get a lot of flat tires because people kept taking mine out of my bed… Now its back under the bed . Safe and sound..
  17. May 9, 2022 at 9:44 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    doesn't everyone have an inflator they carry all the time?
    Taco_mike73 and chuam like this.
  18. May 10, 2022 at 5:48 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I have started to fluid film every fall. So I take the spare out to do that then I coat to mechanism with some ff, check the tire and give the spare steel wheel a light spray too before putting it back in place.
    may not be great only checking the tire once a year but better than people that never do an find it flat when they need it most.
    I carry one often when I go out to the bike trails and camping. It’s only a 12v one. It’s come in handy though and you make new friends with others at the trail heads when you got air
    Big tall dave and Otterstuff[OP] like this.
  19. May 10, 2022 at 6:39 AM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    The assumption for carrying the spare in the bed is having a camper shell or some other means of securing the tire. I wouldn't carry it exposed in an open bed.
  20. May 10, 2022 at 7:17 AM
    Taco_mike73
    York, PA
    Also needs to be secured too. Not wise to always carry it loose in the bed. It becomes a projectile in an accident.
