Spare Tire TPMS sensor?? I thought?
Discussion in 'Wheels & Tires' started by mhomewood, Apr 1, 2010.
  1. Apr 1, 2010 at 5:38 PM
    mhomewood
    mhomewood [OP] Member
    Mesa AZ
    06' Tacoma Sport 4X4
    i know this subject has been beaten to death, but i experienced something i thought was a little odd the other day. I dropped off my spare tire to get a 285 put on and expected my tire sensor light to come on when i left the shop. Surprisingly it never came on, even after stopping and starting my truck a few times. I know there is a sensor in it cause I saw it when i removed the tire last time. Has anyone else experienced this before?
  2. Apr 1, 2010 at 5:43 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    yup... im doing that shit now... i have to change the sensor form the stock spare to my new one.... its annoying as hell...
  3. Apr 1, 2010 at 5:47 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You leave the tire at the shop?? or just swap it and put it back on your truck??
  4. Apr 1, 2010 at 5:48 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    He dropped off his spare wheel and tire, to have a larger one put on. While they were doing this, he left the shop(without the spare). Once they put the new tires on, he will go back and pick it up.
  5. Apr 1, 2010 at 5:52 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    I believe that the sensors only send a trouble code when there is a decrease in pressure of 25%. As far as your Tacoma is concerned, it hasn't been notified of a trouble code, it just hasn't heard from the sensor at all. I'm guessing that the light will come on after a period of time in which the sensor and receiver do not communicate, but I have no idea how long this takes.
  6. Apr 1, 2010 at 5:58 PM
    Trauma85
    Trauma85 Well-Known Member
    Tyler
    Idaho
    2014 Tundra
    I work with these systems every day, and pretty much have toyota's tpms systems down. the systems are just strange somtimes, a dude from work took his spare out of his wifes truck with a sensor in it, 2 years ago, and never put it back and the light doesnt come on at all. The tpms computer sends a signal to the sensors every X amount of minutes, to wake them up and get a reading. If it doesnt get any comunication from one of the sensors, usually it will keep trying for X amount of trys, and if it still doesnt wake that sensor up at the end of the sequence, the light will come on. usually the sequence only lasts 10-15minutes before it decides something is wrong and sets the light off though. Its programed like this because if a sensor didnt want to wake up right away, your light would be on all the time. Thats the most simple answer I can give you. Your system is still working though, if you get a low tire it will kick the light on.
  7. Apr 1, 2010 at 6:03 PM
    Wrencher86
    Wrencher86 Active Member
    Chicago, Il
    '10 4x4 5Spd Reg. Cab 4cyl.
    My spare doesn't have a TPMS sensor in it. I thought that was kind of weird. I got a flat and when I took the tire down it had a rubber valve stem. So unless they are using a different sensor in the spares...
  8. Apr 1, 2010 at 6:05 PM
    Trauma85
    Tyler
    Idaho
    2014 Tundra
    Some trucks dont come with them in the spares. Depends what package you got I guess. or wether toyota felt like putting one in the spares the day it was on the assembly line...
  9. Apr 1, 2010 at 6:06 PM
    LostRebel
    Almost Canada, USA
    They discontinued the sensor in the spare on 2009 models.
  10. Apr 1, 2010 at 6:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Actually it's a 09/10 thing to not have the TPMS in the spare....
  11. Apr 1, 2010 at 6:08 PM
    mhomewood
    Mesa AZ
    Thanks LostRebel and Trauma85. That clears some things up. I knew the sensor worked because I've had to put air in the spare to clear the warning light. I just expected it to turn on as soon as i left the shop.
  12. Apr 1, 2010 at 6:09 PM
    Trauma85
    Tyler
    Idaho
    2014 Tundra
    I didnt even look the year of his truck.. I just know that ive had tacos come in with them, then one of the same year another day that didnt come with it programed.. Either way, Either youve got one or you dont.
  13. Apr 1, 2010 at 8:10 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    When I swap out my stock alloys with the stock tires for my steel wheels with the 33s on them ( I do this 6 or 7 times a year) sometimes the light wont come on for a day or two, then it's on all the time. Unless I park the truck near where the stock tires are stored then it kills the light for a day?? Must have a 20 or 30 foot range. When I get new tires for the alloys I will pull all the sensors out and install them in a piece of pvc pipe with a couple glued on caps and a valve stem so I can pressurize them and hose clamp it under the frame somewhere. End of light problem:D
  14. Apr 1, 2010 at 10:57 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    I haven't had any sensors on my tires since i put them on. About 2 years then out of know where the light came on my dash and i couldnt get the bugger off for the life of me. Well a week ago after it being on since november it just shuts off. I think these sensors are screwy as HELL.
  15. Apr 1, 2010 at 11:07 PM
    Timber
    Tim
    San Pedro Bay Ports
    That's even more screwy than my deal. I kind of understand my problem. Not even having them for 2 yrs without problems then all at once is strange especially since it went out again after 5 months. Are the old wheels& tires still somewhere you park every day?
  16. Apr 1, 2010 at 11:09 PM
    snowgod06
    Rob
    06 Access Cab
    your telling me, i talked to RCBS about it and was gunna rip my dash apart to just cut the wire that gave the light power. My old wheels/tires arent even in the same state so that didnt start anything. I thought there was some problem with the system but then jsut said screw it I DONT CARE. Well atleast i dont have to go on a wire hunt anymore.
  17. Apr 1, 2010 at 11:25 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I had all my 4 tires in my kitchen for a week before I put my lift on. My light never came on.
  18. Apr 1, 2010 at 11:34 PM
    mhomewood
    Mesa AZ
    Well gentlemen, i must say. Gotta love that 30,000 dollars of PSI accuracy!
  19. Apr 2, 2010 at 4:01 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    good info right there :)
  20. Aug 21, 2015 at 12:31 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Weird. I have a 09 and my TMPS light came on. All the tires had perfect pressure except the spare. I filled it to 30 and the light went off.
    was that a fluke then?
