Spare tire size question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by manncura, Nov 19, 2020.
  1. Nov 19, 2020 at 7:38 AM
    manncura
    manncura [OP] Well-Known Member
    2020 DCSB 6MT Sport
    Just a quick question...Just bought a 2020 Sport. And put new tires on it this morning and discovered the spare is a 16 in wheel not 17 like the stock wheels...is that supposed to be that way? Thanks :)
  2. Nov 19, 2020 at 7:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's crazy. It is a 17in on my 2017. It was a different tire than the other four though.
    The overall diameter will be the same if you are sticking with the stock tire size. If you went to a 265/70R17 on the new tires, it still isn't an issue for emergency use. You just don't want to use 4wd while different diameters are on there.
    whatstcp and Thunder Fist like this.
  3. Nov 19, 2020 at 7:49 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Anyone remember the small folding spare tire......
    The sidewalls would fold when the tire was deflated. The spare had to be inflated during the change of the flat with a small N2 can. Super PITA. I had one of these in my old '77 Buick Skyhawk. Ended up getting a POS (not Point of Sale) 12Vdc inflator.
    Then the "donut" spare tires came out. Then spare tires were removed from some models.
    Like @whatstcp said, "....it just a spare..." Meant to get you to a repair, not permanent.
    manncura[OP] likes this.
  4. Nov 19, 2020 at 7:50 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    As long as the diameter is within an inch or so it's fine. Just don't go fast and make it a priority to get a new tire.
    tonered and stevesnj like this.
  5. Nov 19, 2020 at 7:51 AM
    LoveableWerewolf
    Nashville
    Omg, I didnt ever realize that's a thing. Most small cars no just have a sad can of fix a flat. When I found that out, we got my wife a donut from the junkyard.
  6. Nov 19, 2020 at 7:56 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    +1
  7. Nov 19, 2020 at 7:57 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Twas a time the spare matched the other four and would be used in tire rotation. When radials came out and rotation was front to back / back to front same side. The tires were the same but rims were generic.
    I still have the original spare in my ‘78 Ford. Many sets or tires later and it’s been on the ground only once or twice.
    I wonder if an original, first generation General steel belted radial has any collectors value.
  8. Nov 19, 2020 at 7:59 AM
    Knute
    A rubber recycler would value it.
  9. Nov 19, 2020 at 8:01 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Interesting. I didn't know that happened. It does make sense. Like you said, pretty much inconsequential.
  10. Nov 19, 2020 at 8:02 AM
    manncura
    2020 DCSB 6MT Sport
    Make sense...at least for them :) I just didn't even consider it and bought 5 265/70/17s. No biggie, Ill just return the 5th one and leave the spare the way it is.
    tonered likes this.
  11. Nov 19, 2020 at 8:04 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't know about collectors value but I'd not trust a tire that old. They don't recommend a tire much over 5-8 years old regardless of how many miles. A spare kept out of sunlight might be good for longer, but not 40+ years.
    I replace my spare with one of the better take off's every time I get a new set of tires to ensure the spare isn't too old. Of course that wouldn't be possible in the OP's case unless he picks up another 17" wheel.
  12. Nov 19, 2020 at 8:07 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    The 80s 300ZX had those in the interests of space saving. I'm positive I'm come across others, but can't recall which cars they were in. Never used one, but they didn't make me feel safe at all.
    The newer Mustangs, a spare tire and associated tools are an option. If you don't get them, you get an air pump and a can of fix a flat. If you get the Premium Package (not sure if it still exists) you couldn't even use the optional spare because it didn't fit over the brakes. I can tell you, from experience that getting a flat in that care really sucked.
  13. Nov 19, 2020 at 8:11 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You could probably get a 17in steelie or even a matching alloy for pretty cheap? Lots of folks swap out the wheels.
    whatstcp likes this.
