Spare Tire Lock Removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bstrange, Aug 15, 2018.
  1. Aug 15, 2018 at 1:11 PM
    bstrange
    bstrange [OP] Well-Known Member
    2017 Tacoma Off Road
    Does anyone know how to remove the spare tire lock? I had to change the tire the other day, in the garage, and it was a pain. The key would not stay on the end of the bar until I duct taped it. If Im on the side of the road in the rain it would be a major problem.
  2. Aug 15, 2018 at 1:12 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Interesting, I do not have a spare tire lock
  3. Aug 15, 2018 at 1:40 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Question... Did you put the key from the fob on the end of the rod? As far as I'm aware, there isn't a spare tire lock
  4. Aug 19, 2018 at 10:13 AM
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
    There is a "spare tire lock" option that can be installed at the port of entry or by a dealer. Has a "key" whose end has a unique pattern that fits into a receiver installed on the spare tire winch (not sure that's what it's actually called.) It's similar to lug nuts you can get that require a matching driver. Amazon has 'em.
    My 2014 Taco has one. I found it to be a PITA, so I drilled a hole through one of the extension bars and the key, then bolted them together. Works like a charm, especially with the PCV pipe guide mod.
  5. Aug 21, 2018 at 1:14 PM
    bstrange
    I went to google to get an image of the lock and realized I was using it 100% wrong.
    pipe guide mod?
    Vbpiper likes this.
  6. Aug 21, 2018 at 1:17 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    did you install the key right?
    it supposed to attach to the hook and mine has a retaining ring that you would spin around it.
    I've never had an issue with it staying on, more so an issue taking it back off. Would need to hit it on the ground to get it to free up so I can take it off the hook.
    JoeCOVA likes this.
  7. Aug 21, 2018 at 1:22 PM
    bstrange
    That's what you SHOULD do. The other end of the rod, without the hook, doesn't stay on very well. :thumbsup:
    Joe23[QUOTED] likes this.
  8. Aug 21, 2018 at 1:37 PM
    KactusJack
    Collettsville, N.C.
    2014 AC TRD Sport
    bstrange[QUOTED][OP] and Vbpiper like this.
